Old 06-28-08, 07:58 AM   #1
'84 FJ60 newbie question
I'm a regular in the 40 and 55 forums, but I ran across an '84 60-series near me for $500 (asking) that the garage says a guy brought in because it didn't run, but then decided he didn't want to fix it.
The shop knows NOTHING about the non-running condition.
They say it has very little rust (yeah, right, believe THAT when I see it...)
Is an '84 fuel-injected, or carbureted? If it's carbureted, I might be able to rely on my wits to see why it won't run, but if I CAN'T get it to run, are there $500 worth of un-boltable parts on that vintage rig (not including the drivetrain, I'm not going to factor that in because God only knows when I can pull it)?
I figure I'd keep the front knuckles-out for the disc brakes, but that's about it.
'71 FJ55 Arizona truck
1 1/2" shackle lift, 33 x 9.50 BFG All-Terrains, 4-sp with Fairey overdrive, big brush guard with Warn 5687 (that doesn't work), otherwise bone stock.
brider is offline   Reply With Quote
Old 06-28-08, 08:06 AM   #2
Butt Ugly Chuck's Avatar
TLCA# 18371
...if I CAN'T get it to run, are there $500 worth of un-boltable parts on that vintage rig (not including the drivetrain, I'm not going to factor that in because God only knows when I can pull it)?
84's are carburated. Parts could easily fetch over $500 if it's clean
Butt
7/85 FJ60 261k miles
91 Haro Extreme AL MTB - daily rider
16' Aire Jaguarundi
Butt Ugly Chuck is online now   Reply With Quote
Old 06-28-08, 10:57 AM   #3
I don't see how you could miss for $500. Check it out. It should have electronic distributor/ignitor along with the appropriate push rod side plate if your 40 needs that. That's half the deal right there. Then there are the disk breaks. Also, power steering set up if your older 2 Fs have the holes.
86 FJ60, Champagne Bronze, 33X9.5s, Desmogged, Dynamat, ARB in rear, 4.11 gears. OME lift, bedliner on rocker panels. Tint.
1987 FJ60 Dark Blue Metallic, 31X10.5s, 130K, Desmogged.
"We have enough youth, how about a fountain of "smart"?
Heartworm is online now   Reply With Quote
Old 06-28-08, 04:57 PM   #4
didn't run could be alot of things, does it turn over but not start? could be an easy fix, $500 is not a problem to get back in parts if you have the time and room for it.
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 06-29-08, 08:24 AM   #5
cbmontgo's Avatar
TLCA# 14207
You can't go wrong for $ 500...
1985 rust-free, Arizona-raised FJ60 with 33s, OME 2.5", ARB bull bar, Hella 4000s and Warn M8000.
1988 FJ62, all stock...but this will soon change
1992 restored Canadian M101 1/4 ton trailer with rooftop tent
cbmontgo is offline   Reply With Quote
Old 06-30-08, 02:11 PM   #6
sirenmoses's Avatar
yep, snag it. doors & lil bits alone will get your $$ back.
dibs on hood bumpers, front dome light assembly, DS turn signal gasket, PS rear marker lite. ; )
what shall I drive today:
Oct 84 tan fj60, 260k mi -- dobermobile
Sept 84 tan fj60, 202k -- spare
(to be installed) 2.5" BDS suspension, SROR front bumper, Rowlands storage panels
85 Honda Accord, 110k -- commuter
91 Kawasaki Concours, 50k -- on the road again
sirenmoses is offline   Reply With Quote
Old 06-30-08, 03:16 PM   #7
Just try and git it.
Spike Strip's Avatar
TLCA# 17876
What color is it? And what's the mfg date on the inside door jamb. And what's the mileage.
BEST WWII STORY EVER WRITTEN
Spike Strip is offline   Reply With Quote
Old 06-30-08, 03:21 PM   #8
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
That's a great deal, and I'll bet the no run condition is something easy. Just make sure the motor isn't seized and if it will turn over, buy the thing and keep it on the road. These trucks are just tough, and are hard to kill, so grab it and start with the basics-battery, fusible links, ignition, tune up, compression. That should tell you where the problem lies.
Andrew
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 06-30-08, 09:05 PM   #9
planemech's Avatar
If you pick it up and do decide to part it out I would like to put dibs on the left front fender if not rusty and the headlight valance again if not rusty.
BTW what color is it.
Good luck
86 FJ60 Ol' Rustee Nutz 195,XXX
2.5" OME medium lift
Used 33" 1050 x 15 BFG MTs on black steelies
Straight pipe back from the Cat.
Many lessons learned.
planemech is offline   Reply With Quote
Old 06-30-08, 09:27 PM   #10
Huh? Who me?
PhilC64's Avatar
TLCA# 17885
That's a steal in parts alone for $500. Then again if you get it running you can double that or more in a heartbeat.
"We are not the base, we are the 2% lunatic fringe." - Ed97Fzj80
89 FJ62 - nicely modded (OME heavy lift and shocks, lunchboxed rear, ProComp M/T's w/ Rockcrawlers, 4Runner front d/b's, de-smogged)
07 FJC - nicely modded (Toytec lift,OME shocks, Digger Link LCA's, Revo's, JBA headers, aFe CAI)
PhilC64 is offline   Reply With Quote
Old 07-01-08, 08:22 AM   #11
Thanks for the input-
I'm gonna call the guy today and possibly snag it. I'll let everyone know if I do, and start honoring the dibs requests here before I do any classified postings.
Mortgage Calculator | Pay Day Loans | Books | Libro infantiles | Online Loans
