Starting Troubles after cruiser has been driving then stopped.
I apologize for the long read and the disarray of information below:
Coming back from a weekend off roading trip I stopped for gas. When I tried to start her back up it wouldn’t start. The starter does not turn, all I hear is a click. When I keep trying to turn the ignition over it will eventually start after many tries (about 5 minutes.) This starting issue happened again a week later (today.) Both times have been in warm weather above 100°F if that makes a difference. I did notice that my truck was rough idling when offroading at high altitudes during the off road trip (roughly 10,000 feet.) Not sure if that is related to this as well. Also: Prior to the trip I hooked up the battery backwards. I have since then replaced the fusible link. I currently do not have reverse lights and no passenger rear marker light. I am chasing that electrical issue down on the side, but once again it may be related. Also… I have a new radiator that I installed as well as a trany cooler and replaced the trany fluid before the off road trip. Also….I put new spark plugs in before the trip but did not set the gaps. The plug wires and distributor are also replaced within the last year. I know not all this is related but maybe some of you with experience may see a connection. I have read threads about the FPR and other associated parts but cannot pin point my problem. The fuel filter was replaced within the last year so I’m assuming that is ok. Any help with this bad starting issue would be much appreciated. I wanted input before running to Toyota to pick up an FPR for no reason. -Randy |
Get a new starter or rebuild yours. That is the first sign of wear.
If the solenoid is going bad that is easy. If the gears are worn, it is better to just get a remanned or new starter. These starters are gear reduction starters and when they start going bad they lock up and teh solenoid is not strong enough to push through the bind. Or the solenoid is just getting hot. If it happens again just tap it with a rock or a hammer on the end of the starter and it will crank right up. cam __________________ 1988 FJ62 buggy SOA front 4-link rear crawl box lockers C3 beadlocks 38"TSL/SX ram assist 30 splined chromo rears 6 studded rear disc Warn RC rear Warn 8274 front Baja SS seats G-Force Race harnesses 1989 FJ62 Ome HD 4" w/35's 1991 FJ80 w/33's 2006 F350 King Ranch |
Randy, your no starts sound just like a bad starter condition. Adding in the heat equation during a hot day on a long trip seals the dx even futher. Unless there's other physical probs with the starter, a simple rebuild should net you another 10+ years of service. Call C Dan for the rebuild parts (plunger and contacts) if you feel confident it's a bad starter.
__________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
Hodag's old post about the rebuild is currently on page 1:
http://forum.ih8mud.com/60-series-wa...r-rebuild.html __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
Sorry I dod not put in more details. I rebuilt the starter about a month ago. I tore it apart and replaced the copper contacts. I cleaned all ground strap locations. My truck worked beautifully after that newver missing a cold start. I am having a problem with restarting it after it's warm though.
Here's what I have found from searching: "COSkier1 A bad FPR will do 2 things: you will definitely not be able to hot start, and it may just cut out on you completely while driving. In either case, you have to wait for everything to cool down before you can start driving again. So from your symptoms, it doesn't sound like the FPR is bad." |
My vehicle has wanted to cut out once when it was really hot after I got it started up again at the gas station....
Randy
Next time you have this problem try the tap on the starter trick. It sounds like the gears in the starter are worn and in a bind, this also happens when it gets hot. The Starter just clicking is a starter problem, or ground but very doubtful a ground problem. The contacts only help the solenoid actuate properly. __________________ 1988 FJ62 buggy SOA front 4-link rear crawl box lockers C3 beadlocks 38"TSL/SX ram assist 30 splined chromo rears 6 studded rear disc Warn RC rear Warn 8274 front Baja SS seats G-Force Race harnesses 1989 FJ62 Ome HD 4" w/35's 1991 FJ80 w/33's 2006 F350 King Ranch |
#8 | |
I checked the gear on the starter that engages the flywheel and it did not look worn. I have no problem taking it apart again but I’m not sold yet that it’s the gear. What do you mean by tapping on the starter? Would that really help it? ![]() ![]() |
#9 | |
Cam __________________ 1988 FJ62 buggy SOA front 4-link rear crawl box lockers C3 beadlocks 38"TSL/SX ram assist 30 splined chromo rears 6 studded rear disc Warn RC rear Warn 8274 front Baja SS seats G-Force Race harnesses 1989 FJ62 Ome HD 4" w/35's 1991 FJ80 w/33's 2006 F350 King Ranch |
#10 |
Do they sell the stator with the gear on it as a seperate piece at Toyota? I might give CDan a call...
#11 |
I'm still interested on input regarding the rough idling at higher elevation and the one time my truck wanted to stall. I may have an FPR isuue as well as a worn gear....
Anyone with experience on the FPR situation? |
#12 |
I'd bet the farm you have a bad armature in your starter. Try the hammer trick; have somebody hold the key in the start position (assuming that it's not working on this attempt) and whack the starter with a hammer. If it engages, and I bet it will, you have a bad armature and no amount of cleaning and new brushes will fix it.
__________________ 1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going. |
#13 | |
I will check it out next time it happens. I'll carry a hammer. Thanks for the input. |
#14 |
I think that if it were the FPR, she would crank, but not catch. At least that is how I understood it.
