Go Back   IH8MUD Forums > Toyota Tech Forums > 60-Series Wagons
Old 05-10-08, 08:49 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
swimfan's Avatar
Question about steering.
Ok, i've got way to much slop. Driving 60+ down the freeway I have to fight the car to stay straight. It's impossible for me to hold the steering wheel in one position and have the truck go straight. If the grooves in the road change, the tires will steer themselves moving the truck in whatever direction it wants to go in. It's still driveable, but it's a constant battle where i have to stay very alert. Here's what i've done so far.
Recently went from 29"ish tires to 33" tires. Added OME 3" lift installed by 4wheelparts. Never had a problem with this prior to OME install. 4wheel acknowledged the slop stating the tie rod ends needed to be replaced. I bought some new ones and replaced them. Turning the steering wheel, the tie rod ends are much tighter than they were before. Turns out that that's not the problem. The slop continues.
Here's my other observations. After the tie rod ends didn't fix it, i started looking at the rest of the steering system. I don't have any large amount of knowledge in this area, so i need help. Turning the steering wheel, even the smallest amount, turns the "rod" thing in the engine bay that connects to the steering wheel. Here's where I feel i'm having the problem. I can turn the steering wheel about 1-2" in either direction and the pitman arm doesn't move at all.
I'd just like to get some info on other areas i can check to help figure this out. Bad power steering gear box possibly?
'87 FJ60 160K ARB Front, Roof Rack, 4+plus Rear, 3" OME Heavy, 33" BFG A/T, Limo Tint, 62 Grab Bar
swimfan is offline   Reply With Quote
Old 05-10-08, 10:47 AM   #2 (permalink)
Nemesis Gnat's Avatar
i have the same issue, ill be paying attention
Sept. 1985 FJ60, bike hauler with attitude
Looking for a 2h or 12ht and a h55
For sale:
1972 Buick Lesabre custom
1970 VW Baja bug (street legal)
1984 Toyota pick up (2wd)
Nemesis Gnat is offline   Reply With Quote
Old 05-10-08, 11:01 AM   #3 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! Get the alignment checked out. It may need more toe in, which means the front of the front tires needs to be a little closer together. Or, it may need some a axle shims to rotate the steering axis a couple of degrees. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 05-10-08, 12:42 PM   #4 (permalink)
2mbb's Avatar
TLCA# 6404
the maximum allowable freeplay in the steering wheel is 40mm (1.6 inches), measured at the outer diameter of the steering wheel.
Check the alignment
You can adjust the steering box by tightening a screw that's on the top of the box. First loosen the lock nut, then tighten the screw in small increments until you see some improvement.
The relay rod ends may be worn or need adjusting. do a search for the procedure.
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 05-10-08, 12:45 PM   #5 (permalink)
cruiserpants's Avatar
If your steering wheel has excessive play, you may need to adjust the "preload” on the steering box - It is the nut and screw on top of the box that need adjusting. Check your repair manual for specifics.
here is a link for more info: click here
Since you have a lift, it also sounds like you may want to check the front end caster.
Are the voices in my head bothering you?
1989 FJ62, OME lift, 33" BFG A/T's & a new air freshener
cruiserpants is offline   Reply With Quote
Old 05-10-08, 01:27 PM   #6 (permalink)
swimfan's Avatar
Check the alignment
can you go more in depth with the steering box adjustment screw?
Old 05-10-08, 03:56 PM   #7 (permalink)
2mbb's Avatar
TLCA# 6404
Here it is from the FSM.
If you look through the drivers side wheel well at the top of the steering gear box (you will have to lift your fender aprons if you have them) the adjustment screw is the in the middle, on top of the gear box. you can get a wrench on the lock nut from inside the wheel well. You will need to use a long screwdriver from inside the engine compartment to adjust the screw tighter. The screw is pretty much underneath the air bypass valve. I sometimes remove some of the AIR hoses to make it easier to get to the adjusting screw.
mbb
1985 FJ-60
Old 05-10-08, 06:25 PM   #8 (permalink)
sweet, thanks
For sale:
Old 05-10-08, 06:41 PM   #9 (permalink)
Bret's Avatar
As others have mentioned check the alignment, especially caster with the recent lift. It could have caused the axle to rotate (pinion pointed up more?) This will cause the truck to dart from side to side and follow things like raised paint lines etc. If you go with larger tires you can generally get away with a little more caster than stock. It can be a little bit harder to steer but you have better "return to center". You may be limited by the your pinion angle though.
