Old 03-28-08, 03:23 PM   #1
If i buy OME heavy duty, can i...
...take leaves out to make medium..?
Due to the whole ARB sided springs/cruiser lean issue I am going to replace my nearly-new medium springs which i am not too happy about, but i cannot deal with the lean any more. It is making the rig handle like a dog.
However, in the future i can see me needing to add more spring leaves (due to the mods planned). I was going to buy extra leaves for my original medium springs but i was wondering if i am going to change them, can i buy the heavy duty springs now and just remove leaves to make medium in the short-term? The reverse, if you will...
Thanks ~PHIL
'85 FJ62 Aussie model; 3F engine with carb & 5 spd box. Used extensively as a bush-cruiser...
Mods currently on hold until rusty roof is sorted
Buffalo is offline   Reply With Quote
Old 03-28-08, 04:23 PM   #2
Front Range 4x4's Avatar
Thanks ~PHIL
Hey Phil,
I'm confused. You're replacing your OME mediums with different OME's? Have you tried swapping left and right rear to combat the lean?
Yes to the question - remove a leaf from the heavies to make them medium.
Chris - Front Range 4x4
1988 FJ62 - Emily - 250,000 miles, FJ60 Round Eyes, H55F, OME Heavies, Solid Rock bumper & sliders, dual battery, etc.
Front Range 4x4 is offline   Reply With Quote
Old 03-28-08, 04:40 PM   #3
Tapage's Avatar
Are you trying to combat the lean or make it soft . ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 03-28-08, 06:40 PM   #4
Thanks guys... Hoped it would be like that.
Last year I replaced my old set up with a full OME set up on mediums - they fitted me an A&B spring on the rear and i have a lean to the B side. Never had one before the spring change. I'm p'd off with it as i can feel the way it is affecting the handling on the trails and on road. So I want to change the rears for two A springs. I'm sure this will counter the lean - as i said i did not have one before the swap and my old springs are identical to each other.
If the change to OME had gone right from the start (i.e. no lean) i would have just fitted a few extra leaves to the mediums when i needed more load capacity next year. I'm not prepared to do that with these springs, i want rid of the lean first; so i figured if i could buy the heavies in two A springs now, but degrade them for medium in the short term, i'd have my solution.
Make sense..?
~PHIL
Old 03-28-08, 06:50 PM   #5
what he said
Mace's Avatar
that is exactly what I am doing with my front OME heavies..
Pull the third leaf from the bottom..
however, I would see if you can get the med's replaced with another set if they lean horribly..
You also can buy that third leaf for ~$40 IIRC to make your Med's into heavies..
I am kinda gay.......
My Myspace
Old 03-28-08, 10:30 PM   #6
krookedpandas's Avatar
TLCA# 18509
I had the same problem. Have you tried trading sides? Move the A to where the B is and vice versa. ARB told me that it has something to do with the steering column and a bunch of s**t that made no sense to me but when I did it I lost my lean.
-Matt
1987 60 series
1986 22RE-T truck
LSLC Austin.
krookedpandas is offline   Reply With Quote
Old 03-29-08, 07:49 PM   #7
FJ60Cam's Avatar
TLCA# 16341
When I had lean problems that couldn't be switched by swapping sides, ARB sent me an extra "A" spring pack, no charge.
I had to jump through a few hoops to convince them, but everything's perfect now.
Cameron Mosley
'85 FJ60 - Daily Driver
FJ60Cam is online now   Reply With Quote
Money | Mortgage Calculator | Loans | Money | Loans
