Go Back   IH8MUD Forums > Toyota Tech Forums > 60-Series Wagons
Old 12-02-08, 09:14 PM   #1 (permalink)
mp_cude's Avatar
what is the A/C idle solenoid..also any other a/c stuff i should know
im getting ready to fix the a/c in my 60. I bought a new dryer and a used a/c pump off a wrecked low mileage 60. I just desmogged my truck, and put all smog/vac line stuff in a box. I recently came across a write up mentioning the AC idle solenoid. I assume I removed it when i did the desmog. Before I start on my a/c project I would like to get all the inexpensive parts on hand so I don't go back and forth with it.
mp_cude is offline   Reply With Quote
Old 12-03-08, 06:01 AM   #2 (permalink)
NocalFJ60's Avatar
It is a diaphragm mounted on the front of the carb that turns up the idle when you turn on the AC. There is a solenoid mounted on the driver side fender which gets vacuum from the intake manifold right next to where the brake booster gets its vacuum. The solenoid opens the valve when you turn on the ac and sends vacuum to the diagram that turns up the idle which is adjusted with a small screw on the linkage on the carb to raise or lower the idle.
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 12-03-08, 08:52 AM   #3 (permalink)
mp_cude's Avatar
do you know if there is any way to run that with my weber?
Old 12-03-08, 09:42 AM   #4 (permalink)
NocalFJ60's Avatar
I am pretty certain there is not a diaphragm like the stock one on a weber. Maybe someone that has a weber can tell you what they did. I am guessing they just set the idle higher than normal.
Northern California
TLCA/PMC Member
Old 12-03-08, 01:07 PM   #5 (permalink)
Can someone tell me why this (idle up) is needed to run the A/C?
89 FJ62
Bryan062087 is offline   Reply With Quote
Old 12-03-08, 04:12 PM   #6 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
I believe it's to get the AC compressor running at the right RPM for maximum cooling.
Anyone have a picture or the part number of the AC solenoid?
1987 FJ60 - MoonShine - H55f, 2-low, SOA, 62+AAL fronts w/ Ironman rears, 36's, FF w/ 4.11's, Round Eyes, KMR's Tailgate Hatch, desmog + headers, Storage / Sleeping system, etc. -- DD w/236k
Waiting to be installed:
SROR front bumper, York 210 OBA, shocks, lots of little things....
ΦΚΤ - Fall 06
Originally Posted by Woody
I'm done - thread closed, you are banned.
GLTHFJ60 is offline   Reply With Quote
Old 12-03-08, 05:04 PM   #7 (permalink)
humper99's Avatar
It's not needed to run the A/C, but rather to keep the engine from stalling when the compressor kicks on and puts a load on the idling engine.
'87 FJ60 rust free & stock
humper99 is offline   Reply With Quote
Old 12-03-08, 07:25 PM   #8 (permalink)
hank14's Avatar
TLCA# 17839
The compressor works (cools) better at 900-1000 rpms (the idle up setting) than at the 600 rpm regular idle setting.
Scott
Granbury, TX
1987 Beige FJ60.
Seat bottom foam for sale:
http://forum.ih8mud.com/sale-parts/2...ml#post4485578
hank14 is offline   Reply With Quote
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
