Old 12-16-08, 07:36 PM   #31 (permalink)
Tinker's Avatar
Vic -
You'll prolly have to go through the pull-down menu here but RockAuto has several brands: RockAuto Parts Catalog
Can't tell from the limited pix how the ebrake cable attaches. Note, however, that they're single-piston, floating-frame calipers just like the Eldos & Montes.
Spook50 confided to me in an email that he thinks maybe his ebrake cable setup was the cause of his TSM rear disc park brake failure. Bums me out 'cause I put him onto the Lokar cables he used. Told him Madison Power Systems can make up "simple" brake cables (nowhere as complicated as a 60/62 or late 40).
"His mudder was a mudder".
Tinker is offline   Reply With Quote
Old 12-16-08, 10:56 PM   #32 (permalink)
Moby's Avatar
FWIW I'm running TLC4x4's Monster Calipers (they are made by SSBC). I bought these before I knew about the 4runner/mini swap. My rear brakes are well adjusted, the system is well bleed (with Super Blue fluid), and I've compensated the LSPV (fj62) for my lift. Stock MC. The Monster calipers still made a noticeable improvement - panic stops now have much less panic involved. Are they worth it over the 4runner/mini calipers? Probably not, but I've not driven those so I can't say for sure.
As a side note the Monsters actually look like they have more wheel clearance than stock. Fit perfectly fine with the cheap-o wheels I was running when I first got them and plenty of room with my current Stockton Explorer 72s in 16x8 with 3.25BS.
Joel
'89 FJ-62
Moby is offline   Reply With Quote
