LinkBack (7) Thread Tools Display Modes
Old 05-11-08, 06:47 PM   #1
sp0rk sp0rk sp0rk!
Spook50's Avatar
What the deuce is this thing?
Over at Tonkota's place last week, we were trying to figure out what this brass looking thing on the back of the 3FE intake manifold is. There's normally a plastic gray cap that snaps on over the top of it. On his, the screw in the middle was missing completely, and on mine, it had come completely out (but was kept from being lost by the gray cap). I reinstalled the screw (which has a little black O-ring on it) and snugged it down, and it seems to have increased not only my mileage, but I noticed a decent seat-of-the-pants improvement in power. Felt like there was a noticeable increase in low end torque.
My question is, WTF is it?
'88 FJ62 W/ 240K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, TaskLED domelight, Mallory ignition, and four wheel discs
Some people just can't resist going full retard.
Spook50 is offline   Reply With Quote
Old 05-11-08, 06:53 PM   #2
AATLAS1X's Avatar
I want to say Fuel pressure regulator, but ......Drivers side at end of fuel rail?
Shane
AATLAS1X is offline   Reply With Quote
Old 05-11-08, 06:56 PM   #3
sp0rk sp0rk sp0rk!
Spook50's Avatar
Shane
IIRC the FPR is at the forward end of the fuel rail. I guess it's possible this could have some involvement in it though...
Edit: SOR shows it as a dampener at the "inlet" of the fuel rail. Possibly helping to subdue surges in fuel pressure that the regulator might not be able to keep up with. I could see where that might help with mileage, but with power too? I wasn't even expecting any difference when I reinstalled the screw, but I definitely felt something.
Old 05-12-08, 10:48 PM   #4
sp0rk sp0rk sp0rk!
Spook50's Avatar
Update: Replacing and snugging down that screw definitely made a large improvement in my gas mileage. On average I would get 10-11 MPG if I took I-90 across Washington (Spokane to Seattle and back). This time, even with the extra 475lbs of a slant six sitting in the back of the truck, I got 14.8 MPG.
Considering I was cruising along at 75-77 MPH and had almost 500 LBs of extra weight, I'd say that's a hell of an improvement.
I'm curious to see what it'll get the next time I go across via HWY 2 (which is where I got my all-time best of 17 MPG, probably due to staying between 60-65 the whole way).
So long story short, if you've got a 62 or an FJ80, check for that screw!
Old 05-13-08, 06:14 AM   #5
fuel pulsation damper
'82 FJ40, '88 FJ62, '71 Karman Ghia Vert, '73 Alfa Romeo 2000 GTV
billmc is offline   Reply With Quote
Old 05-13-08, 09:05 AM   #6
tonkota's Avatar
TLCA# 14154
I think I have one in my basement. I'll have to fix that now.
A Ron
Using one cruiser to go mountain biking, and the other to collect dust.
2F-E Article
McNamara gear writeup
tonkota is offline   Reply With Quote
Old 05-13-08, 09:13 AM   #7
sp0rk sp0rk sp0rk!
Spook50's Avatar
Be sure to lemme know if you see a difference in mileage on yours too. I guess that little screw kinda was important, huh?
Old 05-13-08, 10:56 AM   #8
OlympiaFJ60's Avatar
Thanks Spook, one more thing to check out when looking these rigs over.
'87 FJ60 2FTBI, '73 FJ40, '72 FJ55, '66 FJ40, M416A1
www.olympiafj60.net
www.eastolympiacruisers.com
OlympiaFJ60 is offline   Reply With Quote
Old 05-13-08, 10:58 AM   #9
Landpimp's Avatar
TLCA# 5506
where abouts is it? I cant quite pin it down
Landpimp is offline   Reply With Quote
Old 05-13-08, 11:06 AM   #10
sp0rk sp0rk sp0rk!
Spook50's Avatar
Look at your fuel rail, and it's at the aft end of it. It'll most likely have a gray cap snapped over the top of it. Work the cap off by hand and you'll uncover it. Careful though. If yours is like mine, the screw will very likely have worked its way out and can easily get lost.
Old 05-13-08, 11:08 AM   #11
Landpimp's Avatar
TLCA# 5506
ah yes.....that thingy......I think I poped the cap off once for some reason....better take a gander at it
Old 05-13-08, 11:48 AM   #12
TLCA# 11276
X2, FPD.
Andrew
75' FJ-55 (future project)
87' FJ-60 (3FE-H55-Marks gears)
97' FZJ-80 (stock)
01' Taco (stock)
Aseif007 is offline   Reply With Quote
Old 05-13-08, 12:17 PM   #13
takeitforgranite's Avatar
Something tells me this thread is a candidate for FAQ.
_____________________________________________
Yeah, I look like a grandpa driving it, but I still pull chicks.
84 FJ60 - 2F, 301k miles, 4.5" Alcans, 12" Bilstein 5150s, 35x12.5 XTerrains, Blazenoffroad.com winch bumper, magnaflow, rust, and an oil leak!
takeitforgranite is offline   Reply With Quote
Old 05-13-08, 01:23 PM   #14
They call me crazy88
cruiser88's Avatar
TLCA# 17319
Yep it is your damper and that blasted thing is known to leak.
It is reguired to remove the airbox if you need to tighten that thing down. BIG BLASTED METRIC WRENCH.
