Old 06-27-08, 09:04 AM   #1
Question My BJ60 keeps throwing up all it's antifreeze...
Wondering if anyone has any suggestions why my BJ60 sends all it's antifreeze into the overflow and beyond after it warms up. She has a new thermostat but still does it. I love my car but know very little about what makes it go. Thanks!
Red Pony is offline   Reply With Quote
Old 06-27-08, 09:17 AM   #2
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Welcome to MUD!
Turn all of you heaters on full blast the next time you add fluid. You may just have air in the system and the heater cores are part of the system.
D'Animal is offline   Reply With Quote
Old 06-27-08, 09:27 AM   #3
george_tlc's Avatar
TLCA# 8068
"still does it"...
I assume that means it was doing this before you replaced the thermostat etc?
I had a diesel that would spew coolant out the overflow once warmed up. Turned out to be a cracked head - hope that's not the case for yours
cheers,
george.
where ever you go, there you are....
'97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx
http://www.george4wd.taskled.com
george_tlc is offline   Reply With Quote
Old 06-27-08, 12:06 PM   #4
What else?
Have there been any other recent repairs? I had a friend go through this. He had rebuilt the engine and the after-market head gasket was incorrect; holes in the wrong places, no coolant flow. That's not the only time I've seen that.
1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going.
lehiguy is offline   Reply With Quote
Old 06-27-08, 12:29 PM   #5
Crack head (most likely)
Broken internal water pump shaft ( check the heater after 15 min. if it blows warm air then it is not water pump)
Bad radiator
FJn00b is offline   Reply With Quote
Old 06-27-08, 01:27 PM   #6
thanks! fingers crossed it is not the head!
I heard that if it was the head was cracked the antifreeze would be mucked up with oil that had leached, does that sound right? The antifreeze is perfectly clean when it comes out. The only repair I have had done recently with the cooling system was the thermostat.
Old 06-27-08, 01:52 PM   #7
mainlander's Avatar
You sure the t-stat is opening?
Might want to post this in the diesel section, many of the diesels folks may not look here very offten.
83 BJ60, 347K km's, Mitsu TD04 Turbo, Custom 2.5" SS Exhaust, OME 2.5 lift, 4x7 Home built roof rack, 80 series rims 265 BFG AT ko's, frame swap coming soon...
04' VW Golf TDI, 172K km's
mainlander is offline   Reply With Quote
Old 06-27-08, 02:23 PM   #8
hey we have twins!
i had the thermostat replaced when it first started doing it, the shop was pretty sketchy though and the new thermostat doesn't open until the heat gage hits the bottom of the overheating section.
Old 06-27-08, 02:36 PM   #9
Note that the FJ and BJ thermostats are NOT interchangeable - a common mis-installation.
Check all the basics, then check for pressure building up in the cooling system while the engine is cold or hot - use a pressure gauge/cooling system pressure tester (looking for pressure that is not related to water temperature/thermal expansion of coolant).
Common cause: head gasket or cracked head.
NOTE: make sure you have NO air in your cooling system.
Check out our new location in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - all hardware included
Limited Quantities - Deposit or Full Payment Required to hold your order while they ship
Old 06-27-08, 05:54 PM   #10
george_tlc's Avatar
TLCA# 8068
The diesel that I had with a cracked head ran perfect till it warmed up, then the high compression of the diesel with the hot head would push exhaust into the coolant. So, no oil/coolant mix in either the sump or coming out the overflow - so seeing 'muck' is not necessary while still having a cracked head.
New head (and all it entails) took care of the problem.
cheers,
george.
Tags
antifreeze, bj60, cooling, overflow, radiator
Savings | Free RPG | Problem Mortgage | Credit Card Debt Consolidation | Loans
