Transmission oil pan removal?
I am going to be doing a "Rodney Flush" on my 89' FJ-62. I also what to clean the ATF filter. After I have removed the 20+ bolts on the trannsmission oil pan, what do I do about the hose that is connected to the front of the pan? Does it have a union that needs to be undone. What is the function of this hose?
Are you referring to the metal pipe? If so, that is the dipstick tube. There is a union about 4 inches up the pipe that is a slip fit with an oring.
When I removed the pan, the procedure I used was 1) remove dipstick, 2) remove 20 bolts, 3) separate pan, 4) wiggle pan to separate the pan tube from the upper dipstick tube. Hope this helps. __________________ Aaron 88 FJ62 - 31x10.5, parabolics, Scion radio, e85 flex fueler, 4 runner calipers, D'amplified, Wagongear weatherstrip. My DD commuter truck. |
Thanks, that is just what I needed to know.
Don't fool yourself into thinking that just because you drained the pan that everything is empty and it's not gonna drool any fluid on you. It will drip ATF for days, so plan to keep a drain pan under it the entire time.
__________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
#6 | |
impervious to subtlety
__________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition |
Refinance | Credit Cards | Unblock facebook | Final Fantasy Ringtones | Car Finance |
