Old 01-14-09, 06:56 PM   #151 (permalink)
orangefj45's Avatar
looking good joey!
you can get the cover gaskets seperate at the dealer; they're cheap. the speedo deal means somebody bolted the rear extension housing on wrong. remove the stake nut on the rear flange, pull the bolts that hold the housing in place, rotate the housing to the proper orientation and re-install.
i would recommend ordering a new ext hsng gasket and a new stake nut from the dealer as well as these items should be replaced when you rotate the housing.
you might also want to remove the speedo gear from the housing so it does'nt get chipped during removal/install.
hth
georg
ps: which 60 did the combo come out of?
TLCA and PMC member
looking for Advance Adapters or marlin crawler parts? send me a pm!
bill dorry style ps brackets for sale:
http://forum.ih8mud.com/merchandise-...ml#post4481037
orangefj45 is offline   Reply With Quote
Old 01-14-09, 06:56 PM   #152 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Damn I love white 60's.
Those springs look perfect for a SOA conversion
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is offline   Reply With Quote
Old 01-14-09, 07:12 PM   #153 (permalink)
NLXTACY's Avatar
TLCA# 19015
Originally Posted by orangefj45 View Post
looking good joey!
hth
georg
Thanks for the info. I actually ordered a whole gasket kit just in case because not sure what else was missing.
And this is the combo from THAT 60. Yes the one you are thinking of over at Mark's. So its definitely been rebuilt but who knows...
ふざけんなよ!
Old 01-14-09, 07:15 PM   #154 (permalink)
NLXTACY's Avatar
TLCA# 19015
They do but i've decided against doing a SOA. So maybe there IS something on my truck worth selling
ふざけんなよ!
Old 01-14-09, 07:30 PM   #155 (permalink)
orangefj45's Avatar
i can attest to that trans and t-case working very well. we drove the truck home months ago, about 100 miles with no hick-ups or other issues/noises. did'nt put any miles on it after that.
nice score, should work out well.
TLCA and PMC member
Old 02-01-09, 10:35 PM   #156 (permalink)
NLXTACY's Avatar
TLCA# 19015
Just spent some time over at SPIKE STRIP's place trying to get my truck to run a little better. Initially I figured I had an exhaust leak so I went ahead and ordered a REMFLEX exhaust gasket:
TOYOTA Header/Exhaust Manifold Gasket
What was cool is when you order the gasket you ALSO get the EGR tube gasket THAT ALWAYS leaks AND the heat riser gasket which was way cool.
Now SPIKE rolled under and started spraying down the exhaust bolts/nuts with AeroKroil. While under there he found that the EGR tube was MISSING the two bolts!!! I was getting exhaust pouring out of this and assumed it was a bad gasket. Lucky for me SPIKE had two spare bolts. Problem solved there.
Meanwhile I took off the air cleaner and valve cover. We adjusted the valves and found 5 out of spec and 1 way out of spec. The head valley looked very clean as did the inside of the valve cover. Did not look like a engine that has over 252k miles.
At this time we hooked up a vacuum gauge and then started to adjust the carb accordingly now that the EGR tube has been fixed and the valves were adjusted. We get the carb dialed in again and it runs a bit smoother and idles nicer. As we tried adjusting the idle mixture we found we just could NOT get more than 10" at idle. So as SPIKE and I were sitting there trying to decide what the issue was, we pretty decided that it must be an intake leak.
Well I found this page here on mud:
Vacuum 101 - Land Cruiser Tech from IH8MUD.com
This confirmed what we already assumed, I have an intake leak for sure. So perhaps over the next week we'll take off the manifold and check for straightness and perhaps having it surfaced. We're planning on a 2 day job but I'm hopeful it can be knocked out in one day.
ふざけんなよ!
Old 02-01-09, 10:42 PM   #157 (permalink)
NocalFJ60's Avatar
Check in front of the carb on the intake manifold and find where three vacuum hoses connect. First unplug the three lines and cap the three ports on the the intake manifold and see if the idle changes. The plastic piece that screws into the manifold was leaking some on mine before I put in a new one. You can unscrew it and check it with a hand pump.
