4.11 gears
I need 4.11 gears front and rear for my 86 FJ60. Best source for quick delivery? kbill45@cableone.net
couple ideas for ya'
here's some ideas:
1. check the parting out section for TWO fj62's, try to get the front diff from each. 2. Cruiserparts.net: but you will need to spend some time cleaning them up. I got mine from them, they were a little dirty, but totally fine. HTH. __________________ 1987 FJ60, SROR Sliders, lockers, 4.11s, 33s and other stuff 1977 FJ40, mostly stock. |
I got
I got Yukon 4.11's from Marlin
and a set-up kit Good guys JT could hook you up too, they are running a deal in Vendor Marketplace of Classifieds __________________ 83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Warn M8000-Ultimate Air-Defender Rack-Rising Sun Roof Clamps-Yukons-Thanks Ige-Groucho-EricS-Corbett-Schmoozer-DurangoDDS-Zen80-Marlin-Bobby-Proffitts |
I run 4.11's with 37's AND an auto tranny. To be honest it has been so long with this setup that I can't tell how bad it sucks. I'll let you know in a week or two as I'm finally putting in the 4.88's.
__________________ 2005 Trek 5000, Ultegra, Easton Orion II's, DD (15k miles) 2002 Xterra, 31's, dual batts, National Luna 52L, (105k miles) 2001 UZJ100, stock (41k miles) 1990 FJ62, SOA+OME, 37's, Slee rear/ARB front, dual batts, FF, ARB's with 4.88's, and other stuff (145K miles) 1975 Bronco, 347 stroker, extended wheelbase, locked, 35 spline 4340, Atlas II, Klune-V, NV4500, 40's, my Land Cruiser killer (110k miles) |
Why do you only want the front diff's from an FJ62?
__________________ 1984 FJ60, 170 Thousand Miles, OME, 33x10.5x15 BFGoodrich All-Terrain T/A KO, 15x8 Eagle 058 Alloys |
Probably because the front ring and pinion will have a lot less wear than the rear. I'd guess that my front gear set has less than 5K miles of wear on it compared to the 70K+ on the rear set.
That's the only reason I can think of. __________________ 2005 Trek 5000, Ultegra, Easton Orion II's, DD (15k miles) 2002 Xterra, 31's, dual batts, National Luna 52L, (105k miles) 2001 UZJ100, stock (41k miles) 1990 FJ62, SOA+OME, 37's, Slee rear/ARB front, dual batts, FF, ARB's with 4.88's, and other stuff (145K miles) 1975 Bronco, 347 stroker, extended wheelbase, locked, 35 spline 4340, Atlas II, Klune-V, NV4500, 40's, my Land Cruiser killer (110k miles) |
yuppers.
bingo. :-)
4.11s
I am only going to run 33'' tires so 4.11s should work well.
Front difs have hardly any wear. It is not necessary that both be fronts as I will just switch them front to back and back to front. I will give Marlin a call. Thanks Bill |
I probably got lucky, but i found mine from a guy on Craigslist.
$100 each. __________________ - 1983 FJ60 - 229K 2.5" Man-a-fre HD leaf springs, HFS shocks 4runner Calipers, 4.11 thirds 33x10.50MT's Wilderness Roof Rack CORN TACO - DD - 2005 Tacoma Double cab with Ethanol full flex converter ARB Front bumper w. warn winch and PIAA lights 3" Toy Tec Lift Rock-tec rear bumper |
Mortgages | Car Insurance | Personal Injury Attorney Los Angeles | Free Myspace Layouts | Video Clips |
