Old 05-21-08, 03:30 PM   #1
alaska60 is on a distinguished road
rear differential is banging when I take off!
Is anyone familiar with this? I am certain I will need to pull the 3rd member to find out what this is. Any comments before I go elbow deep?
alaska60 is offline   Reply With Quote
Old 05-21-08, 03:32 PM   #2
Front Range 4x4's Avatar
Front Range 4x4 is on a distinguished road
The only thing I'd suggest before getting elbow deep is to stop driving it until you find the problem.
Chris - Front Range 4x4
1988 FJ62 - Emily - 250,000 miles, rust free awaiting an H55F
1968 FJ55 - Clarence - Unknown miles, not rust-free and now for sale: http://forum.ih8mud.com/fj55-classif...fj55-sale.html
Front Range 4x4 is offline   Reply With Quote
Old 05-21-08, 03:43 PM   #3
gaylon's Avatar
gaylon is on a distinguished road
Are you sure it is in the diff and not the rear shaft needing to be greased?
'00 LC - OME Lift, REVOs, Group 31 AGM Marine Battery.
'85 LC - OME Dakar Lift, 33" BFGs, ARB roof rack, bull bar & connected slider steps. Tuffy Console.
'92 M101 Trailer
'87 LC - Parting out now - what do you need?.
gaylon is offline   Reply With Quote
Old 05-21-08, 03:47 PM   #4
I havent pulled it apart yet as I have never heard this before today. low Greased axle will do this???..... it sounds like it is slipping for a split second and....bang! it engages.
Old 05-21-08, 03:49 PM   #5
The drive shaft has new ujoints as well as plenty of grease in the yoke and joints.
Old 05-21-08, 03:59 PM   #6
I guess I should state that it only bangs once and then it runs fine. when I stop it does it all over again. One bang and off we go!
Old 05-21-08, 04:10 PM   #7
Trapper50cal's Avatar
TLCA# 15812
Trapper50cal is on a distinguished road
check
Check for play in the driveshaft at the rear as it leads to the third member.
Do you have an auto locker like an Aussie or Lockright?
Pinion nut, flange bolts, inner splines on axles or axle, improperly toleranced locker install. retainer clip failure. Ring or pinion gear tooth damage.
Somebody smarter widdle this list down a bit??
83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Thanks Ige!
Trapper50cal is online now   Reply With Quote
Old 05-21-08, 04:12 PM   #8
inkpot's Avatar
TLCA# 10338
inkpot
Howdy! Sounds like you need to drop the rear DS and test the pinion bearing preload by rotating the flange back and forth. You may have to put a lot of torque on it to see if it is creeping in and out of the nosecone of the diff. That's a bad sign if it is. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 05-21-08, 04:35 PM   #9
BillyGHusk's Avatar
BillyGHusk is on a distinguished road
did this new noise coincide with the new ujoints?
Did everything get marked so when the new ujoints were installed the shaft went back together correctly?
just a thought...
Tim
85 FJ60 powered by a 3B(dreaming and planning for turbo)
Daily driver
BillyGHusk is offline   Reply With Quote
Old 05-30-08, 03:59 AM   #10
Darkrealms's Avatar
Darkrealms is on a distinguished road
Last time I heard something like what your describing it was replacement gears that fixed it.
When starting it bangs like its not aligned but the bang aligns it. Around a turn it bangs like the shift miss aligned it and it had to "bang" to realign.
If thats what it sounds like, I'd say its time for new gears in the 3rd member.
My Rigs
Originally Posted by dieselcruiserhead
Read this article if you haven't yet, it specifically discusses cut & turns....
http://www.ih8mud.com/tech/soa/index.html
Darkrealms is offline   Reply With Quote
Old 05-30-08, 11:43 AM   #11
lehiguy is on a distinguished road
I had an FJ40 that did this. Turned out to be spiders and the shaft thtat were buggered, the ring and pinion were fine. Take off the cover and have a look.
1985 FJ60, 300HP SBC, NV4500, NP241, 14-bolt semi floater, 4.56 gears, four wheel disk brakes, 35" BFGs, 350,000 happy miles and still going.
lehiguy is offline   Reply With Quote
Old 05-31-08, 10:13 PM   #12
Applesauce
HighPlainsDrifter's Avatar
TLCA# 16853
HighPlainsDrifter is on a distinguished road
x2 only on a buddies 10 bolt in his chevy pickup.
HighPlainsDrifter is offline   Reply With Quote
Credit Cards | Loans | Loans | Car Insurance | Advertising