Have you done a compression test?
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 02-01-09, 10:48 PM   #158 (permalink)
NLXTACY's Avatar
TLCA# 19015
Nice, I will check that out tomorrow. I have not checked compression since Georg checked it initially. I may do so again just in case.
ふざけんなよ!
Old 02-02-09, 06:55 AM   #159 (permalink)
orangefj45's Avatar
when you guys rebuilt the carb at marks', did you look down into the intake to see if it was cracked?! iirc, the carb cooling fan was not working when the 60 got to my shop which may have caused the intake to crack. not an uncommon problem.
also, grab some carb clean and spray a little on all the vacuum fittings and connections as well as along the intake manifold. if the idle changes at any point, you found your leak..........
TLCA and PMC member
Old 02-02-09, 08:22 AM   #160 (permalink)
NLXTACY's Avatar
TLCA# 19015
You know I didn't and I really should have with all that I have been reading. We'll know soon enough. The carb clean tricked I tried a few weeks ago and it definitely changed my idle which convinced me at the time that I had a leak somewhere. I just assumed it was the intake gasket.
ふざけんなよ!
Old 02-02-09, 11:03 AM   #161 (permalink)
Rando-kurūzā
Spike Strip's Avatar
TLCA# 17876
It wasn't the EGR tube missing the nuts - it was the exhaust down pipe where it bolts to the ex manifold, and all 3 were missing - we put 'em on and it quieted down a bit, but still some leaks somewhere....
Oh, well, inevitable will be the manifold will have to be disconnected from the truck --
It's gonna rain middle of the week, Joey, so maybe it might have to wait... ?
5/85 FJ60 -- A whole lotta crap and $$ that took 2 years of my life and pissed off the
6-86 FJ60 - current project - gonna stay stock.
Support MUD Vendors: www.marksoffroad.net
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 02-02-09, 10:45 PM   #162 (permalink)
orangefj45's Avatar
wow, i tightened them up when the 60 was at my shop but then again, that was 6 months ago........
TLCA and PMC member
Old 02-02-09, 10:56 PM   #163 (permalink)
Rando-kurūzā
TLCA# 17876
I think he had some exhaust work, since then...
Old 02-03-09, 12:05 AM   #164 (permalink)
fjsixtytwo's Avatar
Originally Posted by NLXTACY View Post
Well I figured I would tell a funny story about my adventures picking up this vehicle and maybe someone can laugh at my pain. BTW I am normally in the 80 section but we needed a second vehicle so I picked up this gem:
http://forum.ih8mud.com/vehicles-tra...00-00-obo.html
Left Thursday morning from LAX to Sacramento to pick up the truck from Zach (Flight: $140; Running total: $140). His 18 year old sister and her BF pick me up. We almost run over a pedestrian. Sister starts the conversation with, "BTW, Zach said you need to buy a new battery because he couldn't get one". So we stop off at Autozone (Battery: $75.00; Running total: $215).
It takes us 2 hours and 15 minutes to get where the truck is first because I didn't think anyplace had worse traffic than LA, I was wrong. Then where we are going is waaaaay out in BFE. I was waiting for the banjo to start playing. I was starting to feel like I was in a horror movie. You know the one where the star crossed lovers pick up a poor sap trying to buy a truck and they take him out in the middle of no-where and precede to torture and ultimately dismember said poor sap.
So we get there, I still have my arms and legs. We are meeting his mom at her work. So I check out the truck, looks the same as the pics. I check out everything. Checked the fluids, added one gallon of water to the radiator. Checked p/s fluid, whoops! No p/s belt. Ooookaay.
I handed his mom the cash, she fills out all the paperwork. All is well the truck starts fine. It feels JUST like my old FJ40. Nite and day between the LX450 and this. But I like it. They hook me up with a bucket of ice and cold water. Cuz the A/C no workie.
I look down, hmmm, fuel tank is empty. I guess I'm going to the gas station. (Gas: $78.00; Running total: $293)
So I start on the road...windows rolled down. Figured I would start taking notes on little things that I know I will need to fix/change as I notice them. Visor, fix. Seat, replace. Headliner, clean. Ashtray, dump out the packed tight stash of cigarette butts. Ugh.
