Uncooperative pin
After spending one hour trying to remove the pin that holds the clutch pedal to the clutch master cylinder, I gave up for today. I removed the small key, tapped on the pin, and did not moved, I grabbed it with a pair of pliers, twisted and turned it and still the pin would not come out. I sprayed with penetrating fluid, and nothing happened. Does this pin have another hidden key?
__________________ José ![]() 92 FJ80 83 FJ60 76 Fj40 85 TY350 91 Isuzu P/UP 79 Plymouth Trailduster 72 Jeep Commando |
It's just a pin and a clip. The pin should pull right out once the clip is removed. did you remove the clutch pedal return spring and try wiggling the clutch pedal to get the holes in the fork to line up with the hold in the clutch pedal? If one is pushing against the other it might be holding the pin in by friction.
Huh? Who me?
Had the same problem on my buddy's 40. Try pulling the clutch pedal forward (towards the seat) then push a little back to loosen it up.
__________________ "We are not the base, we are the 2% lunatic fringe." - Ed97Fzj80 89 FJ62 - nicely modded (OME heavy lift and shocks, lunchboxed rear, ProComp M/T's w/ Rockcrawlers, 4Runner front d/b's, de-smogged) 07 FJC - nicely modded (Toytec lift,OME shocks, Digger Link LCA's, Revo's, JBA headers, aFe CAI) |
Removed the spring, now the picture show a bushing of some sort... I'll try the pull pedal and wiggle.
In debt to the Shaman
That bushing is for the pedal pivot, not the master cylinder.
__________________ aka Bushrat 1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage. |
That bushing seems to be frozen to the pin
Fixed! Since the pin was frozen to the bushing, I figure that pin and bushing have been "married" for almost 25 years, I went and unscrewed the clutch cylinder shaft from the square piece that connects to the pedal, and screwed the new cylinder in place. I replaced the slave also, and now the clutch feels like new!!
Gómez PEER | Credit Cards | Secured Loans | Advertising | Free Advertising |
