| Home | IH8MUD Forum | Photo Gallery | IH8MUD Wiki | CruiserFAQ.com | Technical Links | Product Reviews | Tech Trivia | IH8MUD Store |
very little brakes
I just finished putting longfileds, lockright locker,all bearing and races, seals, calipers, brake lines (hard and rubber).
My brake pedal goes all the way to the floor? have been bled severale times with no luck. anyone have this problem? could it be the master cylinder? |
#2 | |
They call me crazy88
I did that once__________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
yes I bled the back brakes too, I put new calipers on (rebuilt) I bled the brakes w/ the help of a friend foot and then also used a auto setup suction type gun. still no luck. thanks
Look to see if the bleeders on the calipers where they are located on the caliper itself....they should not be on top rather at the bottom. that will make a huge difference.
bleeder position pic
taken a few mins ago. cold and riany outside still trying to figure it out. thanks
here is a pic. |
Yep I would look into the master cy.
![]() __________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
that is what I will do Thanks cruiser88 |
How was the brakes before....full pressure?
before I started the repairs (notheing was wrong except alot of grease and oil) tha brake worked great.
#10 |
um
Did you bleed furthest corner first etc. (pass. rear, then driver rear, then pass. front then driver front)?
all that work and no new felt sweepers??!! IS the resevior remaining full? __________________ 83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Thanks Ige! |
#11 |
bleeder is on the bottom of the caliper,of course you can't bleed it this way it has to be on the top of the caliper in order to release air trap in the system.john
__________________ If i can't fix it i don't buy it.if it cost too much to fix then trash it.![]() 87 fj60 mostly stock at this time 93 toy hi-lux 4x4 extra cab w/camper shell also stock 95 mitsu montero sr w/ rear lockers (wife's suv) 99 mitsu galant gtz (wife's DD) |
#12 | |
bleeding brakes
I bled in this order 1st driver rear 2nd pass rear 3rd driver front 4th passanger front. I have fluind coming from the bleeders, the resevoir is being refield after each wheel is done. I have plenty of pressure from the bleeders. I have good flow I pump the brake and then bleed each one. pedal is hard then after I start the truck the pedal goes to the floor? I think I am screwed dunno? I will keep trying. Thanks |
#13 |
x2 on bleeders being on top....
__________________ _____________________________________________ Yeah, I look like a grandpa driving it, but I still pull chicks. 84 FJ60 - 2F, 301k miles, 4.5" Alcans, 12" Bilstein 5150s, 35x12.5 XTerrains, Blazenoffroad.com winch bumper, magnaflow, rust, and an oil leak! |
#14 |
ok ok ok I am going to kick myself now. I thought they had to be on the bottom. I will change in the morning. thanks guys I feel like a *ss |
#15 |
no I really feel like an *ss
#16 |
Don't feel to bad I did the same exact thing a couple of years ago just swap the calipers, bleed your brakes and you should be fine
.__________________ Benjamin D.Garcia Calhoun, Georgia (Mine) 1988 FJ62, 1985 FJ60(Trail Rig In Progress), 1979 1/2 Ton Chevrolet P/U (Hers) 2005 Nissan XTerra SE 4x4 "May I offer you something to blur your vision" |
#17 |
Cruiser Curmudgeon
The formed steel line to the caliper is still available new from Toy. It's cheap and makes it easy to install (or swap in this case) the calipers.
Just got some last week. PN's are: 47341-60031 47343-60021 HTH __________________ Thanks, Jim C. TLC Performance Underhood Janitor, cleaning up other people's since 1988.
#18 |
i meant top...lol__________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
#19 |
Brakes work
Thanks guys the brakes are working now. new is hydro assist. I hope I can do this correctly.
![]() cruiser88 I figured so. |
#20 |
awesome job man.
![]() __________________ If i can't fix it i don't buy it.if it cost too much to fix then trash it.![]() 87 fj60 mostly stock at this time 93 toy hi-lux 4x4 extra cab w/camper shell also stock 95 mitsu montero sr w/ rear lockers (wife's suv) 99 mitsu galant gtz (wife's DD) |
Life Insurance | Flights | Car Insurance | Personals | Problem Mortgage |
