any mechanics in the house
I am hoping this isn't as bad as it sounds and any advice / help is much appreciated. I up shifted into 2nd gear and accelerated then approaching a stop decelerated and it sounded and felt like it was chewing gears and slipping. It drives fine on the upshift and if you engage the clutch and brake, no problem. The banging and grinding seems to be on the second gear deceleration. I am hoping it is low trans fluid, low transfer case fluid ... something simple...but.... any way thanks for any info.
Loud Second Decell
Wow doesn't sound good,
![]() but what do I know. Let's see what the xperts on transfers and transmission think. I know just sufficent knowledge in this area to keep my big mouth shut. But I do want to read their suggestions. Luck hopefully
__________________ 85 FJ60 in birthing pains. aka BT60 ![]() 2x 85 FJ 60's sold ![]() 76 FJ55 what a pig wrecked after 280000 ![]() 74 FJ45 was not mine but used at work ![]() 72 FJ40 also gone but not forgotten ![]() 01 100 year edition Indian Scout
wild guess
i have never seen the internals on a 60 trans. since most of the noise is in second gear i would say that your second gear is showing wear on the coast side possibly some pitting.i would drain some fluid and get a magnet to see how much metal is getting mix in the oil.if this is the case my suggestion is time to move up to a 5 speed
. also try changing the fluid it might minimize the noise,or best yet is skip a shift to 3rd.hope this helps. john
__________________ If i can't fix it i don't buy it.if it cost too much to fix then trash it.![]() 87 fj60 mostly stock at this time 93 toy hi-lux 4x4 extra cab w/camper shell also stock 95 mitsu montero sr w/ rear lockers (wife's suv) 99 mitsu galant gtz (wife's DD) |
Credit Counseling | Problem Mortgage | Car Credit | صور سكس | Mortgage Calculator |
