10-22-08, 06:45 PM
My 60 just died, fj60 350tbi
SO HELLO ALL,
it has been for ever for me since i been on here, i checked into my new seabee battalion and been busy as shit, but i have been daily driving my 60 until it just died, no warning or anything.
so this is what i have tried so far, not much at all, actually pretty much nothing, hahahhah. i pulled a plug wire and put a plug in and i got spark, so my thoughts about a coil or something are out.
i have a 88 350 tbi and not sure the best place to start in the fuel side, i mean i just dont want to start buying crap and hoping, so i asking what is your guys experience in this and what helped and did not.
thanks in advance
chappy
- Iam home now from the SUCK !!!!!!!
VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!!
- RUBITHON 2008 TESTED
GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7..
10-22-08, 06:54 PM
Swap out fuel filter and see what happens. Turn on key and make sure your electronic fuel pump is working.
1986 FJ60
5.7 Vortec
10-22-08, 07:06 PM
sorry i forgot to mention, i did swap the filter out,
i have not swaped the pump because i have to drain 25 gallons of fuel, should i be able to hear the pump running?
10-22-08, 07:21 PM
Yes... when you first turn on the key you should hear the pump run for about 2 sec (key on but not start).
Is the truck "stone dead" turn over but no attempt to start or run.? Obvious guess is the fuel pump. You could slightly loosen the fuel connection at the throttle body and turn the key on for a sec or two and see if you have gas at the throttle body. No ECM codes, or other issues?
1986 FJ60
5.7 Vortec
10-22-08, 07:22 PM
Yes you should be able to hear the pump running. You added an in tank fuel pump? Most folks use a frame mount fuel pump. If you don't have fuel I'd start with the pump and the EFI relay. TBIs usually will run without all of the sensors functioning, just not well.
Does it start at all or just die?
I chased and chased a problem in my TBI 350 60, in the end it was a temperature sensor. I couldn't get it to throw a code. After 3 weeks of barely running it finally threw a code. Basically the sensor was telling the engine that even it was the middle of summer it was ice cold so it was flooding.
Did you read the codes yet?
Eric V. TLCA 7328
99 UZJ100 "Barnicle Edition" Vorfab front bumper and sliders, MHHS diff drop, ARB front locker, 4x4 labs rear bumper with custom designed swingouts, OME springs/shocks/torsion bars
FJ68 PROJECT LEGO 60body/80chassis
Wagon Parts FS http://forum.ih8mud.com/sale-parts/2...ml#post3693029
ADIDALC "real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
10-22-08, 08:53 PM
Originally Posted by elbert
yes... When you first turn on the key you should hear the pump run for about 2 sec (key on but not start).
Is the truck "stone dead" turn over but no attempt to start or run.? Obvious guess is the fuel pump. You could slightly loosen the fuel connection at the throttle body and turn the key on for a sec or two and see if you have gas at the throttle body. No ecm codes, or other issues?
The truck turns over but does not start.
Originally Posted by ginericlc
yes you should be able to hear the pump running. You added an in tank fuel pump? Most folks use a frame mount fuel pump. If you don't have fuel i'd start with the pump and the efi relay. Tbis usually will run without all of the sensors functioning, just not well.
There might be a outside tank mounted pump, but where ever it is it is on the top side of the fuel tank. The tank is from a 96 chevy van, so not sure what i am in for.
Does not start at all.
I chased and chased a problem in my tbi 350 60, in the end it was a temperature sensor. I couldn't get it to throw a code. After 3 weeks of barely running it finally threw a code. Basically the sensor was telling the engine that even it was the middle of summer it was ice cold so it was flooding.
no codes read, i have o code reader here, i am in ventura, ca area if anyone is not busy this weekend. Hint hint. Lololo
thanks again guys and gals
10-22-08, 09:00 PM
I sent you a PM
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
10-22-08, 09:17 PM
got the pm
10-22-08, 09:20 PM
Beagles Rule!
The FJ60 in the stock form did not have the fuel pump in the tank.
10-22-08, 09:56 PM
#10 (permalink)
He has a 350 so nothing is really stock.
Chappy==Good luck, my guess is that you'll beat this. Sorry I know nothing about Chevy EFI.
Andrew
10-22-08, 10:02 PM
#11 (permalink)
Beagles Rule!
I was checking his 350 out when he came by the shop. I just can't imagine anybody pulling the tank and installing a fuel pump in it and then reinstalling it. I would hate to think of him pulling it just to find out no pump is in it.
10-22-08, 10:10 PM
#12 (permalink)
That would be ironic for sure. Maybe they installed an FJ62 tank with a pump?
Andrew
10-22-08, 10:19 PM
#13 (permalink)
Beagles Rule!
10-22-08, 10:19 PM
#14 (permalink)
this is intresting for sure, the PO did put a 96 chevy van fuel tank in it and i hope i can just rotate the tank down and see the pump there, but luck would most likely say it is in the tank. hahaha no worries all is good, the PO also threw in a extra fuel pump too. so we will see soon enough.