I've taken enough notes for now. Time for some tunes. Hmm, the radio isn't in its cubby. Must be in the glove compartment. Nope. Maybe in the center console. Nope. Time to pull over and check the back. I pull over and check the back. Awesome...I see the 6x9 holes, but no 6x9 speakers. Hmm, I see wiring for bass tube but no bass tube. Hmm, I see wiring for amp, but no amp. Then I look closer at the radio. The wires have been cut. All of them.
I drive back to Zach's mom's work and ask if MAYBE the radio equipment has been removed and gingerly packed for me just in case someone were to steal it all. Nope, turns out from the time it was at his mom's house to the time I picked it up (less than 24 hours), some knuckle dragger decided he wanted the stereo stuff more than I did. (I'm not going to add the cost of the stereo yet because I have no idea what its going to cost me to replace). At this point I am thinking about walking away from the deal. But I decided you know what, Zach will make good on it and we'll just work it out somehow. Besides, his mom gave all the cash to his sister and she took off with her BF. My cash is long gone by now.
Oh well, on the road again.
So I start driving. I am now at mile 111 WITHOUT a radio!!! and I'm falling asleep. Ok time for food. I stop off in Merced (armpit of California) at the Carl's Jr. on V Street. Judging by the copious amounts of tweakers I'm going to guess that "V" stands for "Venereal".
Food in stomach and I'm feeling awake again. Start truck, back up, break for tweaker, put in into first. Hmm, that's strange, the shifter won't go into 1st. Maybe 2nd? Nope. Reverse? Yup. I can drive home in reverse for the next, oh I don't know, 309 FUTHER MUCKING MILES!!!!
I try everything. Finally I turn off the truck and jam the gear into first. I push in the clutch and as I start it, the truck's starter is lurching the truck forward. Clutch is totally toast. I start pushing the truck AFTER I manage to get the thing out of gear, which took a good 20 mins. Which turns out to be pretty nerve racking when you are stuck in the middle of the intersection where the off ramp to the 99 freeway is. Two guys take pity of me and help push me to the Jack in the Box.
From here I call my wife, Zach, Zach's mom and of course...good ole AAA.
Then my cell phone battery dies. Dead. Nothing.
So AT LEAST everyone knows I'm stuck and roughly where I am. By the time AAA gets there with a flatbed its now 8:45PM. I had been waiting for him for over 2.5 hours! During this time I went walking for a few blocks to learn that the wonderful city of Merced has done me the favor of ridding itself of payphones. Awesome.
Drop off truck at the Toyota Stealership. I ask the tow truck driver where the nearest train station is. "Oh its about 3 miles South on 16". Ok, so I ask to see if MAYBE he would be driving that way and can take pity. Nope, no such luck. So I hoof it. AT night. In Merced. The tweaker capitol of California. I make it to the train station. Next train is at midnight. Screw that noise. I walk to Greyhound, the doors are locked. I'm screwed. I look out back and I see people so I go back there. I talk to the bus driver in my lousy attempt at sounding like I know Spanish. Sure he can take me, that'll be $40. (Bus: $40.00; Running total: $333).
I think I should have asked if there was going to be 6 stops with half an hour wait time at each stop. Man I'm dumb. I'll spare you the insights I gained while driving in a Greyhound bus. Needless to say we arrive in Downtown Los Angeles at 4:30. I walk outside and grab a taxi. I get home at 5:05AM. (Taxi: $80.00; Running total: $413). Shower and I cry myself to sleep by 6:00AM. Only to wake up at 7AM because I have to help the MRS. prepare the food for the 4th party we are going to.
So. I am out $1300 for the truck. I am out the truck. I am out $413. I will have to pay at least $300 for a piece of junk radio, amp, speakers to replace the probably $5-600 system he had in there. And I will be out the $800 the stealership will want to do the clutch job.
