LinkBack (6) Thread Tools Display Modes
Old 06-08-08, 09:58 AM   #1
CaliCruiser's Avatar
TLCA# 15987
My H55F/Toybox install thread
It's coming down to the wire for Rubithon, so I figured if I started this thread I would push harder to get it done. The h55f/toybox/split case is fully assembled. I need to split it apart one more time to apply some grey silicone between the h55f and toybox.
Yesterday I modified the factory transmission cross member to clearance the front drive shaft.
I bent up some 1/4" x 5" flat plate steel for the new cross member piece.
I ran a grinder along the cut lines and then bent the sheet in a vice to keep it one piece. It is a lot simpler than tacking three individual pieces together and keeping them square.
First side ground out and ready.
both sides mocked up.
Internal seems welded up.
Gussets on the outside .
Welded up the entire thing. Let it cool. Then cut out the factory piece of the cross member. The finished product.
'85 FJ60 | SOA | ARB | M8274-50 | Sliders | Aussie'd | H55F | 4.7 Toybox | 4.88s | Custom Crap
CaliCruiser is offline   Reply With Quote
Old 06-08-08, 10:01 AM   #2
Butt Ugly Chuck's Avatar
TLCA# 18371
Nice fab work!
Butt
7/85 FJ60 261k miles
91 Haro Extreme AL MTB - daily rider
16' Aire Jaguarundi
Butt Ugly Chuck is online now   Reply With Quote
Old 06-08-08, 10:02 AM   #3
TLCA# 15987
Todays project is the twin sticks for the split case. I should have some pictures of that tonight. If I finish that then I'll pull the center console and mock up where the hole for the toybox shifter will come through.
Here is a shot of the assembled Toyota gears.
Old 06-08-08, 10:25 AM   #4
klinetime574's Avatar
Dang Dylan.
I'm drooling. Nice Fab work
1984 FJ60, 170 Thousand Miles, OME, 33x10.5x15 BFGoodrich All-Terrain T/A KO, 15x8 Eagle 058 Alloys
klinetime574 is offline   Reply With Quote
Old 06-08-08, 12:16 PM   #5
mel lowe's Avatar
Ding dong dang!
Awesome set up
82 Fj60 TurkeyWizz THXAL
88 BJ62 Family Truckster
http://nfcruiserheads.org/forum/index.php
mel lowe is offline   Reply With Quote
Old 06-08-08, 12:22 PM   #6
Dirtgypsy's Avatar
TLCA# 17541
I love it. Do you have a thread of the issues of putting it together?
Also could you measure the distance between the shifters?
Rock on bro,
clint
It's a Jeep thing I didn't understand. So I bought an FJ60 and now I get it.
1987 FJ60, 2F, H55F, 4.11's, Rear ARB locker, ARB bumper, MAF Safari 4" SR, 33 12.50 15 on old school Mags.
ROTW: http://forum.ih8mud.com/60-series-wa...lver-60-a.html
Dirtgypsy is offline   Reply With Quote
Old 06-08-08, 09:44 PM   #7
TLCA# 15987
Ok twin sticks are 85% done. I still need to crawl underneath and check out how the tunnel slopes so I can figure out the angle for the actual shift lever. It may not look like much, but this took a really long time and ate most of the day.
Here they are mocked up on the bench.
I didn't like the angle of the right hand linkage so I ended up cutting it up and reseting it closer to the inside piece.
I pulled off the hi/lo lever and ground a flat spot 90 degrees from the factory flat spot to move the lever. Now it operates in the forward-backward direction as opposed to the side to side factory movement. If you do this make sure when you pull the lever of, that you clamp a vice grip onto the shaft, otherwise that shift rail can FALL INTO THE SPLIT CASE and you have to pull the case apart.
Here are few shots of the linkage mocked up. The threaded rod will get jam nuts up against the heim joints and the brackets will get painted.
Old 06-08-08, 10:06 PM   #8
TLCA# 15987
Rock on bro,
clint
No, I didn't start a thread on the assembly because I ended up not doing that part of it myself. I attempted to do it, but there were simply to many variables to get 100% correct. I can say that Marlin is aware of the entire assembly process now, because he did this one. I'll save the details for Marlin to disclose, he took lots of pictures and I *think* plans on making some instructions. PM if you have any specific questions.
I'll grab the shifter measurement tomorrow after work, when I'm back in the shop. Thanks for comments guys. Lemme know if anything looks funky.
Dylan
Old 06-08-08, 10:10 PM   #9
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Daaaaamn. Good work. So is it in yet?
keep it coming. Looking forward to how it all goes.
See you next week.
edit: will you do my cross-member?
Andrew
1997 FZJ-80 Driveway queen
Old 06-08-08, 10:30 PM   #10
TLCA# 15987
Ya I just picked it up and walked it over to my 60 and threw it in
I need to get it in by Tuesday or so, to measure for drive shafts and maybe take it for a quick spin on the weekend.
I still need to:
-complete twin sticks
-cut a hole for the toybox shifter
-install it
-find a boot for the toybox shifter
-find someone that has a twin stick boot in stock
-drive shafts
-clearance the area around the transfer case at the back of the tunnel
. . .thats enough to think about
Dylan
Old 06-08-08, 11:34 PM   #11
chicago's Avatar
Bad ass big D!
