Old 05-30-08, 06:16 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Randy88FJ62's Avatar
Writeup: 1988 FJ62 4WD Solenoid fix for $17.77
/ Problem: 4WD light stays on.
1. Check the front driveshaft under your car. If you press the 4WD button to the off position in your car and you can't turn your front driveshaft then your solenoid is probably burnt out.
4WD VSV Replacement: Toyota P/N 88690-89132
Part Name: Valve Assy, Magnet
Price from CruiserDan: 17.77
No Discount Price from Toyota: 23.70
This part is off a 1988 Toyota Pickup. It's off the 22R Engine.
Tools Needed:
1. 12 mm wrench or socket. (unbolt VSV bracket from firewall)
2. Screw driver (remove bad VSV from bracket)
3. Angle grinder or file or hack saw (modify metal notch on VSV to fit original bracket.)
4. File, pocket knife, or razor blade (remove connector lip to fit original clip)
For reference: VSV = Vacuum Solenoid Valve
Steps to repair electronic 4WD in an FJ62 (mine is a 1988)
1. Remove Bad VSV (red one) This picture shows the passenger side firewall. You need a 12 mm wrench to remove the bracket. Unclip the wires and hoses. Make sure to label everything or keep it half hanging and connected like I did.
2. Unscrew the new bracket from the new VSV. We don’t need it. Also, take off the 2 hoses that come with the new VSV as well (not shown in pics)
3. Now we need to modify the new VSV before it will fit. Compare the two VSV’s and it’s obvious that we need to trim the metal tab on the VSV and remove the lip off the new electric connector. I had already trimmed mine prior to this picture so use your imagination.
This second picture shows the two metal tabs. They are different sizes. The new one is too big and needs to be trimmed down.
Wear safety glasses and use proper tools and techniques. Don’t stab yourself with a pocket knife while trying to remove the electrical connector lip. Point is, be safe.
4. Now that you’re new VSV is modified; check to see if the electrical connectors fit. Also check and see if the metal tab on the VSV fits into the firewall bracket you unbolted. Connect up the proper hoses. The vertical hose coming straight out the old VSV is the Vacuum line one. The new VSV Vacuum line is the one on the outside. I hadn't trimmed the metal tab yet, so again, use your imagination. Sorry for the lack of proper pictures.
5. Attach everything and don’t worry about sucking on the tube or switching hoses anymore! I have only just installed this. ***DISCLAIMER: Worst case scenario this VSV may burn out early. Who knows, maybe it’s not supposed to be used for this. I hold no responsibility for you trying this. I tried it and it works but I cannot guarantee for how long. My guess is that everything will be ok but I’m just letting you know, do this at YOUR OWN RISK.***
Keywords: four wheel drive solenoid, VSV, vacuum solenoid valve.
Randy88FJ62 is offline   Reply With Quote
Old 05-30-08, 11:04 PM   #2 (permalink)
FJ60Cam's Avatar
TLCA# 16341
Nice find!
This would probably work good for the AC idle solenoid in the 60s.
Cameron Mosley
'85 FJ60 - Daily Driver
FJ60Cam is offline   Reply With Quote
Old 05-30-08, 11:45 PM   #3 (permalink)
beauty school dropout?
RockDoc's Avatar
TLCA# 18148
Thanks for posting this up, I'll have to pick one up for a spare next time I'm grabbing some OEM stuff.
[ ][ ]=TOYOTA=[ ][ ] - 3FE and rust - Wobble Wagon
[ ][ ]=TOYOTA=[ ][ ] - 2FE and no rust, in the works
Edmonton area Cruiser Corner
Peace Canyon Toyota Swamp Donkeys
Today's lesson: You can't teach others, you can only facilitate their learning.
RockDoc is online now   Reply With Quote
Old 05-31-08, 07:21 AM   #4 (permalink)
Ridin Dirty
Bomar's Avatar
TLCA# 17198
Someone needs to put this under FAQ
sixty deuce
94 KZ Runner
Bomar is offline   Reply With Quote
Old 05-31-08, 07:53 AM   #5 (permalink)
PhilC64's Avatar
TLCA# 17885
Excellent find and write up Randy!
