wheel bearing
I have a blown out wheel bearing. I went to change it and its seized on the spindle. Any suggestions for getting it off?
[quote=trimmertrail;3438598]I have a blown out wheel bearing. I went to change it and its seized on the spindle. Any suggestions for getting it off?[/quote
Inner or outer bearing? Outer will suck since you will have the hub in the way the whole time. If it's the inner, remove everything you can, notch the bearing with a high-speed cutter being carefull not the go too deep and screw up the spindle, then use a chisle to break the inner race off the spindle. From there, you will need to see if the spindle can be cleaned up. If not, you'll need a new one. Usually they will clean up. __________________ 1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going. |
I figured it out. I sat, cracked open a yuengling lager, poured a little on it and it loosened right up.
They call me crazy88
excellent...I was going to advise heat
__________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
#5 | |
Fiona is her name!
Thats freaking funny!
__________________ 84 FJ60, OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap 95 Pontiac Trans Am !cats, flowmaster exhaust, and lots of fun. 93 Toyota Camry LE, Daily beater 273,xxx miles and counting. My MySpace----> myspace.com/blitzerkreig1603![]() Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent) NObama '08 |
Problem Mortgage | Car Insurance | Mortgage | New York Hotels | Loans |
