LinkBack (3) Thread Tools Display Modes
Old 06-18-08, 11:35 PM   #91
freds40's Avatar
My DC Control showed up today
It'll run my Mark VIII fan
freds40 is offline   Reply With Quote
Old 06-18-08, 11:38 PM   #92
freds40's Avatar
Got the input seal replaced on my 465 and got it cleaned up.
Another of the sleeved and turned nose cone in prep for the 3 speed bellhousing.
Old 06-18-08, 11:40 PM   #93
freds40's Avatar
And tonight I got the back end cleaned up a bit. Got the axle pulled and blew the rivets on the spring hangers.
No pic of the new hangers welded on . I moved them 3" back from stock to get the tire a bit further away from the door. Should work out pretty well.
Oh, and I guess I won't be running 3.73s, even temporarily. I pulled the driveshaft and I could see the pinion flange wobbling around. The pinion nut came loose and I'd saw there is roughly 1/4"-3/8" of play. I was rolling when I saw it. I'm interested to get inside and see how bad the third is.
Old 06-18-08, 11:47 PM   #94
freds40's Avatar
And the last one for the night.
I built this 4.7 mini case with a 465 adapter about a year and a half or 2 yrs. back. I never ended up running it nor did the 3 other buddies who had posession of it in the mean time. Now it's back to me and it's going to get run.
So anyway after noisy time ended (I try to knock off about 9:30 to be decent to the neighbors) I started in on the mini case. Got a bit torn down but with no air tools (too loud) I didn't get as far as I wanted.
Old 06-19-08, 12:07 AM   #95
Overlord's Avatar
Originally Posted by freds40 View Post
Dang, if I was a chick you'd have a black eye right about now.
Anyway, I'll try to remember to get a bulgde to buldge measurement tonight.
Did you ever take the measurement?
Sean
'87 FJ60 2.5" BDS lift/+1" shackles/1.5" BL w/ 35 TSLs, FF axle w/ bling bling cable lockers
'94 FZJ80 stock - my DD
Overlord is offline   Reply With Quote
Old 06-19-08, 12:09 AM   #96
freds40's Avatar
No I forgot and I've since put the 31s back on to make it easier in the garage. I'll try to remember when I throw the Iroks back on.
Old 06-19-08, 01:19 AM   #97
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
I'm guessing you are not taking this rig to Moonlight Madness.
D'Animal is offline   Reply With Quote
Old 06-19-08, 06:31 AM   #98
Hudson's Dad
LCOwner's Avatar
Taco axle?
Nice night light princess.
If you’re not part of an organized volunteer group working on the trails, YOU are the problem.
LCOwner is offline   Reply With Quote
Old 06-19-08, 08:55 AM   #99
weak-link's Avatar
Originally Posted by LCOwner View Post
Taco axle?
nope... it'll be way cooler then that, keep guessing
The range box already had a 4.7 and is set up to bolt to a 465. the rear of the tcase will get tossed.
www.4x4Him.com
Pit Bull Rescue Central
http://www.pbrc.net/
weak-link is offline   Reply With Quote
Old 06-19-08, 09:27 AM   #100
Huh? Who me?
PhilC64's Avatar
TLCA# 17885
Barbie does make a nice addition to the shop. Gives me the sense that you're in touch with your delicate side.
BTW Nice build! I've been following it since you started it!
"We are not the base, we are the 2% lunatic fringe." - Ed97Fzj80
89 FJ62 - nicely modded (OME heavy lift and shocks, lunchboxed rear, ProComp M/T's w/ Rockcrawlers, 4Runner front d/b's, de-smogged)
07 FJC - nicely modded (Toytec lift,OME shocks, Digger Link LCA's, Revo's, JBA headers, aFe CAI)
PhilC64 is offline   Reply With Quote
Old 06-19-08, 10:31 AM   #101
freds40's Avatar
Thanks. I'm happy with the progress so far.
BTW, it's Cinderella...........................my daughter hasn't discovered Barbie yet.
Old 06-19-08, 10:39 AM   #102
Hudson's Dad
LCOwner's Avatar
Do you mean the transfer part or just the tail housing?