You could also check the wheel bearings and trunion bearings. Jack the tire off the ground and see if there is any play from top to bottom, etc. A little less likely considering the symptoms.
Bret is offline   Reply With Quote
Old 05-12-08, 09:27 PM   #10 (permalink)
Trapper50cal's Avatar
TLCA# 15812
Mine...
Mine was all over the place. Mine ended up being knuckle (trunyon-sp?) bearings and shim pack thickness. But toe-in needed adjustment too. front of tires should be a little closer together than the backs of the tires. no more than .25"
83 FJ60-5" ALCANS-HYSTEER-80 TRE's-RICEBUILT RODS-AUSSIELOCKER-ARB DeerSlayer-LONGFIELDS-35" MTR's-BILSTEIN 5150's-Warn M8000-Ultimate Air-Defender Rack-Rising Sun Roof Clamps-Yukons-Tailgate Storage-Thanks Ige-Groucho-EricS-Corbett-Schmoozer-DurangoDDS-Zen80-Marlin-Bobby-JimC-Proffitts-WagonGear
Trapper50cal is offline   Reply With Quote
Old 05-14-08, 09:21 AM   #11 (permalink)
swimfan's Avatar
got a great bit of advice from a fellow mudder and it fixed the problem. i pulled out the pins on the ends of the tie rods and screwed the ends in all the way, then backed them off a full turn. tightened everything right up!
Old 05-15-08, 09:32 AM   #12 (permalink)
So what you had was a drag link problem, being out of adjustment. Keep those well greased and life stays happy.
1985 FJ60, 300HP TBI 350, NV4500, NP241, 14-bolt semi floater with 4.56 gears, E-Locker, SOA, four-wheel disk brakes, 35" BFGs, 350,000 happy miles and still going due to a wicked case of wander lust.
lehiguy is offline   Reply With Quote
Old 05-15-08, 06:14 PM   #13 (permalink)
intense1's Avatar
you might wanna check the lil rubber flexplate between the steering shaft and the steering box. That can wear out.
'89 fj 62 33's, 4:88's, 2" shackle lift.
intense1 is offline   Reply With Quote
Old 05-16-08, 05:25 AM   #14 (permalink)
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
The rag joint is not used on FJ55/60/62, only on FJ40.
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's since 1988.
Buy a 1981 FJ40 project!
FJ40Jim is offline   Reply With Quote
Old 05-16-08, 08:19 AM   #15 (permalink)
Yup. Small u joints on the 60s. I had one get sloppy, I took the opportunity to replace it when I had the motor out and I could stand in the engine bay...
Old 05-16-08, 07:38 PM   #16 (permalink)
joel hj60's Avatar
Adjusted mine today. I had major slop, I'm thinking it was over two inches. I have adjusted it up and while it is out of sight better now, there is still a clunk in there when the wheel is in the straight ahead position. Any ideas?
1985 HJ60
joel hj60 is offline   Reply With Quote
Old 05-17-08, 03:18 PM   #17 (permalink)
So I'm not sure I'm following the fix. If the tie rod ends were new, what effect would screwing them all the way in have? And how is that related to the drag link?
Peter
'66 FJ40 SBC 350, 3 spd manual
'84 FJ 60 OME Heavy, 33/12.5R15
'68 F250 (that's a Ford) highboy with Cummins engine.
workingdog is offline   Reply With Quote
Old 05-17-08, 03:49 PM   #18 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Peter
The drag link ends are spring loaded. It is a frequent source of slop. By tightening down on the compression screw, you are increasing the spring preload on the drag link end. Toyota's spec for adequately tight results in slop. Much better to tighten down all the way and back off about 1 turn.
Notice on the 80 series wagons the steering is basically the same and they did away with that goofy spring loading in the drag link ends. Much better in my opinion.
Andrew
1984 FJ-60 H55f, 4.11, SOA, partially Rubicon tested
1989 FJ-62 122k-son's driver for now-low and slow
1997 FZJ-80 Driveway queen
Old 05-18-08, 04:27 PM   #19 (permalink)
Thanks for the clear explanation. I had no idea. So that's why people go over 80 series steering. I may have to look into that. Can you put stiffer springs in the ends?
