Old 05-11-08, 05:01 AM   #1
Buffalo is on a distinguished road
Weird 'trickling' noise from behind dash - any ideas?
HI
I have recently noticed that i am getting what i can only describe as a trickling noise that appears to come from behind the dash around the level of the heater controls.
I have moved to a colder part of Australia - we are almost in winter now (very low teens 'c) and so we are using the heater inside a lot more. Previous we were in a climate usually no less than 15'c and average over 25'c so never used the heater.
Typically the noise occurs after i switch the motor on from cold and turn the heater on, then move off. It sounds under acceleration and is as I describe above. After couple of hundred metres (having gone through the gearbox) it stops.
Is it just the water trickling into the heater matrix..? Is it trying to tell me the heater matrix is knackered..? (I am not losing coolant) or is it something entirely different..?
Thanks ~PHIL
'85 FJ62 Aussie model; 3F engine with carb & 5 spd box. Used extensively as a bush-cruiser...
Mods currently on hold until rusty roof is sorted
Buffalo is offline   Reply With Quote
Old 05-11-08, 06:59 AM   #2
Location: Kansas City, MO - pretty much in the Grandview Triangle
chuckirons is on a distinguished road
I've had this happen too, everything seems to be operating fine, it's just the trickling noise you describe. Hope you can get some answers!
'85 FJ60
'02 VW GTI 1.8T
'96 Corolla
chuckirons is offline   Reply With Quote
Old 05-11-08, 07:16 AM   #3
FJ60Cam's Avatar
TLCA# 16341
FJ60Cam is on a distinguished road
Yep, just the coolant flowing through the heater parts. I think I've read that it could be air in the lines... mine makes the noise and it heats just fine and I don't have (engine) overheating problems so I don't worry about it.
Cameron Mosley
'85 FJ60 - Daily Driver
HELP A BROTHER OUT!!! (LANDSPEEDER)
FJ60Cam is offline   Reply With Quote
Old 05-11-08, 08:33 AM   #4
They call me crazy88
cruiser88's Avatar
TLCA# 17319
cruiser88 is on a distinguished road
Check the rad. fluid level......burp the system for air maybe?
Girls you need to join this club
http://www.playhardgetdirty.com/index.html
"how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer
http://s237.photobucket.com/albums/f...13957_15_0.jpg
http://s237.photobucket.com/albums/f...113957_1_2.jpg
Old 05-11-08, 05:53 PM   #5
RredFJ40's Avatar
TLCA# 14992
RredFJ40
It's air in the heater core causing turbulent coolant flow. I've got a very slow coolant leak so it's my warning tone to check the coolant level
Joel
"Birds have nests, foxes have dens but the hope of the whole world lay on the shoulders of a homeless man." - R. Mullins
82 FJ60 - normal stuff
68 FJ40 - gone
88 FJ62 - gone
RredFJ40 is offline   Reply With Quote
Old 05-11-08, 09:48 PM   #6
Would air inthe system make the car run cooler as a whole..? I have been investigating my cooling system as the car is running too cold IMO. This weekend i replaced the thermostat and the noise was worse afterwards, but it was present before.
I don't think i am losing coolant. I haven't had to fill it up in years!
How do i bleed (burp!) the system..?
Thanks. ~PHIL
Old 05-12-08, 12:24 PM   #7
Search 1st, THEN ASK
zuluzeugma's Avatar
zuluzeugma is an unknown quantity at this point
This has been covered 5 times in the last 3 months... Use the search function.
Buffalo, it would probably be a really good idea to change your coolant out if what you say is true about not even adding any in years. A coolant system flush is probably way overdue. You can do it for free with a garden hose or you can take it some place. Either way, a good idea.
72' FJ55 - SOA, SR, DB, FJ62 PS, Webber, Header, H.E.I., 37 X 12.5 X 15 MT/R's, Savanah-heat air freshener.
73' FJ40 - Long term project in the hands of HappyChappy
83' FJ60 - Mint Condition
07' FJC - Atrac Hack - DD
08' Tundra, 4.7 2WD - Company Truck
zuluzeugma is offline   Reply With Quote
Internet Advertising | Mortgages | Bad Credit Loan | Life Insurance | Credit Card
