Old 07-01-08, 11:13 PM   #1
Kief's Avatar
FJ62/60 w/ H55f transfercase compatability?
Will an H55f work with the FJ 62 transfercase (32 spline)? I think it will as it is the later larger shaft. Just checking.. thanks, Kief.
Kief is offline   Reply With Quote
Old 07-02-08, 03:55 AM   #2
Yep.
Mitch
Mitch Rowland
Dallas, Pennsylvania
"Take the body off"
archtimb is offline   Reply With Quote
Old 07-02-08, 07:12 PM   #3
Kief's Avatar
Thanks, I know I've seen a thread in which the stock case was used in the H55f swap.. just couldn't remember the details.
Old 07-04-08, 06:45 AM   #4
Just make sure that the H55 you are using is for the gas engine. PN 33030-60450. I understand the diesels have a different input shaft.
Mitch
Mitch Rowland
"Take the body off"
Old 07-04-08, 02:40 PM   #5
Tapage's Avatar
2H H55F usea 275mm clutch ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-04-08, 02:43 PM   #6
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Mitch
The B diesels have a different input shaft, the H diesels' transmission is compatable with the gasser H55f.
Andrew
1971 FJ-40 Rubicon tested
1976 FJ40 RIP
1989 FJ-62 117k-son's driver for now.
1997 FZJ-80 Factory sub-tank, and other tricks
Old 07-04-08, 04:12 PM   #7
Tapage's Avatar
It's longer as the same as the bellhousing is ..
Old 07-09-08, 05:48 PM   #8
Kief's Avatar
Thanks, I think this will work... need to start saving and stop spending..
Old 07-09-08, 10:32 PM   #9
RredFJ40's Avatar
TLCA# 14992
So Kief, maybe in your studies you found the answer to this:
Will an FJ62 TCase fit an early FJ60 Tranny (80-84)?
My yearning is 3 fold
1) Already have 62 tcase - could rebuild early in anticipation
2) 34mm idler shaft
3) lower gears possibly
Joel
"Birds have nests, foxes have dens but the hope of the whole world lay on the shoulders of a homeless man." - R. Mullins
82 FJ60 - normal stuff
68 FJ40 - gone
88 FJ62 - gone
Jefferson State Cruisers
RredFJ40 is offline   Reply With Quote
Old 07-09-08, 10:42 PM   #10
KI6MIE
TLCA# 11734
2) 34mm idler shaft
It will, but you will need to mod the shifter system. that has been pretty well covered in previous threads.
Since you basically build the t-case on the transmission, there is no reason to do it "early".
The FJ62 has a 38mm idler like the late FJ60 cases.
There has been much speculation about the gear ratios, but I believe all the USA cases are roughly 2.231315926 : 1. It is possible that the 62 has 1.99 : 1 like the overseas trucks, but you can count the gear teeth when you do your rebuild and then you will know.
Andrew
1976 FJ40 RIP
Old 07-10-08, 10:40 AM   #11
RredFJ40's Avatar
TLCA# 14992
Thanks, yeah I meant 38mm....
I was mostly concerned with bolt pattern and length of the tranny output shaft considering there is no spacer.
I would buy another tranny case - I have an H41 waiting, it's just in an early case (One-piece transfer). So I'd want to assemble the tranny and t-case ahead of time to simiplify the swap into my rig.
On the gear ratio - the tech trivia lists the auto gearing as 2.29 or thereabouts.
Joel
68 FJ40 - gone
88 FJ62 - gone
Old 07-10-08, 03:53 PM   #12
Tapage's Avatar
IIRC all auto 62 come with 2.48:1 Low range as same as 80 series HF series t-case ..
Moneygram | Loans | Online Loans | Loans | Fantasy Football