74 FJ40 - Now with 2F and explosives.
89 FJ62 - nicely modded
07 FJC - basically stock
PhilC64 is offline   Reply With Quote
Old 05-31-08, 12:50 PM   #6 (permalink)
I'd like to make a more official writeup that is cleaner to put on the FAQ but this is a good start to help those of us with electronic 2WD to 4WD .
Old 05-31-08, 12:54 PM   #7 (permalink)
Originally Posted by FJ60Cam View Post
Nice find!
I assume this VSV will work for most, including the AC idle up. The question is how much modification will be needed for the connector or bracket.
Old 06-04-08, 03:02 PM   #8 (permalink)
Is everyone sure the part number listed is correct? I called Toyota with the number and they said the cost was about $225 and the nearest one was Japan.
2001Slayer is offline   Reply With Quote
Old 06-06-08, 08:27 AM   #9 (permalink)
I can scan or take a picture of the receipt if it will help.
Old 06-06-08, 08:29 AM   #10 (permalink)
Make sure to ask for this off of a 1988 toyota pickup truck. The ones for the land cruiser cost more because they were made in low quantities whereas there are way more tucks so production cost was lower.
-Randy
Old 06-06-08, 11:50 AM   #11 (permalink)
jts560's Avatar
Good write up, thanks.
1988 FJ62
jts560 is offline   Reply With Quote
Old 06-06-08, 03:20 PM   #12 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
It's in the FAQ.
Mike S
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 06-16-08, 03:11 PM   #13 (permalink)
JMRINS's Avatar
TLCA# 18861
The origional bracket can also be used, just take your time pinching the four lock "V's" back together and slide out. New valve will seat just a touch higher within bracket, but still fits. Seperate "V's" again to lock in place. Either way, great fix!
JMRINS is offline   Reply With Quote
Old 06-17-08, 10:34 AM   #14 (permalink)
Mud_Guppie's Avatar
TLCA# 2394
I just called the local dealership that I deal with,
Their price is $227.30 list (in Canadian dollars)
I'm guessing a serious typo is happening somewhere
Look at the part, the number if pieces in it, the function it performs and remember it's coming from a dealership. Do you think $23 is right?
Steven T.
EBI Cruiser Parts
www.extremebends.com
body panels in stock
Mud_Guppie is offline   Reply With Quote
Old 06-17-08, 10:41 AM   #15 (permalink)
Call cruiser dan. He got it "special ordered" for me for $17.77.
Old 06-17-08, 10:43 AM   #16 (permalink)
This is the second comment from a Canadian user that has had this problem with price...
Try Cruiser Dan and check back in.
Old 06-17-08, 10:44 AM   #17 (permalink)
505 823-4440
Cruiser Dan @ NM Toyota Quote
Old 06-17-08, 10:46 AM   #18 (permalink)
Crusier Dan will be gone until Tuesday, he's going to be in the Rubicon....
Old 06-17-08, 02:12 PM   #19 (permalink)
I hooked up my battery last weekend backwards and blew the fusible links. I just got it running again and noticed that my 4WD light stays on. I just ordered another one from my local Toyota Dealership in California without discout and it was $27....
Old 06-20-08, 11:55 AM   #20 (permalink)
chicago's Avatar
TLCA# 16202
Just got finished with this STUPID EASY mod!
Took me all of 10 min. start to finish.
The hardest part is grinding down the metal tab if you wanna get all technical and precise about it. Id recommend using a dremel to make it precise. I used an angle grinder....wasnt the prettiest, but it worked.
Thank you sooo much for pioneering this. Its saved me a BUNCH-O-CASH!
Chicago
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Sold to a good home. Goodbye old friend!)
76 FJ40 (Blotch rig part deux)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS!
chicago is offline   Reply With Quote
Old 06-20-08, 01:18 PM   #21 (permalink)
You're welcome. I just took the idea off ih8mud and did a write-up. I'm not sure who we should thank for the initial idea.