Ive been having hard start issues with mine since Ive owned it where shell crank, but not catch fire. Ive replaced hoses, FPR, EGR...Now Ive also heard that the issue could be related to the check valve on the fuel pump...She ALWAYS fires, eventually. As far as the rough idle...I donno what to tell you on that. Maybe a vaccuum issue on one of the MILLION hoses? Good luck and post up when you find out what it is. Chicago __________________ TLCA#16202, KE7VAT Toyota family: 88 FJ62 (Fairly built) 06 4runner...wifes rig! 06 Tacoma, DD, BONE STOCK and staying that way! PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada! FAWKING CUBS! Life long DISAPPOINTMENT! |
#15 |
Stumbling at altitude only points me a too-lean condition. FPR or related item, small vac leak, even bad O2 sensor (however, they almost always over-richen when heading south). I've not had to deal w/ these issues yet on my own 62, so I'm not much further help here.
#16 | |
__________________ -24 volt 1980 BJ40. -Five 24 Volt Hobbs heavy duty equipment lights. -32x11.5 GWrench AT's. |
#17 |
Yes, armature and brushes in the starter motor are what are being posited as a potential fault. What the raps on the starter do are to "shake" the brushes and armature into contact and jar the motor into operation.
So bring along your favorite BFH and a bar to act as a extension so you can swing away from above the fender. Have someone hold the key on the "start" position when the failure is present. You don't have to bang hard, use enough force to drive, say, a finishing nail. Good news is replacing the starter brushes is easy, cheap and you were almost there when you had the starter out!!! Best regards, Rick |
#18 |
One more thing: Carburetors are not altitude compensating. They don't alter the air/fuel ratio due to ambient air pressure. If you run an sea level tuned carb at 10k feet, your idle smoothness and performance will not be equal, period. If you are satisfied with the truck at the altitude you normally drive, then chock up the experience to the temporary venture into higher altitude.
Rick |
#19 | |
#20 | |
That will work too, for a while. Eventually the brushes will stop making contact and any amount of hammering won't make it start..... The plunger is the moving part of the solenoid, bridging the contacts that transmit power to the starter motor. The armature is the moving (rotating) part of the starter motor, passing through the attracting/repelling field currents of the motor, producing mechanical effort that turns the ring gear through the bendix gear. The brushes that wear out are located in the housing that covers the armature. Rick |
#21 | |
The armature is the big cylindrical object in the top middle of my first picture. The plunger is in the middle of the second picture. If you want more information on the theory of what they are post here and I'll keep on writing. Update: Got my FPR from toyota, waiting for the fuel pump. I will install all of these items in two weeks when I get beck from working in England. |
#22 |
Real Time Help Please:
I got the fuel pump, FPR, and Fuel filter installed. I hooked up all the hoses and now the car won't start. It turns over but no vroom... Do I need to prime the fuel lines or something? I put about 2 gallons in the gas tank. Mybe I hooked the rear rubber fuel lines up wrong?! |
#23 |
I rechecked all hoses and everything looks to be in order. I pulled off the rubber hose that hooks up to the hardline leading to the FPR and gas came out. I can't figure out why my car isn't getting gas to the injectors. :(
#24 |
Randy,
Two other options that you might want to check out are your ignition wiring, and also the switch found on the automatic's shift lever. I had a problem very similar to yours on my truck, where after getting "hot", the starter would fail to engage immediately after shutdown. There were several occasions where I would have to wait for approximately 30-45 minutes before I could get my FJ-62 started again. Needless to say, this issue was very embarrassing, especially when I had to push my heavy truck from the gas pump to the nearest open parking spot. My issued turned out to be a wiring mess that the previous owner had made. Long story short, he had wired an alarm system into the ignition wiring, but did a poor job doing so. The added resistence found in the ignition circuit when hot, due to the piss-poor wiring, would not send enough "juice" to the starter. Also, as mentioned above, I would due a quick check of the switch located in the automatic's shifter lever. I seem to recall that there is a simple switch in there that will not allow you to start your vehicle unless it is in Park. Sometimes, this switch needs a little cleaning to prevent it from sticking in the "open" position, which again disables your starter. Just a couple of ideas that you may want to consider, after checking the contacts/solenoid in your starter... Regards, Joel. |
#25 |
Joel,
My starter engages when I turn the key, trying to crank the engine. Fuel never ignites and all I am doing right now is wearing out my starter and battery. My fuel pump failed two weeks ago and I tried replacing it myself. At the same time I replaced the FPR nd the fuel filter. Right now I need to figure out what part of the fuel delivery system is failing. Whether that be electrical or mechanical. How do I tell if the engine is getting fuel? What checks / diagnosis can I do? |
#26 |
more help please. :(
#27 |
If the fuel pump is pumping and your very quiet you should be able to here it.When you turn the key on do all your dash warning lights come on?
__________________ Mike Hanson 1982 FJ40 1987 FJ60 1988 & 1989 FJ62s 1991 FJ80 |
#28 |
Yes, the dash warning lights come on. When the key is turned to ignition but not started should i be able to hear the pump if I'm under near the fuel tank? Does it constantly run providing pressure until fuel is used?
