Mors Ab Alto
Oil recommendations
I was curious if would be advantageous to switch to a synthetic motor oil in my 140,000 mile '89 FJ62. I have been running a regular high mileage oil to this point. I am open to suggestions on either syn or regular motor oil !!
![]() ![]() __________________ 1989 FJ62 2001 UZJ100 2003 MBz CL55 AMG 1991 Range Rover ~ What do I know ? I have a Range Rover and I still like Oasis !! ~ |
Also curious
Also curious to see what the powers that be will say...
I've been running reg. 10/30 __________________ 83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Thanks Ige! |
I think there are two main camps when it comes to this debate.
Side A: The extra cost of synthetic is by no means justified in a 20+ year old engine. You will develop leaks when you start running synthetic . Regular oil changes when a good quality oil are all you need to do. Side B: Any thing I that can be done to increase the life of my baby is worth doing. If some leaks develop fix them I am in camp B. I also have a 3B with about 85,000 miles on it. I think the main think to consider in asking this question is the age of the engine and can you afford synthetic. Tim Just my $.10 worth..........inflation.... __________________ 85 FJ60 powered by a 3B(dreaming and planning for turbo) Daily driver |
No, I don't think so. I run synthetic in one of my cars (supercharged pontiac with 22,000 miles), 5000 mile change interval. I run Rotella in the other cars. 10W 40 in the Cruiser, 15W-40 in the oil burning town only driving car.
I will say that with the Rotella, I saw no wear after 8000 miles on the camshaft and lifters. The surfacing grind marks were still there. I would run synthetic if: It was a high performance engine it was a high revving engine it sits not running for more than 9 months at a time I wanted extended change intervals That is my $1.50 __________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup |
Just try and git it.
My engine builder said newer oils have removed a lot of the pressure-wear additives necessary for flat-tappet engines. Modern engines with OHC don't need them, and also for smog reasons.
Run an oil (like Rotella T) that's certified for BOTH gasoline and diesel engines. Those contain the pressure-wear additives. There are both synthetics and dino oils with diesel/gas certs. Rotella (shell) makes one, but I've found it hard to find the full synthetic Rotella T . Frequent changes is the key -- Consumer Reports tested this a few years ago. |
You don't think so what?
damn, cost of living has hit you harder than me... ![]() __________________ 85 FJ60 powered by a 3B(dreaming and planning for turbo) Daily driver |
I don't think its worth the money to run in an old engine. I don't think you'd see any benefit from switching at this point.
Full Synthetic Rotella is available at Wal*Mart here. __________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup |
I don't get to Wallyville, much, but if it's available there, that's what I'd prolly run, but only on a low-mileage or rebuilt. A motor with 100K + , what's the point?
#9 | |
Tim __________________ 85 FJ60 powered by a 3B(dreaming and planning for turbo) Daily driver |
#10 |
Howdy! I have just under 200,000 miles on my 350, and just over 200,000 on my 22RE. Both run fine, pass emissions, have only trace metals on the drainplug magnets, and both have only minor damp spots due to oil leaks. There are 3 high problems to avoid on engines: High RPM, High temperature, and High mileage between oil changes. Both engines have run only name brand dino oils. After 80,000 miles on my wife's van, I quit running synthetic. It is not worth the extra $$$ to me. I would rather spend the $ on more frequent oil changes. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
#11 |
impervious to subtlety
I'm not as up on it all as some of the 80s guys (look there for a ton of info and debate) but I think the add-pack is more important than whether the base-stock is syn or conventional. I used to run Mobil 1 10w30 year round, now I run Rotella T conventional 15w40 summer and Rot T syn 0w40 winter. Lots cheaper, and I suspect much better in terms of additives.
