Old 01-05-09, 01:18 AM   #1 (permalink)
sessions's Avatar
Oil leak
I'm looking into buying an 85 fj60 and the current owner states that it leaks a little oil. It's in Bend and I'm in Spokane so I can't decide if it's worth looking at or if it could be a bigger issue. It's a daily driver and I doubt it's seen much dirt. Any advice or things to look at when I make the trip to look at it?
sessions is offline   Reply With Quote
Old 01-05-09, 09:04 AM   #2 (permalink)
Leaking oil is not uncommon. It can be caused by a leaking oil pan gasket, push rod cover, or more serious rear seal. Before you take the plunge, you should check out other issues like rust for instance. There are multiple threads to help you know what to look for. Here is a good start point.
http://forum.ih8mud.com/60-series-wa...year-best.html
slcfj62 is offline   Reply With Quote
Old 01-05-09, 01:58 PM   #3 (permalink)
Land Cruisers and Massey Ferguson tractors are very much alike in utility, durability, torque curve (possibly top speed) and yes, oil leaks. Pan gaskets and rust holes under the skid plate that is spot welded to the bottom on the pan are the usuall suspects. It's a fairly easy fix.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
lehiguy is offline   Reply With Quote
Old 01-05-09, 09:25 PM   #4 (permalink)
sessions's Avatar
Thanks for the information!
Old 01-05-09, 11:11 PM   #5 (permalink)
sessions's Avatar
Well it looks like I'm off to Bend to take a look at the 60!! Hopefully it works out cause I bought a one way ticket... I'll keep ya posted!
Old 01-11-09, 06:58 AM   #6 (permalink)
grant5127's Avatar
Did ya get it?
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|_____________________/||__|___|
The Beer Truck, that ran over Bunny.....
(\__/)
(")_(")
grant5127 is offline   Reply With Quote
Old 01-14-09, 12:03 AM   #7 (permalink)
sessions's Avatar
Yep flew into Redmond and hitched a ride to Bend and got dropped off at Deschutes Brewery and sampled all the finest brews until the PO picked me up in it. I had the local Les Schwab shake it all down for me and identified some hopefully minor issues. The Transfer case is leaking it looks like from the seal and the yoke slip needs some attention and it definitely needs new shocks and leaf springs in the future. I think the transmission is leaking from the drain bolt? The shocks aren't leaking, OEM still! I'm thinking about a 3' lift and while I'm at it getting some of the oil leaks fixed.
The only things I noticed when driving it back to Spokane was the temp gauge went to almost hot and at the same time the gas gauge went to full?!? It did it a few times then both dropped back to normal. Also when coming off the freeway or high speeds in neutral it almost died. I'm thinking maybe adjusting the idle? I averaged just about 14mpg @ 60-65mph.
I'll post some pics of the leaks and hopefully all you rad members could help me out!!!
Karl
08 Freddy, Brindle Boxer Puppy, Newest addition to the Fam!
85 FJ60-New addition to the family
95 Toyota Tacoma
03 YZ250F
06 Yamaha R6 50th Anniversary Edition
08 Yamaha WR250X
Old 01-14-09, 12:15 AM   #8 (permalink)
tonyota's Avatar
TLCA# 15492
Mine leaked from the pan gasket, & the pin holes under the oil pan skid, & the side cover & the fuel pump mount & the oil sending unit, & the valve cover...I got a complete gasket set from Toyota. ( only use OEM Toyota gaskets, you'll be glad) & with just a few hours & some degreaser & some cussing, My engine is leak free. Now the power steering box, that's another story. Your new Rig looks sweet.
It's All Good, All The Time.
83' FJ60. . Yeah, its got some mods.
tonyota is offline   Reply With Quote
Old 01-14-09, 12:24 AM   #9 (permalink)
sessions's Avatar
Cool thanks! You're in Spokane right? Maybe you could take a peek and double check it. I'll buy the beer or soda your choice. The PO replaced the rear main, valve cover gasket, clutch and oil pan gasket in early 08. So im hoping just a few minor repairs before I get out and play, then time to lift it!
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-14-09, 12:47 AM   #10 (permalink)
tonyota's Avatar
TLCA# 15492
I'm in Indiana, if your talkin to me that is. I'd be glad to check it out with you , if I was close. I cleaned the engine best I could & started looking for wet spots (take the sexual overtones out of that statement). Mine was leaking like the Exxon Valdiz, not just a spot here & there.
If you want to pretend that I'm helping, just draw a picture of a stupid looking shmo, place it leaning on the fender of the 60 & say something ignorant on my behalf every now & then.....It'll be just like I'm actually there.
Good luck with the project, take your time, one leak at a time & it'll be done in no time. Lifting them is fun too.
