09-08-08, 06:50 AM
FJ60 - Repairs After Sitting Too Long
I have an '85 FJ60 that I unfortunately let sit in the yard for too long without good use (approx. 1 year). It will crank after a jump but won't hold a charge after running for about 20 minutes. I plan to take it to the shop to get checked out. In addition to oil/filter change and checking the alternator and determining why it won't hold a charge, what items would you have the mechanic check out, replace etc. as a result of sitting this long? Thanks very much.
09-08-08, 10:36 AM
I bet it's just a battery
It's either the battery or the alternator. Or maybe just corroded connections. If you can get it to a Checker or AutoZone or Napa, they will typically test the electrical system for free. that will tell you if it's the alternator or battery (or both).
Check the battery for basic maint. - like, make sure it has water in it.
Other stuff: all the fluids- old brake fluid can get kinda corrosive - replace the brake fluid and Clutch fluid. I'd also change the driveline fluids (diffs, tranny, x-fer), and drain/refill the cooling system.
HTH
1987 FJ60, SROR Sliders, lockers, 4.11s, 33s and other stuff
1977 FJ40, mostly stock.
Reason: added more stuff.
09-08-08, 11:10 AM
Rum Runnin'
Also check to make sure that the grounds are operating correctly - block to frame, etc.
1987 FJ60 - MoonShine - H55f, 2-low, SOA, 62+AAL fronts w/ Ironman rears, 36's, FF w/ 4.11's, Round Eyes, KMR's Tailgate Hatch, desmog + headers, Storage / Sleeping system, etc. -- DD w/236k
Waiting to be installed:
SROR front bumper, York 210 OBA, shocks, lots of little things....
ΦΚΤ - Fall 06
Originally Posted by Woody
I'm done - thread closed, you are banned.
09-08-08, 04:18 PM
Beagles Rule!
You might want to add some fresh fuel to the tank and maybe replace the fuel filter.
09-08-08, 06:41 PM
Thanks guys. Any other thoughts are certainly welcome.
09-08-08, 07:16 PM
battery is probably toast after sitting that long...
92 FJ80, 120K, Duals w/ FlowMaster catback exhaust, 31" Tires;
87 FJ60, 101K, Not Quite Stock, Just Broken In; 87 FJ60, 238K, Stock, Project Truck (FOR SALE); 88 Chev K1500, 138K, 4x4, 350, Headers, duals w Flowmasters, Rear Locked, 33" tires.
09-09-08, 10:20 AM
2X on the dead battery, they don't do well when discharged and stored for long time. But check the conections and others that's free.
09-20-08, 01:17 AM
IH8Mud.Commando!
X2 on that and the battery is the best place to start.
ingen konflikt, ingen glädje