10-23-08, 11:24 AM
#15 (permalink)
You should have a couple of relays for your system. The TBI wiring harness uses a special relay for the fuel pump. You should be able to hear the pump when you turn on the key. If you can't hear it, you need to make sure that your switched power to the relay is working. So I would start there. Check for fuel pump relay, power at the pump, if those check out but no pump action, it probably died. With the key on, you should be able to use a circuit tester at the injectors, each injector has two wires, there is a common color to both, this is hot. The different colored wires are actually grounds and go directly to the ECM that pulses them by grounding them. Check that. If there is no power there, you need to do some digging and find out how the install was done, but if it was done properly, there should be a relay that powers this circuit and it would likely be an after market job. Again, you are useing switched power to make the relay work, so check for a live wire at the relay with the key on (obviously this wire will be linked to a fuse in the rig, so start there.) You should have switched power, a ground, a lead to the battery and and one that energizes when switched power is applied. All these can be checked with a simple circuit tester, and I would bet anything you will find your problem.
So to recap, check fuses, check for switched power at the relays, check for power at each injector with key on. Listen for fuel pump operation and you should be able to narrow it down pretty fast.
A daily driver 1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater rear w/Elocker, 4.56 gears, SOA, four-wheel disk brakes, 35" BFGs, 360,000 happy miles and still going due to a wicked case of wander lust.
10-23-08, 05:13 PM
#16 (permalink)
and i have a awesome tester, time to break it out....
i really forgot to start at the basics, a fuse, hmmmmm..... lets hope
10-23-08, 05:16 PM
#17 (permalink)
ok Fuel pump in tank....then if so, you will not hear the fuel pump run at least for the most part I assume you can't. I was thinking you had an external fuel pump. Seomone may have setup a tank like the stock GM setup...ie in-tank fuel pump. I see now where you say it has a GM van tank.
I'm guessing you have no gas at the throttle body ( did you do the simple test I suggested)?
TBI...you can read the ECM codes with a paper clip. You ground the ALDL connector and the check engine light will flash. First flash if single stands for one.... next if quick flashes...you count them to equal whatever value... ie.. one slow flash = one...then three quick flahes = 3.... 1&3 =13. Code readers are cheap though...
Gonna suck if you have to drain the gas...
I would attempt to determine the hot wire that feeds the fuel pump. When key on...it should be "hot"... it its hot...then I would say you have a bad fuel pump. Or you need to do a simple test to physcially see if gas at throttle body.
1986 FJ60
5.7 Vortec
10-23-08, 06:48 PM
#18 (permalink)
now what would happen if i just dump gas down into the throttle body? i ask becaus i honestly dont know much about TBI systems.?
10-23-08, 06:55 PM
#19 (permalink)
Originally Posted by chappysfj40
now what would happen if i just dump gas down into the throttle body? i ask because i honestly dont know much about TBI systems.?
I dont know crap about TBI myself Brother but try it what the hell if it fires then thats the problem. Goos Luck sorry we wont get to see you and the Family at SnT
10-23-08, 07:31 PM
#20 (permalink)
update update update......
good news is i finially got the wife to help me with the fuel pump to see if i could hear it, so the pump is turning on, so the next step is to actually pull the plugs, i check spark by putting another plug in a wire i pulled and it sparked, so i really need to look at the actual plugs now, tried to pore gas in the TBI and got nothing,,, so there is where i am at. yes super slow i am, lolololoo
10-23-08, 09:40 PM
#21 (permalink)
Do you have a check engine light? If so, and it is on. Use a jumper to read the codes.
Eric V. TLCA 7328
10-23-08, 09:44 PM
#22 (permalink)
yes yes , i have the check engine light, hower ever i can not remember what place to put the paper clip, i mean what pins to jump.
10-24-08, 06:33 AM
#23 (permalink)
GM 1983-1995 OBD1 Decoder
terminal A&B.... make a u shape out of the paper clip,
1986 FJ60
5.7 Vortec
10-24-08, 10:16 AM
#24 (permalink)
Test for power at the injectors with the key on. Simple test, as I said, they each have a dedicated ground that goes straight to the ECM and they each have a hot wire which, if you follow them back into the wiring harness, actually join together. They then SHOULD be energized by a relay.
10-24-08, 07:43 PM
#25 (permalink)
riht on guys awesome info... also got a scanner today so i will see what that says this weekend. update as i get shit done
thanks again
10-24-08, 08:24 PM
#26 (permalink)
Don't you need one of the "noid" testers for the ingectors? For some reason I remember that name...(small sensor that plugs into the injector harness that lights up when the injector is fired.
1986 FJ60
5.7 Vortec
10-24-08, 10:26 PM
#27 (permalink)
i got a scanner from one of the guys at work, we will see
10-25-08, 06:37 PM
#28 (permalink)
damn damn..... damn..... so i did the check with the paper clip and i got the standard OK code, one long and 2 short. so i tried to start for the the hell of it and now my starter is giving me greif, all it does it click click click, damn damn damn
10-25-08, 07:27 PM
#29 (permalink)
Beagles Rule!
dead battery.
10-25-08, 07:41 PM
#30 (permalink)
well i pulled a retard mistake, i forgot witch battery runs the truck. lolooolo so needless to say i had a dead battery, charging now. i did try to start and it popped off but then nothing. crazy crazy.
