Old 07-01-08, 06:36 AM   #1
Transmission oil pan removal?
I am going to be doing a "Rodney Flush" on my 89' FJ-62. I also what to clean the ATF filter. After I have removed the 20+ bolts on the trannsmission oil pan, what do I do about the hose that is connected to the front of the pan? Does it have a union that needs to be undone. What is the function of this hose?
CarbonCruiser is offline   Reply With Quote
Old 07-01-08, 06:48 AM   #2
ad20k's Avatar
Are you referring to the metal pipe? If so, that is the dipstick tube. There is a union about 4 inches up the pipe that is a slip fit with an oring.
When I removed the pan, the procedure I used was 1) remove dipstick, 2) remove 20 bolts, 3) separate pan, 4) wiggle pan to separate the pan tube from the upper dipstick tube.
Hope this helps.
Aaron
88 FJ62 - 31x10.5, parabolics, Scion radio, e85 flex fueler, 4 runner calipers, D'amplified, Wagongear weatherstrip. My DD commuter truck.
ad20k is offline   Reply With Quote
Old 07-01-08, 08:08 AM   #3
Thanks, that is just what I needed to know.
Old 07-01-08, 11:10 AM   #4
KLF
KLF's Avatar
Don't fool yourself into thinking that just because you drained the pan that everything is empty and it's not gonna drool any fluid on you. It will drip ATF for days, so plan to keep a drain pan under it the entire time.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 07-01-08, 11:29 AM   #5
Randy88FJ62's Avatar
KLF is right. Ask me how I know.
Randy88FJ62 is offline   Reply With Quote
Old 07-01-08, 12:42 PM   #6
impervious to subtlety
RockDoc's Avatar
TLCA# 18148
Even worse if you pull the valve body, downright annoying if you have to pull it twice
[ ][ ]=TOYOTA=[ ][ ]
4 eyes > 2 eyes
Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition
RockDoc is offline   Reply With Quote
Money | Mortgage Calculator | Personal Car Finance | Remortgaging | Канада знакомÑтва
