Old 07-09-08, 01:01 AM   #1
hy steer
Hey is there any problem using the stock tie rods and pitman arm with a high steer set up?
If you can't, whats a good set up?
Thanks.
Kurtis
Kurtis is offline   Reply With Quote
Old 07-09-08, 01:33 AM   #2
weak-link's Avatar
Most hy steer kits come with a new tie rod and drag link + rod ends. the reason they come with new rod ends is because they up grade to FJ80 rod ends. FJ80 rod ends are much cheaper to to replace and beefier.
If you want to go cheap and mod the stuff you already have give W a call Our Services he heats and bends your arms for soa. I had him do a set on my FJ40 years ago and have never had a problem.
If you want a bolt on kit that takes all the guess work out and is top notch call Marlin Marlin Crawler: Selling HySteer™ Kits since 1997!
A plus with Marlins kit is you get a new pitman arm that's about an inch taller then stock(helps to keep the springs from hitting the draglink)
brakes and steering is the last place you want to cut corners.
www.4x4Him.com
Pit Bull Rescue Central
http://www.pbrc.net/
weak-link is offline   Reply With Quote
Old 07-09-08, 06:56 PM   #3
hy steer
cutting corners is never an option I was just wondering as my rods and ends are still tight, I saw you can get just the arms and was wondering if they would bolt up? Sounds like getting the whole kit is the easiest though which sounds good to me.
Old 07-09-08, 08:55 PM   #4
Kavik's Avatar
Done and done.
85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs
Copper State Cruisers #71
KavikOffRoad.com
60 Series porn
Kavik is offline   Reply With Quote
Old 07-09-08, 10:05 PM   #5
I used ALL PRO and have had no problems, I think it may save you 50 bucks or so as well.
1987-fJ60,SOA,longfields,beilstein,4.88 Sierra,Allpro hy-steer,ARB-bar & locker,35BFG
MTN.GOAT is offline   Reply With Quote
Old 07-09-08, 10:54 PM   #6
In what way are the 80 ends superior to 60 ends. I've seen far more failures in 80 ends because of the notched out piece by the taper. They are both 23 mm
thread. The taper is a bit larger but it seems to be negated by the weak point before the ball joint.
lcwizard is offline   Reply With Quote
Old 07-09-08, 11:28 PM   #7
weak-link's Avatar
If you think the 60 ends are better make your own kit, have it tested and sell them yourself. Because you obviously know more then Jon Bundrant, Marlin Czajkowski, Brian ellinger(sp), Bud Rosenberger, etc...
www.4x4Him.com
Old 07-10-08, 12:21 AM   #8
freds40's Avatar
Yeah you wouldn't want to cut those corners huh.
BTW, did you get brake parts yet?
freds40 is online now   Reply With Quote
Bad Credit Loan | Download movies | Gnarls Barkley | Loans | Home Loan