Old 01-14-09, 04:43 AM   #11 (permalink)
hank14's Avatar
TLCA# 17839
Fuel and temperature gauge spike repair. Common problem. Mine did it when I was driving it home right after I bought it. Freaked me out, but searching mud eased my mind.
http://forum.ih8mud.com/60-series-wa...ding-unit.html
http://forum.ih8mud.com/60-series-wa...zy-gauges.html
Congrats on your purchase!
Scott
Granbury, TX
1987 Beige FJ60.
One clean cruiser.
hank14 is offline   Reply With Quote
Old 01-14-09, 09:12 AM   #12 (permalink)
sessions's Avatar
Tonyota lol thanks, guess i mixed ya up with another member. thanks for the advice! my buddy bought a 79 toyota 4x4 and it leaked like a quart of oil an hour so i named it Valdez! haha
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-14-09, 09:22 AM   #13 (permalink)
sessions's Avatar
Thanks Hank14!! I about crapped myself when I saw the temp gauge spike to hot!!! I immediately pulled off the freeway and popped the hood to let it cool down and drank a beer in the meantime..lol What a relief!!!
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-14-09, 09:39 AM   #14 (permalink)
Hey, that's a decent looking 60, I think you did all right there. The crazy gauges thing is common. Mine still does it now and then.
Old 01-14-09, 06:04 PM   #15 (permalink)
sessions's Avatar
Thanks! Well the first battle is over...passed emissions!!! FYEAH!! Now all I have to do is fork over some sales tax $ to the man to transfer the title!!
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-16-09, 01:10 PM   #16 (permalink)
sessions's Avatar
So I just had the transmisson shop take a look at the tcase, knuckles, f+r diffs, slip yokes and the transmission. Looks like the best route to go would to be replacing the rear half of the tcase due to the oil filler bolt leak (they said that a hellicoil might not be big enough to resolve the leak) definetely needs the seal replaced in all of the above mentioned areas. They gave me quote for about $1k to do all the work.
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-16-09, 01:20 PM   #17 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Damn. Rebuild the t-case for $1k? Makes me reflect on how much my truck would cost me if I couldn't do the work myself.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is online now   Reply With Quote
Old 01-16-09, 01:25 PM   #18 (permalink)
sessions's Avatar
the quote was to do all the work on the tcase, transmission, f+r diffs, knuckles and slip yokes. I don't have a shop to work in, adequate tools and none of my buddies will even touch the tcase or transmission. It doesn't help being a noob mechanic either. LOL
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-16-09, 01:36 PM   #19 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
I didn't realize the quote was for so much! Rebuilding the front axle at the dealer with all the parts costs far more than that.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 01-16-09, 02:38 PM   #20 (permalink)
tonkota's Avatar
TLCA# 14154
Dude, baby it until spring, then bring it over (damn I wish I had a garage!) The work isn't that big of deal. I think you'll be amazed how simple this thing is.
BTW, it looks very good. Stop by some time and take a look at the leaks on my FJ62 for comparisons sake.
A Ron
Using one cruiser to [ c'mon snow!! ], and the other to collect dust.
2F-E Article
McNamara gear writeup
Complete Camshaft Info
SPOKANE LAND CRUISER FORUM ON IH8MUD
tonkota is offline   Reply With Quote
Old 01-16-09, 03:28 PM   #21 (permalink)
forestdan7's Avatar
TLCA# 17532
That's good advice. Resist the temptation to pay somebody to fix all those things right away. $1000 sounds too cheap for all that work anyway. It can leak forever and still be fine. Just keep the fluids full, and address things one at a time. You'll learn a lot. And gain some good tools along the way.
Nice looking truck. Dig the pinstripe. Have fun with it.
1985 FJ60
1987 4Runner -- SOLD
2002 4Runner Limited
2007 Honda XR650L
forestdan7 is offline   Reply With Quote
Old 01-16-09, 05:15 PM   #22 (permalink)
sessions's Avatar
Cool guys! I just got the garage cleaned out and I think I'll start with small projects and learn as I go. I just got a repair manual and with the extra money from I'm not paying a shop to do the work I can buy a lot of seals/gaskets etc.!
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
Old 01-16-09, 05:23 PM   #23 (permalink)
tonyota's Avatar
TLCA# 15492
X2 on that take your time & fix it your self thing. You'll get to know your way around the rig & it's not that tough to fix any of those items. It'll bring you & your rig closer to becoming one.
Old 01-16-09, 07:10 PM   #24 (permalink)
ktwilson's Avatar
I had the fill plug on the transfer case repaired by this guy, Land Cruiser transfer case drain plug repair | OlympiaFJ60. Cost me more to ship the back half of the case to him than the repair but still a lot cheaper than buying the tools and doing the repair myself and he did a great job.
ktwilson is offline   Reply With Quote
Old 01-17-09, 12:45 AM   #25 (permalink)
sessions's Avatar
Cool thanks!! Good looking out!
Karl
95 Toyota Tacoma
03 YZ250F
08 Yamaha WR250X
