Old 06-29-08, 09:35 PM   #1
Sloooowwww!!!
I know that Landruisers are not race cars, but I think I that I may have a problem or maybe not. It just seems like it takes forevever to accelerate to around 55 MPH or to around 2500 RPM. Someone had mentioned that a bad temp sensor (CAT) could cause this? your thoughts???
1985 FJ60, H55F, OME 3" lift, 33 MT's
elkiny
elkiny is offline   Reply With Quote
Old 06-29-08, 09:39 PM   #2
2mbb's Avatar
TLCA# 6404
A bad temperature sensor will not cause this. A plugged CAT or exhaust could cause loss of power at higher RPMs. If you feel you are losing power as the RPM's increase then the exhaust might be restricted assuming it runs fine otherwise (no missing, etc.).
The temperature sensor is used to protect the CAT from burning up if you are running rich. It stops the air injection system from injecting air into the exhaust in front of the CAT.
edit: if you are running 33" tires and the stock gears (3.73), you're gonna take longer to get up to speed than guys with a closer to stock overall gear ration. With 33" tires, people usually start thinking about new differential gears.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 06-29-08, 10:23 PM   #3
weak-link's Avatar
secondarys not opening?
good tune up?
www.4x4Him.com
Pit Bull Rescue Central
http://www.pbrc.net/
weak-link is offline   Reply With Quote
Old 06-30-08, 09:17 AM   #4
Butt Ugly Chuck's Avatar
TLCA# 18371
Did you sort out your hesitation/surge? Do you get to 2,500 rpm any faster with the EGR bypassed?
Butt
7/85 FJ60 261k miles
91 Haro Extreme AL MTB - daily rider
16' Aire Jaguarundi
Butt Ugly Chuck is offline   Reply With Quote
Old 06-30-08, 10:07 AM   #5
TLCA# 18770
Butt
2X If not desmogged this will sure cause that kind of problem.
85 FJ60 in birthing pains. aka BT60
2x 85 FJ 60's sold
76 FJ55 what a pig wrecked after 280000
74 FJ45 was not mine but used at work
72 FJ40 also gone but not forgotten
01 100 year edition Indian Scout
IndianDoc is offline   Reply With Quote
Old 06-30-08, 10:11 AM   #6
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
W/ the 33's, how fast is 55 indicated, actually?
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's since 1988.
FJ40Jim is offline   Reply With Quote
Old 06-30-08, 10:17 AM   #7
beaufort-fj60's Avatar
33" are 88.41%.. or 48.63mph
Real Americans drink PBR
beaufort-fj60 is offline   Reply With Quote
Old 06-30-08, 10:19 AM   #8
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
55 indicated on the speedo is 48 true?
Check that math. 55 IAS is prolly more like 64 TAS.
Thanks,
Jim C.
TLC Performance
Old 06-30-08, 10:26 AM   #9
yup.. i typed it backwards.
8.64'- circumference in a 33" tire. it has 611.11 revs/mile
7.59'- circumference in a 29' tire. it has 695.65 revs/mile
so +12.15%mph is difference
Old 06-30-08, 11:07 AM   #10
High Desert's Avatar
Last time my rig was that slow on the go it was the fuel filter, (my EGR already bypassed) with the rotten fuel out there I'm only getting 18 months or so out of a filter before it goes south, (I drive less than 3k miles a year so mine sits up for weeks at a time which probably adds to my short life problem.
Also here in Oregon they have started putting at least 10% Ethanol in all the fuel. I noticed a drop in both MPG and "performance" (if that word can be applied to a Cruiser under any condition?)
1984 FJ60, 102k miles, OME med/heavy,
BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console.
High Desert is offline   Reply With Quote
Old 06-30-08, 12:44 PM   #11
Huh? Who me?
PhilC64's Avatar
TLCA# 17885
I had a similar issue until I did a tune up, trans cable adjustment, and a trans flush. Now I have no problem getting up to 70.
"We are not the base, we are the 2% lunatic fringe." - Ed97Fzj80
89 FJ62 - nicely modded (OME heavy lift and shocks, lunchboxed rear, ProComp M/T's w/ Rockcrawlers, 4Runner front d/b's, de-smogged)
07 FJC - nicely modded (Toytec lift,OME shocks, Digger Link LCA's, Revo's, JBA headers, aFe CAI)
PhilC64 is offline   Reply With Quote
Old 06-30-08, 02:47 PM   #12
what would a good tune up entail and what kinda place would you take a cruiser to to get it done?
ienjoysocks is offline   Reply With Quote
Old 06-30-08, 08:59 PM   #13
Huh? Who me?
PhilC64's Avatar
TLCA# 17885
Plugs, cap, rotor, wires, pcv, and air filter to start. If you're running the A440 auto trans do the Rodney Party trick, then the Rodney Flush. (Search those terms on how to do it.) Check the throttle cable adjustment and any other cable you have. I spent a good day doing all of this and loved the results on my FJ62!
All this can be done with simple hand tools. Don't be afraid to get your hands dirty, but before you do search the for sale section here or Fleabay for a Factory Service Manual. It's an invaluable reference!
Old 06-30-08, 09:51 PM   #14
I am having a similar experience and the boys at TLC discovered that I had a big crack in my intake manifold.
Sloan is offline   Reply With Quote
Old 07-02-08, 10:26 AM   #15
TLCA# 18770
Ouch!!
2x 85 FJ 60's sold
Old 07-02-08, 07:15 PM   #16
NCCruiser302's Avatar
That's how mine always was, and wouldn't "cruise" despite the name, it was always jumpy, so I rebuilt the carb and now I feel like I've got a brand new rig. I can hardly keep it from running away from me
NCCruiser302 is offline   Reply With Quote
Old 07-02-08, 09:29 PM   #17
No not yet, I was thinking it may be related. I guess I will try the tune up route first.
Payday Loans | Mortgages | Bet365 bonus | Hotels | Buy PSP
