Old 07-03-08, 08:57 AM   #1
cruiserloco's Avatar
TLCA# 16372
question abaut the hubs please
I was fixing the breaks on my fj62, so I had it in 4 stands. I locked the hubs and put the truck in 4h to inspect the 4wd system, everything is working fine so I put it back in 2h and free the hubs.
With the hubs on free position I put it in 4h again and the front tires started spinning, is this normal? I always thought the free hubs means free spinning you will see the driveshaft moving but no the tires.
If my hubs are locking up all the time I want to fix it right away, any opinion will be appreciated.
cruiserloco
cruiserloco is offline   Reply With Quote
Old 07-03-08, 09:01 AM   #2
nuclearlemon's Avatar
TLCA# 1431
did you hold the tire while turning the powertrain? they will float a bit, but you should be able to grab the tire and stop it.
seven cruisers and 3 of em run and four are for sale
nuclearlemon is offline   Reply With Quote
Old 07-03-08, 09:03 AM   #3
5280Hawk's Avatar
in 4hi and hubs free, the front shaft should spin, but the tires shouldn't. have you had your hubs apart recently?
they're pretty simple, and one might just be sticking a bit.
- 1983 FJ60 - 229K
2.5" Man-a-fre HD leaf springs, HFS shocks
4runner Calipers, 4.11 thirds 33x10.50MT's Wilderness Roof Rack
CORN TACO - DD - 2005 Tacoma Double cab with Ethanol full flex converter
ARB Front bumper w. warn winch and PIAA lights
3" Toy Tec Lift Rock-tec rear bumper
5280Hawk is offline   Reply With Quote
Old 07-03-08, 09:11 AM   #4
TLCA# 16372
No I havent had it apart. And the system is moving stong.
Can the hubs be fix or i have to buy new ones?
cruiserloco
Old 07-03-08, 09:15 AM   #5
cruiser88's Avatar
TLCA# 17319
Take them apart and clean them
BLAH BLAH
Old 07-03-08, 09:16 AM   #6
Randy88FJ62's Avatar
They can be rebuilt but I have personally not done that myself.
Randy88FJ62 is online now   Reply With Quote
Old 07-03-08, 09:22 AM   #7
5280Hawk's Avatar
It seems to me if they were broken internally they would fail where you couldn't get them to lock, because the internals were trashed. and it would sound horrible when you spun it.
simple explanation - Theres a spring inside the hub that moves the teeth of the hub on and off a spindle when you turn it from free to locked, and if theres not enought lube grease in there, the spring would not be able to move it.
They don't break very easily.
- 1983 FJ60 - 229K
Old 07-03-08, 09:24 AM   #8
cruiser88's Avatar
TLCA# 17319
And a real common mistake is to much grease...which would cause the lock in lock outs to stick or drag whatever you wish to call it.
BLAH BLAH
Old 07-03-08, 09:37 AM   #9
TLCA# 16372
when I turn the knob dose not turn all away it get stock in the middle it go from free to 1/2 way to lock. Does this mean is fry?
cruiserloco
Old 07-03-08, 09:41 AM   #10
cruiser88's Avatar
TLCA# 17319
No does not mean they are fried they could be filthy.
BLAH BLAH
Old 07-03-08, 10:04 AM   #11
It means that the clean grease that is supposed to be in there is probably sludge. Do a search on hubs. There are plenty of good pictures showing an exploded view and a few threads on how to rebuild them. It is within your ability.
Keep asking questions and we'll get you to where you need to be.
Old 07-03-08, 01:38 PM   #12
what he said
Mace's Avatar
very simple to pull them off and clean them.
One bananna job
Bout $40 worth of tools if you do not have any.
BTW, if your hubs are gummed up. You most likely need to do a whole knuckle job. That is not hugely tough either but does take some special tools (one big ass socket specificly)
I am kinda gay.......
My Myspace
Old 07-03-08, 05:44 PM   #13
cruiser88's Avatar
TLCA# 17319
One bananna job
54 mill. I think?
BLAH BLAH
Old 07-03-08, 10:29 PM   #14
Fiona is her name!
CruisinFJ60's Avatar
TLCA# 16781
54 mill. I think?
yuppers
84 FJ60, OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap
Originally Posted by whodat View Post
lol, carbs...lol
even us cavemen have switched to EFI.
95 Pontiac Trans Am !cats, flowmaster exhaust, and lots of fun.
91 Honda Civic with a B18A1 Integra LS motor, soon to be JDM B20B CR-V motor.
My MySpace----> myspace.com/blitzerkreig1603
Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
NObama '08
CruisinFJ60 is offline   Reply With Quote
Old 07-03-08, 11:45 PM   #15
When you get it apart, find out what is wrong and start putting them back together make sure you get your bearing preload, and jamnut specs correct or the drivers side jam nut can back off and fuse the hub together. (PO did this to mine)
'88 FJ62 2 1/2"OME 33x10.50 BFG ATs (5.3 Vortec/4L60E arrived working on remaining parts)
'71 IH Scout II (working on Injection)
Yes my says the Cruiser needed more PUNCH
but WOW the Honey Do List got BIG
jacksfj62 is offline   Reply With Quote
Old 07-04-08, 02:56 AM   #16
freds40's Avatar
If you need to clean it, it's just a matter of using a 10 mil socket and removing the 6 bolts from the outer most cap of the locking hub. The inner (large chrome ) section just houses the hub gear. The outer cap houses the movable mechanism. Pull that, clean it up really good, maybe scrape out the crud on the chrome hub section, re-grease, and throw it back together.
I'd say max of 15 mins. each side from start to finish, and that's with a thorough cleaning.
freds40 is online now   Reply With Quote
Old 07-04-08, 07:33 AM   #17
TLCA# 16372
[quote=freds40;3455295]If you need to clean it, it's just a matter of using a 10 mil socket and removing the 6 bolts from the outer most cap of the locking hub. The inner (large chrome ) section just houses the hub gear. The outer cap houses the movable mechanism. Pull that, clean it up really good, maybe s****e out the crud on the chrome hub section, re-grease, and throw it back together.
I'd say max of 15 mins. each side from start to finish, and that's with a thorough cleaning.[/quot
I'll clean them and if dosent get any better then is time for some newones anyway.
thanks so mush for everybody's advice.
This forum is great
cruiserloco
Old 07-04-08, 09:32 AM   #18
freds40's Avatar
What ever you do, don't buy NEW Aisin hubs. They are something like $250-$300 a piece. You can always find good used ones but even if cleaning doesn't fix yours, I'm sure you can get a replacement spring.
US Business Directory | Personal Loans | Car Insurance | Secured Loans | Earth for Energy