"how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer
http://s237.photobucket.com/albums/f...13957_15_0.jpg
http://s237.photobucket.com/albums/f...113957_1_2.jpg
Old 05-13-08, 01:57 PM   #15
tonkota's Avatar
TLCA# 14154
I'll check the mileage, but I won't be able to tell you if it was that little screw or if it was the camshaft that I just put in. I also won't be able to confirm a power increase (from the little screw anyway).
I was getting 13 no matter what I tried though.
A Ron
2F-E Article
Old 05-13-08, 02:01 PM   #16
sp0rk sp0rk sp0rk!
Spook50's Avatar
Are we talking about the same part? I can see where it'd be prone to leak, but looking at it, I wouldn't think I'd need to remove my airbox or intake hose at all.
Not that I want to try. The thing looks like a bitch to get to either way...
Old 05-13-08, 02:09 PM   #17
cruiser88's Avatar
TLCA# 17319
There may be a sst tool or something to remove it...i fawked around for over a hour to tighten that thing down with a wrench with no success.
In all honesty you can have the air box off and on within the hour if you are de-smogged.
Old 05-13-08, 02:34 PM   #18
YODA 88 62's Avatar
It started leaking on mine about 6 years ago and is currently leaking. I used the smallest cresent wrench i could buy and managed to get it off without removing the intake. I think i paid around fourty bucks for the damper.
1988 FJ 62- SOA, Aussies front and rear, 30-spline Longs, 4.88s, 36x13.5 Iroks, Marlin hysteer
YODA 88 62 is offline   Reply With Quote
Old 05-13-08, 02:36 PM   #19
cruiser88's Avatar
TLCA# 17319
how. of course i have the biggest hands on the planet so that does not help
Old 05-14-08, 10:19 AM   #20
YODA 88 62's Avatar
It looks like i bent the heat shield out of the way. That gave just enough to get the crescent wrench in.
Old 05-14-08, 10:30 AM   #21
IB14A69's Avatar
Very interesting
I will have to check this out, if my 62 gets any quicker I wont be missing my sti
59 GMC Fleetside 65 FJ45 Lwb 69 Bronco 69 Charger 71 Chevelle 74 FJ55 76 F-250 lifted 77 F-150 lifted 78 FJ40 lifted 81 FJ40 82 Ram 4x4 89 FJ62 93 FZJ80 96 F-350 Powerstroke 97 FZJ80 40th Anniv 05 WRX STI sold
IB14A69 is offline   Reply With Quote
Old 05-24-08, 03:36 PM   #22
sbisig's Avatar
TLCA# 16740
I made the adjustment on my 92 FJ80. It needed a few turns with the screwdriver to tighten it down.
After driving it around home, it seemed to have better low end torque. The true test will be when I head over Snoqualmie Pass (hopefully tomorrow). I have a good baseline from traveling there last week (13.4 mpg gallon from Federal Way to Ellensburg, WA).
Steve
1992 Toyota FJ80 Land Cruiser, OME 850/863, Pin7 CDL, ARB Bull Bar, ARB Touring Rack, Storage Box, Dual Batteries, Winch, FJ Cruiser Wheels, 285/70R-17 BFG M/Ts
Pacific Northwest Backroad Adventures - Pacific Northwest Overland Adventure Blog and Forum.
sbisig is offline   Reply With Quote
Old 05-24-08, 08:45 PM   #23
sp0rk sp0rk sp0rk!
Spook50's Avatar
Steve
I just checked mine again last night while I was gassing up, just for shits and giggles (and to distract myself from the assrape being counted up on the pump) and it was coming out again. So I snugged it down again and noticed the same improvement in power. I figure it's worth checking every time you gas up, just to make sure it's still good to go.
I can't wait to drive across HWY2 and see what kind of economy I get out of it.
Old 05-24-08, 09:01 PM   #24
GAS-A-LOT!'s Avatar
where exactly? got a zoomed out pic?
HELO?....is this thing on?
1991 fj80 's but I drive it, suspension air bags, roof rack, trailer 8pin connection, 7 pin mod, hood spacers & stolen radio. 1985 fj60 (DD)HID-xenon retrofit projectors, tailgate storage, rear seat shoulder belts, 62 rear sway bar, & roof rack. 1987 4runner, seat bracket spacers(4crawler.com), driver side battery, HID-xenon retrofit projectors, & modified/upgraded intake, rancho shocks.
WWW.RONSERRANO.COM
GAS-A-LOT! is offline   Reply With Quote
Old 05-24-08, 09:22 PM   #25
sbisig's Avatar
TLCA# 16740
Look straight down over your engine, all the way to the rear, you'll see the plastic cap (or if lost, see the picture in the first post).
You can pop it off with your fingers.
Steve
Old 05-25-08, 09:55 AM   #26
tonkota's Avatar
TLCA# 14154
I just checked mine again last night and it was coming out again. So I snugged it down again and noticed the same improvement in power. I figure it's worth checking every time you gas up, just to make sure it's still good to go.
The Napa one I bought has a rivet, not a screw. I wonder why there is a screw there? Maybe manufacturing limitations at the time? Who knows.
EDIT:
I have not swapped them out yet, I am getting a feel for the power I have and I wanted to see if there was a power increase with the new part. Plus, I am going to pick up a cheap wrench for modification to change this part out.
A Ron
2F-E Article
tonkota is offline