Needless to say I am pissed, I am angry. But I'm not pissed at Zach, just pissed at the lousy situation I am in right now. Sooo, I guess now I am hoping for suggestions. Somehow I need to get that truck here to LA, with or without a working clutch.
Whoa, what a story. I hope it all works out for you.
Think you prolly need a few good beers!
fjsixtytwo is offline   Reply With Quote
Old 02-05-09, 11:22 AM   #165 (permalink)
NLXTACY's Avatar
TLCA# 19015
Just had my truck smogged. Better luck next time I'm sure:
http://forum.ih8mud.com/60-series-wa...ml#post4129621
ふざけんなよ!
Old 02-05-09, 12:18 PM   #166 (permalink)
It's funny to me because I had almost the same scenerio when I picked up my 85 8hrs away from LA and they whole, no radio, car broke down on the way back, towtruck and all. Now it is sitting on the driveway and everyday for the past 3 weeks, I go outside look at it and then go back inside thinking where to start first. I now know more of the car without touching it than touching it, jeje
Good luck!!
eraldovallejo is offline   Reply With Quote
Old 02-05-09, 04:51 PM   #167 (permalink)
AKcruiserfreak's Avatar
Wow! What a crazy ride. By the time you are done with everything needed to pass smog, you should have a new truck! ;-)
TK
1966 FJ-45lv resto. in progress
1966 FJ-45lv donor
1971 FJ-40 fun truck, resto. in progress
1974 FJ-40 donor
1985 FJ-60 donor
1985 FJ-60 creampuff
1993 FZJ-80 built to haul groceries
AKcruiserfreak is offline   Reply With Quote
Old 02-05-09, 04:55 PM   #168 (permalink)
NLXTACY's Avatar
TLCA# 19015
TK
Well at this point the only thing I haven't replaced is the motor. I'm sure there is a conversion in my future.
ふざけんなよ!
Old 02-17-09, 11:24 PM   #169 (permalink)
KayakPanic's Avatar
wow...
what a wild ride, just as any toy freak can attest, as we've all been there at one time or another!
this thread reads like a rollercoaster! good luck!!
one funny time:
when i test drove my 1977 fj40 (for sale in classifieds) farm-find about 1/2 of a mile before realizing the steering seemed a little wierd...
pulled back into the previous owners driveway and everyone was laughing as i pulled up...
turns out the tires were dry-rotted and i pulled back to their house on 2 rims and 2 tires (one in front and one in back-on opposite sides)
...obviously this helped with the final negotiations on the sale price...
-kayakpanic
KayakPanic is offline   Reply With Quote
Old 02-17-09, 11:57 PM   #170 (permalink)
NLXTACY's Avatar
TLCA# 19015
Ok THATS funny. I can visualize too :P
ふざけんなよ!
Old 02-17-09, 11:57 PM   #171 (permalink)
WOW! Ok here the deal hopefully I don't have your luck but I am driving to reno nv this weekend to pick up my 60 I am almost sorry I read this story wish me luck
clongacre is offline   Reply With Quote
Old 02-18-09, 12:00 AM   #172 (permalink)
NLXTACY's Avatar
TLCA# 19015
Ok words of advice:
• Hide the money
• Make sure you have more than you need
• Carry a cell phone AND CHARGER!!
• Make sure 17 people know where are going
• Tweakers can run....fast!
• Forget about trying to find a pay phone
• AAA sux ass in the middle of no where
• In a pinch, you CAN use a pine cone for toilet paper
ふざけんなよ!
Old 02-18-09, 12:04 AM   #173 (permalink)
NLXTACY's Avatar
TLCA# 19015
Oh as another update...
Mark Algazy had an FJ60 he was parting out and I bought the suspension on it. Looks like about a 4" OME spring lift with anti-inversion greaseable shackles. All the bushings are energy suspension. Sway bar extension. Bump stops. The works.
I ordered the u-bolt flip kit from LCWIZARD and they already showed up...in THE heaviest USPS delivered box I have ever lifted. Its gotta be 50#. So I gotta spray paint the u-bolts. All I think I need now are the extended brake hoses and I should have everything I need. I am looking forward to documenting the whole process.
