If i buy OME heavy duty, can i...
...take leaves out to make medium..?
Due to the whole ARB sided springs/cruiser lean issue I am going to replace my nearly-new medium springs which i am not too happy about, but i cannot deal with the lean any more. It is making the rig handle like a dog. However, in the future i can see me needing to add more spring leaves (due to the mods planned). I was going to buy extra leaves for my original medium springs but i was wondering if i am going to change them, can i buy the heavy duty springs now and just remove leaves to make medium in the short-term? The reverse, if you will... Thanks ~PHIL __________________ '85 FJ62 Aussie model; 3F engine with carb & 5 spd box. Used extensively as a bush-cruiser... Mods currently on hold until rusty roof is sorted
#2 | |
I'm confused. You're replacing your OME mediums with different OME's? Have you tried swapping left and right rear to combat the lean? Yes to the question - remove a leaf from the heavies to make them medium. |
Are you trying to combat the lean or make it soft . ?
Thanks guys... Hoped it would be like that.
Last year I replaced my old set up with a full OME set up on mediums - they fitted me an A&B spring on the rear and i have a lean to the B side. Never had one before the spring change. I'm p'd off with it as i can feel the way it is affecting the handling on the trails and on road. So I want to change the rears for two A springs. I'm sure this will counter the lean - as i said i did not have one before the swap and my old springs are identical to each other. If the change to OME had gone right from the start (i.e. no lean) i would have just fitted a few extra leaves to the mediums when i needed more load capacity next year. I'm not prepared to do that with these springs, i want rid of the lean first; so i figured if i could buy the heavies in two A springs now, but degrade them for medium in the short term, i'd have my solution. Make sense..? ![]() ![]() ![]() ![]() ~PHIL __________________ '85 FJ62 Aussie model; 3F engine with carb & 5 spd box. Used extensively as a bush-cruiser... Mods currently on hold until rusty roof is sorted
what he said
that is exactly what I am doing with my front OME heavies..
Pull the third leaf from the bottom.. however, I would see if you can get the med's replaced with another set if they lean horribly.. You also can buy that third leaf for ~$40 IIRC to make your Med's into heavies.. __________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
I had the same problem. Have you tried trading sides? Move the A to where the B is and vice versa. ARB told me that it has something to do with the steering column and a bunch of s**t that made no sense to me but when I did it I lost my lean.
__________________ -Matt 1987 60 series-DD plus family project LSLC AUSTIN |
When I had lean problems that couldn't be switched by swapping sides, ARB sent me an extra "A" spring pack, no charge.
I had to jump through a few hoops to convince them, but everything's perfect now. __________________ Cameron Mosley '85 FJ60 - Daily Driver UNDER THE BRIDGE TOUR 2008 Last edited by werd; 08-20-08 at 11:08 AM. Reason: Sorry my gammar isn't that good... |
Loans | Loans | Anime Ranking | Fast Loans | Homeowner Loans |