Old 06-19-08, 02:59 PM   #103
Moby's Avatar
Does the Mark VIII fit with a 2F in the stock location? I tried to fit one on my 3FE but it look like the depth of the fan motor was going to hit the pullery of the water pump. Went with the twin Contour fan instead with a DC Controller (which is working very well).
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 06-19-08, 03:30 PM   #104
freds40's Avatar
Don't know, haven't tried just yet.
I'm thinking I'll be able to make it fit as there is about 1" to either side of the shroud on the radiator and the motor is also offset on the shroud so if need be, I can flip it upside down.
Old 06-19-08, 03:31 PM   #105
freds40's Avatar
Only need the reduction housing so the whole transfer section will be tossed.
Old 06-19-08, 09:13 PM   #106
89s rule's Avatar
TLCA# 14198
using an 80 series rear?
'93 FZJ 32K miles - 850/863's, 285 MTR's & Lightforce 240's waiting.
'89 FJ62 - 4" Alcan, 33" BFG MT's, 4.88's, Lockright (rear), 4runner calipers, & 3' firestick. Cruise in the garage. FOR SALE!
'97 4Runner SR5 - 4x4, leather, '06 4runner rims, 265/70/17 Toyo AT, TJM T-15, 3 baby seats. (Wife's DD)
'83 FJ60 - DooDoo Brown in and out FOR SALE!
'63 Biscayne Wagon - Kandy Green and Tweed. Family Wagon 3rd row in the garage.
Erskine College Upstate Cruisers
89s rule is offline   Reply With Quote
Old 06-19-08, 09:16 PM   #107
weak-link's Avatar
way to easy
www.4x4Him.com
Old 06-19-08, 09:35 PM   #108
Kool Arrow
kling-on's Avatar
TLCA# 15374
WOW super cool ... but you might have to trim the fenders some
82 FJ60 OME Heavy 33BFG's 410's & quicklock ARB bull & side bars and warn 12k down for repairs
85 FJ60 Trail beater SM 420 crawler box lockers 456,38's bobed & choped with a Metal Tech cage
85 SR5 new DD want am I thinkin
GIT-R-DONE!!!!
TLCA #15374
low riders want SWITCHES... 4 wheelers want SHIFTERS
www.jkcustoms.com
kling-on is offline   Reply With Quote
Old 06-19-08, 10:01 PM   #109
freds40's Avatar
The fenders are pretty clean so I was thinking about resetting the locks in the steering box so it'll stop before the tires rub. Turning radius will suck but I'll look pimp @ the mall...........................................:lo l:
No, I actually got a new air saw that I'm itching to test out. Should make short work of the sheet metal.
Old 06-19-08, 10:12 PM   #110
freds40's Avatar
way to easy
I think you're enjoying the guessing game even more then I am.
Old 06-19-08, 10:18 PM   #111
Kool Arrow
kling-on's Avatar
TLCA# 15374
I cut 3 or 4 in outa mine and used 15x12's to get that wide
GIT-R-DONE!!!!
TLCA #15374
www.jkcustoms.com
Old 06-19-08, 10:34 PM   #112
weak-link's Avatar
yes...yes I am
It's best solution to cruiser rear axle's I've ever heard.
www.4x4Him.com
Old 06-19-08, 11:07 PM   #113
weak-link's Avatar
btw my rig didn't end up going. she's all yours if ya want to go play this weekend.
www.4x4Him.com
Old 06-20-08, 08:21 AM   #114
Tapage's Avatar
I saw that you like the fun .. much more widening an axle than buy wheel spacers ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 06-20-08, 08:34 AM   #115
tclndcrz's Avatar
TLCA# 14430
cool build
-Thomas Crumrine
TLCA #14430
88 FJ62 33x12.5 BFG A/Ts, front parabolics, ARB bumper, warn xd9000, 2badfjs sliders, aussie lockers, longfields, durabak, flowmaster, rear disks...
tclndcrz is offline   Reply With Quote
Old 06-20-08, 09:26 AM   #116
redcorn's Avatar
Mopar 8 3/4 rear axle????
if you can cut a Tcase in half with a cheap circular saw you can do anything.
BIG WAGONS RULE
redcorn is offline
