Old 07-09-08, 12:25 PM   #1
hammered's Avatar
birf removal help needed
I am trying to get a birf off a 60 axle.
Can't seem to get it.
Anyone help me with some tips.
or walk me through it
1 clip slid back but can't get any further
Steve
hammered is offline   Reply With Quote
Old 07-09-08, 12:31 PM   #2
Steve
It sounds like you have the shaft out and you're trying to remove the Birfield joint, is that right? If so, I know of no other way than to hold the shaft in one hand using your other hand to beat the hell out of the joint with a big hammer. Sounds Cro-Magnon, but it worked for me, the inner clip eventually gives up. Maybe somebody more enlightened than myself knows a better way.
1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going.
lehiguy is offline   Reply With Quote
Old 07-09-08, 12:33 PM   #3
brew8's Avatar
TLCA# 7165
Get a pipe longer that the axle and stuff a rag in one end so you don't hurt the splines on the axle the put the axle in the other end, making sure the birf is wider that the pipe, then wack it on the floor of the garage till the birf lets go, cheers, Larry
Larry Brewster, TLCA 7165, Billings, MT
brew8 is offline   Reply With Quote
Old 07-09-08, 02:26 PM   #4
hammered's Avatar
pipe worx good!
Now do I have to put a new inner clip on?
It blew apart in 2 pieces.
Thanks for the pipe tip.
Steve
Old 07-09-08, 03:05 PM   #5
TLCA# 11554
pipe worx good!
Steve
Don't reuse the one clip that didn't break. They are both less than $2 ea. from Toyota.
John
FJx3
75 FJ40 purchased new basically stock
85 FJ60 complete OME 33x10.50 muds 260K still daily driver
89 FJ62 just turn 100K completely stock
John McVicker is offline   Reply With Quote
Old 07-09-08, 03:21 PM   #6
Suffering from V8 Madness
djawahir's Avatar
Don't reuse the clips. Just get some new ones. I used a 3 foot long 1.5" diameter PVC pipe for mine. It only cost me $5 at the store and it's soft enough to not ruin the birf.
I just got through this myself...all I can say is GREASY!
I have the uncanny ability to make things harder than they really are.
V8 swap progress: 5.3L Vortec mounted. Plumbing lines!
djawahir is offline   Reply With Quote
Old 07-09-08, 03:29 PM   #7
John
Just weld a small tack on the splines where the shaft goes into the side gears. I tried to use new clips, gave up and broke out the welder.
Old 07-09-08, 05:07 PM   #8
Fiona is her name!
CruisinFJ60's Avatar
TLCA# 16781
"martack"
http://forum.ih8mud.com/60-series-wa...7-martack.html
84 FJ60, OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap
Originally Posted by whodat View Post
lol, carbs...lol
even us cavemen have switched to EFI.
95 Pontiac Trans Am !cats, flowmaster exhaust, and lots of fun.
91 Honda Civic with a B18A1 Integra LS motor, soon to be JDM B20B CR-V motor.
My MySpace----> myspace.com/blitzerkreig1603
Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
NObama '08
CruisinFJ60 is offline   Reply With Quote
Loans | Buy Anything On eBay | Loans | Refinance | Compare
