1989 FJ62, what are some common issues that one should know about?
I just got a really nice '89 FJ62 with 175K, I plan on doing the basic tune up stuff like plugs, wires cap, rotor. I might even take it to AAMCO and have them check everything out. Is there anything else I should keep my eyes on or have checked before I put this rig on the road?
P.S. How do I take the spare tire down? thanks __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
if you have the tool bag, there should be a rod assembly in there to stick thru thewhole between the rear bumper and the tailgate, and crank down......but in your neck of the woods it might be all froze up rusted tight, if it hasn't been used much
__________________ those that fail to prepare are preparing to fail....Benjamin Franklin 1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains 1965/67 FJ45 SWB combining 2 into 1 under construction 1970 FJ55 all stock 1980 FJ40 all stock, factory air and power steering, 82,000 miles |
Yeah...It was pretty seized up... luckly the four bolts holding up the bracket (cross member thing) came loose after spraying them with penetrating fluid and breaking the torque. Now I need to find a spare tire bracket for my roof rack.
Any suggestions? __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
Can I open your beer?
Yes - join the 3FE yahoo group. Everything you have ever wanted to know about a FJ62 with the 3FE engine.
Keep the tranny serviced, and add a tranny cooler. __________________ FZJ80, 3FE40, rtcustoms.net powered FJ62 Austin, Texas Lone Star Land Cruiser - Austin Chapter Cool crap for your cruiser! http://www.cruisercrap.com ![]() TLCA #14710 |
Yeah...I joined earlier today.
Thanks. I just thought I'd ask the folks at ih8mud real quick. __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
DON'T take it to AAMCO! Seriously, they will find thousands of dollars of work that HAS to be done before you drive off their lot. Same with a dealer. Spend time with your new vehicle and let it tell you what needs to be done. Seriously.
__________________ Steve Crase TLCA 10222 1988 FJ62 - Bart 1997 FZJ80 40th Anniversary #3727 - Sandy |
YES...I second what Steve says...
Most of the people on the 3FE group are around here also. ![]() __________________ FZJ80, 3FE40, rtcustoms.net powered FJ62 Austin, Texas Lone Star Land Cruiser - Austin Chapter Cool crap for your cruiser! http://www.cruisercrap.com ![]() TLCA #14710 |
Any of you guys know where I can get a rack bracket for my spare tire?
You want to strap your spare tire to your factory roofrack? I do not think I would do that. That is a lot of weight in a small area.
__________________ '00 LC - OME Lift, REVOs, Group 31 AGM Marine Battery. '85 LC - OME Dakar Lift, 33" BFGs, ARB roof rack, bull bar & connected slider steps. Tuffy Console. '92 M101 Trailer '87 LC - Parting out now - what do you need?. |
#10 |
The FAQ
http://forum.ih8mud.com/60-series-wa...%2A%2A%2A.html And please, don't take it to AAMCO or Midas or (BOX STORE MECHANIC). __________________ A Ron Using one cruiser to go mountain biking, and the other to collect dust. 2F-E Article McNamara gear writeup |
#11 |
Have the #5 oil galley plug replaced. Mine let go at 325k. :(
#12 |
If your spare tire apparatus is/was rusty and no longer operational, I'd suggest you check out the possibility of rust along your inner rear frame rails. This is a common problem area on the 60 series.
__________________ Bret Juneau, Ak 1989 FJ62 3FE 122K 1992 Toy short cab 4x4 22RE 175K |
#13 |
get a second job so you can afford the gas
![]() __________________ J. Graham Seattle, WA TLCA #16405 1988 FJ62, 153,000 miles, Freeborn Red, 33 x 9.5 BFG AT/KO's, alarm system with remote start & kill switch, custom rack. |
#14 |
Amen to the get another job for gas...this gas thing is out of control. I may need to modifiy my cruiser to run on Coca-Cola
![]() The roof rack on my rig is not factory...off hand I don't remember the manufacturer, but I've seen spare tires on roof racks. I always wondered how they mounted on to them. __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
#15 |
"Commom Issues"? Lack of noticable forward momentum when the accelerator is pinned to the floor!
