#2 | |
75-80 need to be machined .100 to make up for the larger CC and use .100 Gr8 washers under the head bolts |
KI6MIE
I don't really know the years, but any of the heads that came with the flat top pistons should work, so that's 81 and up.
Or you could mess with all that machine work as suggested by weak-link. Did you have an overheat? __________________ Andrew 1971 FJ-40 Rubicon tested 1976 FJ40 RIP 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now. 1997 FZJ-80 Factory sub-tank, and other tricks |
Yeah - long story. Smog pump locked up and when I opened it up - there was not much left inside except small bearings that were loose. Shortly after started overheating. Was losing water but nothing showed up outside the engine. Ran a compression check and #1 & 2 cylinders were about 20 pounds low. Water was lightly spraying out of the #2 cylinder. #2 had a crack in it that must have been leaking.
__________________ Dave Stinchcomb Green Country Cruisers 1981 FJ60 1976 FJ40 1966 FJ40 |
I would find one 81 and up to keep the lighter valve train, and the ease of use, even if you skin the other head you will loose a little compression, So pick one up and have it rebuilt, I think they have cost me less that a new toyota gasket set to be machined, Larry
__________________ Larry Brewster, TLCA 7165, Billings, MT |
Search 1st, THEN ASK
61040
Do a Search, the topic of head interghancability was covered in heavy detail several months back. __________________ 72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener. 83' FJ60 - Mint Condition which is now FOR SALE 07' FJC - Atrac Hack - DD 03' Matrix Xrs - It's her's 08' Tundra, 4.7 2WD - Company Truck |
Credit Cards | Bleach Music | Remortgages | Debt Consolidation | UK Hotels |