Old 11-12-08, 12:00 AM   #22 (permalink)
stash12's Avatar
Garage
Good info thank you. When i click my 88 fj62 in h4 it engages all four wheels are locked in, but when i go from h4 to l4 4wd doesn't engage i only have the rear wheels working. The 4wd display lights up and then turns off during shifting to h4, can you help me out please.thanks.
stash12 is offline   Reply With Quote
Old 11-12-08, 08:35 AM   #23 (permalink)
I have never heard of the 4wd light going off when going from low to high. The vacuum solenoid valves hold it in place until you manually push the button. Get under your truck while it is in park and the parking brake is on. You will know you are in 4wd hi and 4wd lo if you can not turn the front driveshaft with your hand.
Please clarify your question for me.
Rig: 88 FJ62, DD: 2006 Mazda Speed6 Turbo
Support Mud Vendors:
http://www.marksoffroad.net/index2.html
Old 11-12-08, 10:58 AM   #24 (permalink)
Just ran over this post by Spook50.
Originally Posted by Front Range 4x4
I never knew this - if this is the case why the solenoids?
I'm pretty sure it's in the case. Either that or connected to the mechanical linkage in one way or another. The switch allows current to go to the 4WD solenoid when you shift into low range, hence automatically shifting to 4WD at the same time......as long as the solenoids are working
http://forum.ih8mud.com/60-series-wa...n-writeup.html
Seems that you may have some connection problems at the tcase, either mechanical or electrical.
Old 11-12-08, 05:32 PM   #25 (permalink)
stash12's Avatar
vacuum selenoid
thanks for replying. when i click on the H4 button my 4wd display lights up and all 4 WHEELS are locked in , then when i switch from H4 TO L4 THe 4wd light display turns off and only my rear wheels are locked in , basically i have no 4 wheel drive when switching from h4 to 4L. thanks.
Old 11-12-08, 05:50 PM   #26 (permalink)
stash12's Avatar
i'll get under my rig and try the hand turning the shaft thanks.
Old 11-12-08, 06:25 PM   #27 (permalink)
DirtyLittleSecret's Avatar
Thanks for the thread. Ordered three (replace both with new, and got a spare). Will be in tomorrow!
1988 FJ62 (Toylet): LT1, 4L60e, IPOR seats (heated), 3" OME HD w/ 4+ Ubolt flip, 1" BL, 33x10.50 BFG KM's, Longfield 30 SS, PP Rears, Aussied, ARB/Warn M8000/HID's, TG sliders, RL harness, Thule box, and a 125 lb. Bouvier des Flandres.
DirtyLittleSecret is offline   Reply With Quote
Old 11-12-08, 06:47 PM   #28 (permalink)
stash12's Avatar
if you don't mind me asking, where did you buy your vsv's from. thanks.
Old 11-12-08, 06:58 PM   #29 (permalink)
Front Range 4x4's Avatar
TLCA# 15452
The switch allows current to go to the 4WD solenoid when you shift into low range, hence automatically shifting to 4WD at the same time......as long as the solenoids are working.
Maybe I'm being incredibly dense but what's the purpose of the 4WD button if shifting activates the solenoids?
Chris - http://frontrange4x4.com
1988 FJ62 - Emily - 260,000+ miles, FJ60 Round Eyes, H55F, SUA, SR, OME Heavies, 35x12.5's, trimmed fenders, Solid Rock Off-Road bumper & sliders, rear locker, Warn xd9000i, dual batteries, OBA, Scion radio, etc.
Front Range 4x4 is offline   Reply With Quote
Old 11-12-08, 07:15 PM   #30 (permalink)
t
Went to my local Toyota dealership (Gresham, OR). Will have them tomorrow.
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/224061-writeup-1988-fj62-4wd-solenoid-fix-%2417-77-a.html
Posted By For Type Date
FJ60 and FJ62 FAQ ********* start here and come back often ********* - IH8MUD Forums This thread Refback 03-06-09 08:58 PM