At least in stock format.__________________ '88 FJ62, Turbo/IC, 33x10.50 BFG A/T's, Aussie F/R, AAL, Shock hoops, blah blah blah... |
#16 |
impervious to subtlety
Make sure you give the transmission some attention when you baseline things. Search "Rodney Flush" to see how to change all of the ATF in one go. Synthetic ATF is supposed to run 10-15 degrees cooler, an aux cooler down-flow from the stock one is always a good idea if you live somewhere that sees decent heat. Check the kick-down cable, if it has more than a touch of slack in it, you'll like the difference after tightening it up again. Ditto for the throttle cable from the skinny pedal.
Changing the fuel filter is easy, and the 3FE is supposed to be pretty sensitive to a dirty air filter. Give the intake air chamber and throttle body a good cleaning if they're gummed up, running something through for the injectors would be a good idea (BG44K (?) is said to be the best...). Check the air hose between the throttle body and air flow meter for cracks, they'll let un-metered air in and screw with drivability and power...... __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Want better headlights? Semi-professional David Cross impersonator |
#17 |
Be careful doing a rodney flush if your tranny has never been serviced, it can make crud come loose and screw up your tranny. Its best to do changes at every oil change.
Its a great truck if well cared for. Tranny would be the weak link if there is one, but its tough if maintained. __________________ '93 FZJ 31K original miles and stock...for now. '89 FJ62 - 4" Alcan, 33" BFG MT's, 4.88's, Lockright (rear), 4runner calipers, & 3' firestick. IPOR Bumper w/carrier, Cruise control and Lightforce 240's in the garage!(My DD) '97 4Runner SR5 - 4x4, leather, '06 4runner 17" rims, TJM T-15, 3 baby seats. (Wife's DD) '83 FJ60 - DooDoo Brown in and out (parting out) '63 Biscayne Wagon - Kandy Green and Tweed. Family Wagon 3rd row in the garage. LSx swap???? Erskine College Upstate Cruisers |
#18 |
The Rodney flush is a passive flush, IE: it uses the tranny's pump to move fluid. It is not going to stir up or loosen anything, no more than driving the truck will.
It is the ACTIVE flushes you want to avoid. In this case pressurized fluid forces new fluid in. Faster? Sure. Easier? Sure. A fast and easy way to kill your A440F. Do the PASSIVE flush & clean the filter. You may be surprised. Mitch __________________ Mitch Rowland Dallas, Pennsylvania "Take the body off" |
#19 |
Ah, now I know the difference. My fluid was so clean when i finally changed it I dotn think I need to do the rodney flush.
#20 |
They call me crazy88
AMEN...
__________________ Girls you need to join this club ![]() http://www.playhardgetdirty.com/index.html "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
#21 |
what about checking the ATF level...
I know, dumb question.I'm guessing start it up, run the shifter through the gears, put it in neutral and check the dipstick. Is this correct? __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
#22 |
I also think the tranny is supposed to be at operating temperature as well. Other than that, I think you got it.
#23 |
Can someone tell me what the gap is for spark plugs in an FJ62.
I'm gonna change them and I don't have that info. Thanks. __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
#24 |
0.031" or 0.8mm
#25 |
thanks pal...
#26 |
If you post a picture, someone here will most likely be able to help you identify it. Then one of us would be better likely to offer a suggestion for a rack mount for the tire. You can always ratchet strap it down for now...
#27 |
It's no big deal, I see online there are a variety of different universal tire brackets... I'll just do a little research.
Thanks __________________ 1985 FJ60: needs a few things. 1989 FJ62: eye candy! 1993 Toyota Pickup: zero rust! 1985 Celica GT-S convertible: daily driver |