ふざけんなよ!
Old 02-18-09, 07:37 AM   #174 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Nice! Make sure to get the stainless braided extended lines.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 02-18-09, 07:43 AM   #175 (permalink)
orangefj45's Avatar
sweet! that rig rode pretty well so yours should too. you can get the brake lines from marlin. the ones they sell are dot approved ( most kits are not ) with the clear palstic sleeve on the outside. i use them almost everytime i install a lift or do an SOA conversion.
TLCA and PMC member
Old 02-18-09, 03:10 PM   #176 (permalink)
hopefully tweekers don't like snow and there is a oil leak from the front of the motor does anyone know what size the crank pully bolt is?
Old 02-19-09, 08:28 AM   #177 (permalink)
iron_giant's Avatar
Wow, this truck has come a long way! I was at Georg's when this 60 first came in, and I can attest to the time and effort already put into it.
A suggestion when doing the manifold: Remflex strongly recommends against using any sealant on their gaskets. Typically the burn temps of the sealants are much lower than the gasket is rated to (especially the spray on copper sealants) and often below the temps the manifold reaches. I've done three manifolds now using the dry gasket and have had excellent results with them all. Make sure you torque properly and evenly, and although they say you don't need to re-torque, I always check just to make sure. If you have any questions feel free to hit me up.
David
1984 JDM Hj60, RHD, ARB & limited slip, high roof, Alcans, 35's, 4.56's and a whole lotta fun
Remflex Exhaust Gaskets for Land Cruisers.
Gas and Diesel.
2f EGR flange gaskets.
2F, 22R/E/EC, 2H, 3B
Manifold gaskets
http://shop.fundametalism.com
iron_giant is offline   Reply With Quote
Old 02-19-09, 10:50 AM   #178 (permalink)
NLXTACY's Avatar
TLCA# 19015
Thanks for the advice!
David
ふざけんなよ!
Old 03-13-09, 01:31 AM   #179 (permalink)
NLXTACY's Avatar
TLCA# 19015
Quickie update:
Putting in the lift kit AND doing the manifold this Sunday/Monday. I was at Mark's today and while I was there he was taking off his headers from his 40. The exhaust flange had a Remflex gasket. It was toast. It was broken in three pieces and brittle. I have the feeling that this is definitely a single use gasket. I'm still going to give it a try. Depending on how warped the manifolds are will determine if I go to Martin Davidson machine shop and have them surfaced. Anything more than 1/16" and I will get them ground down.
So by Monday my lift will be on, my exhaust/intake leak will be gone and I will have my new to me 80 series wheels. All I need now are some tires (275 or 285/75/16) if anyone has some to sell
I have been SERIOUSLY considering using SecondSkin's DeadLiner roll-on/spray on bed liner to put OVER the Damplifier Pro I will eventually be getting. This is instead of the Rhino Lining. Any thoughts?
ふざけんなよ!
Old 03-13-09, 09:16 AM   #180 (permalink)
iron_giant's Avatar
Awesome, big weekend ahead! The Remflex gaskets are realistically a single use gasket. Unfortunately exhaust gasket materials tend to have an inverse relationship between between sealing tolerances and re-usability. The harder and reusable gaskets like compressed steel, aluminum, even copper, require more precise surfaces to seal and and are much less forgiving as far as the heat cycling. The combination steel gaskets like OEM and Fel-Pro are often reusable and more forgiving but as experience has shown, long term sealing on older engines and with custom headers has been hit or miss. The Remflex gaskets are a soft and thick graphite designed with large sealing tolerances and for longevity (high heat tolerance plus malleability). Unfortunately, once they are torqued and especially after they have heat cycled they pretty much bond with the surfaces and are difficult to reuse. Good luck and be sure to PM if you have any questions.
Gas and Diesel.
Manifold gaskets
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/229660-new-fj60-world-come-share-my-pain.html
Posted By For Type Date
60-Series Wagons on IH8MUD.com Forum - The Truth is in the Rocks | BoardReader This thread Refback 09-13-08 12:27 PM
