Old 06-12-08, 07:05 AM   #1 (permalink)
Transfer case plug helicoil?
Saw my truck was leaking at the T-case fill plug. When I tried to tighten it, it just spun. I got it out, and found the threads of the plug packed with...something metal, which I was able to spin off of the threads. I will try to post some pics soon.
Now I need to repair this. Does anyone know if the fill plug is heli-coiled? My thought was to tap the threads, and put is a M18 helicoil. Finding one that size has been tough though...
JT
Joshua993 is offline   Reply With Quote
Old 06-12-08, 10:31 AM   #2 (permalink)
Trapper50cal's Avatar
IF its
If it's just a plug (for the filler hole?) just tap it out to the next size, IMHO a helicoil job isn't really needed if its not supporting anything
83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB Bumper-LONGFIELDS-35" MTR's-BILSTEIN 5150/25's-Warn M8000-Ultimate Air-Defender Rack-Rising Sun Roof Clamps-Yukons-Tailgate Storage-Thanks Ige-Groucho-EricS-Corbet-Schmoozer-DurangoDDS-Marlin-Bobby-JimC -Proffitts-WagonGear
Trapper50cal is offline   Reply With Quote
Old 06-12-08, 10:51 AM   #3 (permalink)
Bradfly85's Avatar
JT
I had this very same problem and thank goodness it's only the fill plug. I'm pretty sure there isn't a coil that big, but I did find something else that may work...try this site... Over Size and Repair Oil Drain Plugs . I ended up just wrapping mine in thread tape and using a small piece of metal that attached where the wire comes out of the T Case to hold pressure on it so it would never fall out. Sounds crazy, but I haven't had a leak or any issues. I'd take a picture for you, but it's been at the tranny shop for months...not due to the above mentioned fix
1988 Royal Blue FJ 62 sittin' on 15" black crawlers with 31X10.5 used tires, murdered out grille and a 2.5" Hell Creek Suspension lift...1996 80 Factory Lockers front and rear...2007 Taco Double Cab TRD Sport debadged
Bradfly85 is offline   Reply With Quote
Old 06-12-08, 11:09 AM   #4 (permalink)
OlympiaFJ60's Avatar
HERE (<--link) is what I did. There are several posts here and the 40 section about peoples different methods of repair (IH8MUD™ Forums - Search Results)
OlympiaFJ60 is offline   Reply With Quote
Old 06-12-08, 11:12 AM   #5 (permalink)
Bradfly85's Avatar
Awesome!! Thanks!!
