Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 60-Series Wagons
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
Thread Tools Display Modes
Old 09-02-08, 05:53 AM   #1
FJ60LG-K4
smells like gas in my rad :(
There s also brown(oil)
could it just be that it ran real rich or am i looking @ another pricier issue.
Should I flush and see what happens,drive around with water for a bit?
thanks
MA
FJ60LG-K4 is offline   Reply With Quote
Old 09-02-08, 07:25 AM   #2
Wile E Coyote
Lifer
Wile E Coyote's Avatar
Garage
I'd look for other signs that the head gasket took a dump, or even the oil cooler is bad.
"The grass is always greener on the other side when you're not the one mowing it"
Toys:
'90 FJ 62
'03 Cannondale Speed 440 // '04 Yamaha Warrior 350 // '05 Suzuki z400 // '05 KTM Mini Adventure 50
2f engine manual and 84-90 Chassis and Body manual in pdf:
http://hugh4prez.nate-online.com/Cru...416%20Manuals/
Wile E Coyote is offline   Reply With Quote
Sponsor 09-02-08, 07:45 AM
Sponsored Link
advertisement
Old 09-02-08, 07:45 AM   #3
PhilC64
X2^ Chocolate Milk looking anti-freeze means oil got in there somehow. Do a compression check first and see where it leads you.
PhilC64 is offline   Reply With Quote
Old 09-02-08, 03:23 PM   #4
Matt60
KiSS of Death
Matt60's Avatar
the oil on the stick is brown? radiator smells like gas. does it shoot water out the filler neck when the cap is off and running?
pull the head-
oh and good luck
matt
OzarkMountainCruisers
Matt60 is offline   Reply With Quote
Old 09-02-08, 08:21 PM   #5
sdbrassfield
sdbrassfield's Avatar
Oil Cooler x2...Bypass it temporarily
92 FJ80, 120K, Duals w/ FlowMaster catback exhaust, 31" Tires;
87 FJ60, 101K, Not Quite Stock, Just Broken In (sold);
87 FJ60, 238K, Stock, Project Truck;
09 Tacoma Pre-Runner
sdbrassfield is offline   Reply With Quote
Old 09-03-08, 03:58 PM   #6
wagon4wd
The fuel smell in the radiator concerns me and makes me think that it might be more than the oil cooler, and be more like a head gasket or cracked head. But certainly do the easy troubleshooting first.
wagon4wd is offline   Reply With Quote
Old 09-03-08, 06:16 PM   #7
cruiser88
10k Club
cruiser88's Avatar
I also think the fuel pump is leaking gas into the crankcase if it is not then your rig is running really rich. ...but yep its time to do a compression check.
NEW! Club sticker for sale. pm me for details!
MountaineerCruisers.net
Old 09-03-08, 09:07 PM   #8
mrlocksmith
mrlocksmith's Avatar
Although the gas smell in the Rad pretty much nails it, there is a kit you can buy from Napa to confirm the problem:
Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
Then you could do a "Leak Down" test, somewhat like a combustiuon test but gives you a much better picture of what is going on in the motor as you can monitor how much air pressure escapes from a cylinder and more importantly in your case... find out where the air goes... If you get bubbles in the rad as I suspect then you will have to address it.
http://www.carcraft.com/techarticles...ter/index.html
Mark
Mark Weiss Ham Radio Call Sign K7VQU
1985 FJ60 Nickname: "Leaky" Expedition Camping Rig Outfitted with H55F. ARB Bull Bar, Man-A-Fre 4+ Rear Bumper, Warn XD9000, OME Heavy Lift, 33" BFG AT's, 4.11's, Oasis2 RTT, Mean-Green Alt, Dual Batteries, Cargo Cabinets. http://web.mac.com/mrlocksmith
mrlocksmith is offline   Reply With Quote
Old 09-03-08, 10:23 PM   #9
wagon4wd
Duh, forgot some of these weren't injected and had a fuel pump attached to the block. Had that problem on an old cherokee a while back.
Like everyone else says, though, it's time for at least a compression check. While it's possible a few things could fail at the same time, it's a lot more likely that it's just one thing causing all the symptoms.
Old 09-13-08, 12:02 AM   #10
FJ60LG-K4
environment + procedure
Then you coul...... "Leak Down" .
How to do Cylinder Leak Down Testing- Car Craft Magazine
Mark
good one
do not have that tool NEED it
PRIOR to starting this project:
`search...read
` located some canisters. To bleed/clean the fj60(lot's of liters/gallons of pollute)
read /searched
Old 09-13-08, 12:14 AM   #11
FJ60LG-K4
running RICK it was. Carb ,air intake... everything THE smell from the exhaust
good thing
Compression
1 @125
2 @ 130
I stop compression testing. Get depressed quick
no matter,LC ran b4,senses got invovled oil,gaz,green or yellow red but it RAN
Really needed canisters to dump the oil,gaz,green or yellow red drainage
+++ decided to be a wire guy... groundin... to be followed
PS WOW thanks for the tips and postings! and PICS
Old 09-13-08, 12:32 AM   #12
FJ60LG-K4
pull the head-
oh and good luck
matt
oil inside engine, actually dipstick was pretty good,but PO could of changed it a month earlier
Didn't boil over No
I changed(garage) when I got certification done. Along with ALL fluids besides rad.
I ll double verfy if THEY did the job,paid cash to save 15% rear,transfer case,grease every greaseable'S.
Then I get more familliar with my FJ60
No Steam out of muffler
FJ60 2F I ll attempt pulling(heads+gaskets/boats) crammin(stuff),stompin(anyt'in),pushin(more)climbi n(higher) now to get it started! no more CLIKKs please
you mean
"Leak Down" test,
Mark[/QUOTE]
Old 09-13-08, 05:00 PM   #13
Bahndo111
Bahndo111's Avatar
Mark
[/QUOTE]
uh..... huh?
'94 fzj80- SOLD
'82 jetta diesel- POS- hit by retaining wall, going to junk yard soon -or- for sale **SOLD**
Bahndo111 is offline   Reply With Quote
Old 09-13-08, 05:51 PM   #14
RockDoc
Lifer
RockDoc's Avatar
I think Tntoyota/Hilux has a Canadian cousin.
[ ][ ]=TOYOTA=[ ][ ] - '89, rough and ready - Wobble Wagon Now with a 2FE that's been turd polished
[ ][ ]=TOYOTA=[ ][ ] - '90, no rust, in the wings
- '70, some assembly required, batteries not included - Spot
RockDoc is online now   Reply With Quote
Old 09-14-08, 08:31 AM
Sponsored Link
advertisement
Old 09-14-08, 08:31 AM   #15
Wile E Coyote
Lifer
Garage
FJ60LG-K4, slow down bud. We're losing you. Personally, I don't know whether you're asking for more help, or just sharing your inner dialog with us? Good luck with your project, either way.
Toys:
'90 FJ 62
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
