Old 07-08-08, 05:28 PM   #1
Suffering from V8 Madness
djawahir's Avatar
2 Rotor bolts Torque spec - front axle
Hey guys, I'm replacing my rotors and there are a couple of 14mm bolts on the inside of the disc that hold the disc to the hub. Does anyone know what the torque specs are for those 2 bolts on the inside of the disc rotor on the front axle???
I've looked in the FSM and the Haynes manual, and neither one mentions the torque value. I'm not sure if it's because these 2 bolts are unnecessary or they just forgot...
I have the uncanny ability to make things harder than they really are.
V8 swap progress: 5.3L Vortec mounted. Plumbing lines!
djawahir is offline   Reply With Quote
Old 07-09-08, 10:39 AM   #2
The torque value is as follows:
That's tight enough.
1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going.
lehiguy is offline   Reply With Quote
Old 07-09-08, 10:57 AM   #3
TLCA# 11554
34 ft. lbs...............If it's the 2 bolts I am thinking of. The 2 bolts that hold the disk on and that you come at from the inside. That make any sense ??
John
FJx3
75 FJ40 purchased new basically stock
85 FJ60 complete OME 33x10.50 muds 260K still daily driver
89 FJ62 just turn 100K completely stock
John McVicker is online now   Reply With Quote
Old 07-09-08, 03:26 PM   #4
djawahir's Avatar
Yep, those are the ones John...
I tightened mine to 90 N-m.
Lehiguy, "That's tight enough" always turns into "Hmm, maybe I should tighten just a tiny bit more..." and then bolts strip and bolt heads start flying off, helicoil needs to be used, bolt extraction needs to happen etc...
If I was only smart enough to know when 'tight enough' was tight enough, I wouldn't have this problem...
Old 07-09-08, 05:04 PM   #5
Fiona is her name!
CruisinFJ60's Avatar
TLCA# 16781
an impact gun...
84 FJ60, OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap
Originally Posted by whodat View Post
lol, carbs...lol
even us cavemen have switched to EFI.
95 Pontiac Trans Am !cats, flowmaster exhaust, and lots of fun.
91 Honda Civic with a B18A1 Integra LS motor, soon to be JDM B20B CR-V motor.
My MySpace----> myspace.com/blitzerkreig1603
Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
NObama '08
CruisinFJ60 is offline   Reply With Quote
Old 07-09-08, 05:09 PM   #6
cruiser88's Avatar
TLCA# 17319
BE VERY SURE TO USE LOCK WASHERS and locktight . Those suckers WILL back out
Old 07-09-08, 05:09 PM   #7
cruiser88's Avatar
TLCA# 17319
Originally Posted by CruisinFJ60 View Post
an impact gun...
x2....tight as you can and one more turn as my dad would say
WoW Gold | Cheap Magazine Subscriptions | Myspace Layouts | Loans | Web Advertising
