11-03-04, 07:35 PM
SOA build up: talk to me about cut and turn
I went to cruiser outfitters and checked out their cut and turn products. But I dont really understand it. I just bought an ARB for the rear. Is the cut and turn a new redesigned third member or do you use the existing one??
thanks,
mark
11-03-04, 07:40 PM
Supporting Vendor
I may be qaulified to answer this...
The cut and turn axle we offer is simply a modified OEM axle housing. The third member is completely interchangable, nothing is modified in respect to the differential setup.
For the FJ60 axles, we require your core axle to cut and turn, this is due to the fact we have ZERO 60 series axle housings available for modification.
I am working on a Cut & Turn tutorial for my webpage, but in summary...
Purpose: To rotate caster backwardd (to between 3-5 degrees) with respect to the line perpendicular to the ground. At the same time, we rotate the pinion upward to the provided spec (usually between 6-22 degrees) with respect to the line parallel to the ground.
Any other questions? Lemme know
11-03-04, 07:50 PM
ohh okay thanks alot for your help.
So basically all I need to do is send you my existing third member and let you do the modifications to it?
thanks again,
Mark
11-03-04, 07:56 PM
One more thing... Do you recommend cut and turn on both front and rear axles?
Im going to be doing a SOA with OME springs and hopefully a marlin crawler with the stock transfer case. So my rear driveshaft will be significantly shorter.
11-03-04, 08:01 PM
Location: Silver Spring, Maryland & Daytona Beach, Florida
thanks again,
Mark
Mark, hmmm ... a cut-n-turn is done to the axle housing. I think he means he need your front *axle* housing, not the third.
Cheers,
Cahil
67 Red FJ40 - SBC, Holly, NV4500, SOA
87 Blue FJ60 - Cummins 6BT, NV4500, OME, SUA
..... coupla' parts rigs too ...
11-03-04, 08:24 PM
Supporting Vendor
thanks again,
Mark
Nope, not the third-member (aka pumkin, differential, dropout...) We need the entire front axle housing, no diff, no shafts, no knuckles, just the bare empty housing.
11-04-04, 06:36 AM
Hey Luvenmud15
Also, check out http://www.proffittscruisers.com/
I bought my cut and turned from them cause they had one in stock and when i am done my SOA, i will send them my stock housing as a core while i build up the cut and turned housing in my garage while still driving them 60 around. It was a lot easier for me to do that then to rip done my rig and send away my one and only housing!
I was VERY please with the quality of work they did on the housing!
My .02
11-04-04, 06:40 AM
Admin
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
- 1974 FJ40 'The Raisin' - 39" Pitbull Maddogs, 17x9 TrailReadys, 30-spline Longfields, SOA - 1/4 ellip, Ultimate Air, MobiArc, Optima RedTop
- 1996 FZJ80 'Gretchen' - MetalTech sliders, MetalTech tube front, MileMarker V10 MiFi, OME lift, IPOR rear & skid, 4x4Labs swings, INTI rack, dual Optima RedTops, 285 TreadWright tires, Ultimate Air, Raingler Barrier
- 2009 buggy....designing... RockCrusher60's
- 2003 2500HD Duramax - Edge/Juice/Attitude, 285 Hankook DynaPro ATM, KYB MonoMax, 4" exhaust
- 2008 32' ABU Gooseneck car hauler, 2000 Damon Hornet M-32F, 1997 14' car hauler
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
12-03-04, 06:27 PM
Supporting Vendor
Originally Posted by cruiseroutfit
...For the FJ60 axles, we require your core axle to cut and turn, this is due to the fact we have ZERO 60 series axle housings available for modification....
This has changed...
FJ60 Cores now in stock (however they are slightly more expensive than the 40 cores)