Youve done a beautiful job man!
Chicago
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Fairly built)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS! Life long DISAPPOINTMENT!
chicago is offline   Reply With Quote
Old 06-08-08, 11:42 PM   #12
chappysfj40's Avatar
TLCA# 9188
what run you on? iam on the wagon run see you on the trail reguard less
great work
- Iam home now from the SUCK !!!!!!!
VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!!
- RUBITHON 2008 TESTED
GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7..
chappysfj40 is offline   Reply With Quote
Old 06-09-08, 12:03 AM   #13
NocalFJ60's Avatar
Awesome work Dylan. I like how your crossmember turned out. Try Marlin on the toybox shift boot.
1982 FJ60
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 06-09-08, 10:08 AM   #14
Hudson's Dad
LCOwner's Avatar
Marlin has both.
If you’re not part of an organized volunteer group working on the trails, YOU are the problem.
LCOwner is offline   Reply With Quote
Old 06-09-08, 03:55 PM   #15
GLTHFJ60's Avatar
TLCA# 17825
That is exactly the set up I plan on running in my rig some day. Beautiful work, and I can't wait to see it all buttoned up!
1987 FJ60 - MoonShine - 62 springs, add-a-leaf, 33's, KMR's Tailgate Hatch, desmog + headers, storage / sleeping system, etc. -- 228k miles
Waiting to be installed:
FF w/ 4.11s, York 210 OBA
"Fluids have a purpose,
Liquids are just there..."
-TJP
Originally Posted by REKCUT View Post
P.S. OMG someone call the cops, there is a guy abusing his sixty by turning circles. We need to take his truck away.
GLTHFJ60 is offline   Reply With Quote
Old 06-09-08, 06:41 PM   #16
TLCA# 15987
Originally Posted by LCOwner View Post
Marlin has both.
Oh, I didn't see the twin stick boot on their website. The single is 55 bucks? Ouch, I am out of cash. It may be a boot-less Rubithon, hopefully the water isn't too deep.
Dylan
Old 06-09-08, 08:40 PM   #17
Dirtgypsy's Avatar
TLCA# 17541
nice work here is an alternative. not bashing marlin's stuff but these are very well made:
JB Custom Fabrication: Shifter boots
clint
Old 06-09-08, 09:55 PM   #18
TLCA# 15987
Thanks for the link Clint. Center to center on the shifters came out to be about 11 and 1/4".
Old 06-10-08, 10:44 AM   #19
Dirtgypsy's Avatar
TLCA# 17541
your welcome and thanks for the measurment.
clint
Old 06-10-08, 11:18 AM   #20
weak-link's Avatar
done yet?
www.4x4Him.com
Pit Bull Rescue Central
http://www.pbrc.net/
weak-link is offline   Reply With Quote
Old 06-11-08, 11:41 PM   #21
TLCA# 15987
Ok, I just got in from installing the transmission and crossmember. I just was not up to installing the toybox-split case setup so that is going to happen tomorrow night. Now that the transmission is in I can get the angle of the twin stick shift lever. I figured I better wait so I didn't weld them on at the wrong angle. I don't have any pictures because my dad has the camera but proof will come tomorrow night.
Dylan
Old 06-12-08, 08:25 AM   #22
DBOZ40's Avatar
Bell Housing
Did you have to grind the bell housing, or did the H55 slide right in?
'78 Fj40
DBOZ40 is offline   Reply With Quote
Old 06-12-08, 09:48 AM   #23
TLCA# 15987
Wow that is funny you asked that, almost like you were underneath it too when I realized I forgot to grind out a spot for the new wider h55f front cover plate.
Dylan
Old 06-12-08, 11:48 AM   #24
chicago's Avatar
Dude...
I might be hitting you up with the x member and linkage fab for mine when the time comes!
That came out really frickin awesome!
Cant wait to see the completed pics!
Im a bit nervous as to how my set up is gonna come together when I have all the pieces in place!
Chicago
TLCA#16202, KE7VAT
Toyota family:
Old 06-12-08, 05:48 PM   #25
vipergrhd's Avatar
awesome job
that thing looks killer man,wish i could weld like that. john
If i can't fix it i don't buy it.if it cost too much to fix then trash it.
87 fj60 mostly stock at this time
93 toy hi-lux 4x4 extra cab w/camper shell also stock
95 mitsu montero sr w/ rear lockers (wife's suv)
99 mitsu galant gtz (wife's DD)
vipergrhd is offline   Reply With Quote
Old 06-14-08, 01:46 AM   #26
TLCA# 15987
IT'S IN!!!!!!!!!!!!!!!!!!
The drive train is fully assembled an installed. It is definitely a tight fit, but everything fits with a little clearance. I do not have a body lift so that made the install even a bit more challenging. After I spent a bunch of time trying to install it with the transmission and crossmember installed, I ended up pulling the crossmember and letting the transmission droop down a bit to give me a better approach angle into to align the output shaft and input coupler. I'm tired so here are some pictures. . .
Old 06-14-08, 06:19 AM   #27
KI6MIE
TLCA# 11734
Awesome-so we'll see you Wednesday morning.
Where did you get that output flange for the t-case? It does not look stock.
Does it really fit without hitting the body at the back of the tunnel?
Andrew