__________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Want better headlights? Semi-professional David Cross impersonator |
#12 |
Mors Ab Alto
Ok, here is another thing that I would like to address as we are on the oil topic.... I only put about 5--7K miles per year on my 62. So, I guess that would be considered low. It is not my primary DD but it does get driven pretty frequently. On a vehicle that is driven that amount of miles, what oil change intervals should I go with ?? BTW, as of right now, I have 0 leaks from the rig. I have had some things worked on (pertaining to leaks) the past yr: valve cover gasket, oil cooler line, and tranny pan. But anyway, NO leaks currently. The oil change interval is my main concern. I have been using QState 10W30 High Mileage. To be honest, I have had the rig going on 7 yrs and I have been changing the oil twice a yr, regardless of mileage..Should I be doing changes more often, or not ?? Also, the rig drives great, aside from a somewhat tempermental, slow to shift tranny....
![]() What the devil is Rotella ? Never heard of it... ![]() ![]() __________________ 1989 FJ62 2001 UZJ100 2003 MBz CL55 AMG 1991 Range Rover ~ What do I know ? I have a Range Rover and I still like Oasis !! ~ Last edited by twstrchasr; 05-21-08 at 06:11 PM. |
#13 |
Rotella T is a Shell product marketed mainly as a diesel oil, although it meets spark ignition requirements too. (I learned about the specs here: http://forum.ih8mud.com/60-series-wa...as-engine.html)
I would think changing twice a year is good. Just make sure the truck gets a good run at full temp every so often to drive off fuel dilution and moisture. __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Want better headlights? Semi-professional David Cross impersonator |
#14 | |
Mors Ab Alto
#15 |
Switched to royal purple fully syth after being told about all the leak horror stories, and yet no leaks. My engine did stop making a tapping sound that I used to hear before the switch.
__________________ A hundred times every day I remind myself that my inner and outer life depend upon the labors of other men, living and dead, and that I must exert myself in order to give in the measure as I have received and am still receiving. -Albert Einstein
#16 |
Synthetic lubricates better and leaves a film on engine parts helping prevent engine wear at startup. The Harley guys at work say it runs 10 degrees cooler in their bikes. It's better hands down. It's more expensive hands down. One more benifit is that synthetics do not contain any sulfur. Refineries cannot remove 100% of the sulfur from their product. Sulfur combines with water vapor to form sulfuric acid (icky) which is why you should change your oil periodically despite milage.
__________________ 87' FJ60 stock drivetrain for now...Recaro seats, Grant steering wheel, OME lift and 33x12.50-15 Mickey Thompson MTZ's, Tuffy Console, Thule Rack. PIAA 520s, rust, Optima yellow-top |
#17 | |
what he said
Harley guys pay $1000 for 2 exhaust pipes as well... Is synthetic good? yes... Is it worth it in a tractor motor?? Nope __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#18 |
I don't see anyone using Castrol GTX 10/30. Is there a problem with it? I am thinking of switching to rotella. It is cheaper and they say here it is pretty good.
__________________ 1983 lifted FJ60 should shoot myself for giving it up 1995 FZJ80 should have keep this one too. 1990 FJ62 Ugg- Prefer the FJ60 or FZJ80 1983 FJ60 LOVE MY ""FJ60"" Landcruiser is a beautiful thing even if broken in the driveway!! HOOAH |
#19 |
I've used Castrol in my 60 since I've owned it. It had 200K when I bought it. Has about 340K now. Think I'll stick with the Castrol.
__________________ Cruzerman '85 FJ60 '78 FJ40 |
#20 | |
TOUCH OF GREY
![]() ![]() __________________ HAT I CAME I SAW AND I CONQUERED What A Long Stange Trip It's Been
#21 |
what he said
I have used castrol 20/50 for a very long time. I am only switching because I buy Rotella by the gallon for Diesel oil changes.
Makes life easier only having one type of oil around the house.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#22 | |
![]() __________________ 87' FJ60 stock drivetrain for now...Recaro seats, Grant steering wheel, OME lift and 33x12.50-15 Mickey Thompson MTZ's, Tuffy Console, Thule Rack. PIAA 520s, rust, Optima yellow-top |
#24 | |
I've run synthetics in everything I've owned - going back to the introduction of Arco Graphite, - including Air Compressors, Lawn Mowers, and weed whackers. But in the cruiser I will run Rotella T (when it's running ). That's just what I think is best, not necessarily the "Best" oil out there. |
#25 |