Peter
Old 05-18-08, 07:40 PM   #20 (permalink)
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
There is no need for stiffer springs.
There is an adjuster plug on the end of the joint. As the plug is tightened down, the spring is compressed, and the spring gets "stiffer". When the adjuster is tightened fully, then the joint becomes solid, no play.
Thanks,
Jim C.
TLC Performance
Old 05-19-08, 08:20 AM   #21 (permalink)
Randy88FJ62's Avatar
FJ40Jim,
Can you explain the difference with the 80 series steering a bit more in detail? They have no springs at all? Are there any good links that explain these differences and the conversion? Thanks.
Randy88FJ62 is offline   Reply With Quote
Old 05-19-08, 10:47 AM   #22 (permalink)
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
All tierod ends have some sort of spring in them. A conventional end has a belleville spring inside it which allows the rod end to absorb some road shock.
The reason to go to the 80 series rod ends is because they are noticeably larger & stronger.
Thanks,
Jim C.
TLC Performance
Old 05-19-08, 11:01 AM   #23 (permalink)
MoCoNative's Avatar
TLCA# 14418
I'm going to hijack for a moment on this thread. What do you do with a wandering 60 that has new wheel bearings, new knuckle bearings, new tierod ends and draglink ends. All done properly and in spec.
I set the toe in myself, thought I had it good, but it still wanders and pulls all over hell, and the outside of the front tires are cupping badly.
Is my alignment off, or are my 221000 mile springs so flat and worn that caster and tracking are going to be crap anyways.
1996 T100, Stock, nice truck
1973 FJ-40, Stock
1984 FJ-60, Stock, 225,000+miles
2002 Subaru Forester L, for the wifey
MoCoNative is offline   Reply With Quote
Old 05-19-08, 01:28 PM   #24 (permalink)
Is my alignment off, or are my 221000 mile springs so flat and worn that caster and tracking are going to be **** anyways.
The answer, in your own words, "the front tires are cupping badly". You have bad alignment.
Old 05-19-08, 01:51 PM   #25 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! You may need to replace the knuckle bearings. When I changed mine, they had obvious wear on the races in the straight ahead position. Not hard to beliceve since 90% of my driving is straight. John
CSC #41
Old 05-20-08, 12:47 AM   #26 (permalink)
joel hj60's Avatar
Knuckle bearings have been replaced. Hmmmmm
1985 HJ60
Old 05-20-08, 01:01 AM   #27 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! Well, in that case, disregard. Have you got an aftermarket steering stabilizer that is hitting the front diff? I saw one on an FJ40 that was setup that way. (Just another guess, I guess?) John
CSC #41
Old 05-20-08, 01:04 AM   #28 (permalink)
joel hj60's Avatar
Nooo nothing like that.
1985 HJ60
Old 05-20-08, 07:15 AM   #29 (permalink)
151fab's Avatar
TLCA# 18792
If your tires are older than your front-end rebuild than they may have already been cupped. Once a tire is cupped it will continue to cup further, it will not "un-cup". If you have too much toe-in that could be causing the problems as well. You only want about 1/8".
Also possible, but less likely: your spring hanger and shackle bushings can be worn so badly that it would effect the steering play, a cracked or otherwise damaged leaf could also be a cause. Remember your pushing against the bushings/leafs when you steer because these are the only things locating the axle laterally.
You want to check all this first, before you start shimming in caster, because adding a butt-load of caster will hide all the other problems you might be having as well as wear everything out sooner due to excessive steering effort put on the system.
---------- Todd@151fab.com ----------
1984 FJ60; totally stock, rust free, soon to be Black and Tan with an SOA
Read my introduction to see how it all started.
------WWW.151FAB.COM------
151fab is offline   Reply With Quote
Old 05-24-08, 09:45 PM   #30 (permalink)
joel hj60's Avatar
VERY novice question but I'll ask anyway. How much affect does the shims under the steering arms influence the steering?
My steering has developed a nasty wander around 80km/h...
ALL tyres are new, same pressures. Knuckles are good as far as I know. Last time I did my LH knuckle the top bearing race came out VERY easily, could this be a drama?
1985 HJ60
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/220637-question-about-steering.html
Posted By For Type Date
swimfan | Garden Ask This thread Pingback 05-15-08 07:00 PM
swimfan | Information Blog This thread Pingback 05-15-08 05:01 PM
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
