U-Bolt Dimensions...
Hey All,
I am in the middle of installing a 2.5" lift on my 83 Bj60 - Actually, its more like a 5" lift, seeing as the original springs were perfectly flat, maybe even reverse arched a bit. I have hit a minor snag: Despite some serious soaking in penetrating fluid, I torqued the nuts off of some of the u-bolts. I will be heading to a spring shop here in town to have them bend me some new ones. I'll be measuring them myself tomorrow, but I would like to double check with the mud gurus here to see what the dimensions are for both the rear round ones, and the front square ones. I have the back springs pretty well in order - I managed to remove two u-bolts without shearing anything, so one side is sitting on rubber while the other side is still on jack stands. I ran out of light and will attack the fronts tomorrow. I'll be replacing all the u-bolts with new ones once I can get them made but I'll have to wait till monday. The help is appreciated, I'll post before and after pics when I'm through. |
Howdy! I took a couple of my old u-bolts into a local spring shop to get replacements. They just matched the curve and length of the old ones. I even upgraded to the next larger size bolt stock. All I had to do was ream out the holes in the mounting plates to match the new bolts. Cheap and easy. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
impervious to subtlety
When you spec the length of new ones, be sure to account for any change in spring pack thickness.
__________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition |
Dancemania Bass | Loans | Mobile Phones | Just Holden Commodores | Loans |
