Old 08-28-04, 11:45 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
Improved handling - FJ60
When I recently had OME suspension installed on my 60, Mudrak suggested that I consider installing the rear sway bar from the FJ62 on the FF axle we were installing. It bolted right up, and cost very little. This, in addition to the OME suspension has been a tremendous improvement on on highway hadling in the hills. Seems to provide a firmer footing on corners.
If you are looking for better highway manners, this may help.
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 08-28-04, 01:14 PM   #2 (permalink)
Tank Buster
HZJ60 Guy's Avatar
TLCA# 13102
I wonder if you can do that with a spring over?
TB
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
HZJ60 Guy is offline   Reply With Quote
Old 08-28-04, 02:08 PM   #3 (permalink)
Mike S's Avatar
TB
The bar attaches to the frame with a pivoting rod which fits a bracket on the frame and passes through the eye in the end of the bar. The SOA setup seems feasible if this rod were extended. Not sure about the geometry. If you could look under a 62, you might be able to figure this without a problem.
Mike S
www.AutoHomeUS.com
TLCA Member #14874
Old 08-28-04, 05:23 PM   #4 (permalink)
I added a rear sway bar to my 60, and it's a noticable improvement. Not as big a deal as the new 3" suspension, and fixing all the worn stuff in the steering though...
Doug G
Seattle, WA
TLCA#12671
lovetoski is offline   Reply With Quote
Old 08-29-04, 07:24 AM   #5 (permalink)
masscrusher's Avatar
TLCA# 13009
Since the installation of the new OME lift last week I have noticed that when I get heavy on the gas pedal, the rear sways a bit. I blame the automatic locker more than anything else. I bet if I install one of them rear sway bars all that side to side movement might be gone.
But my worry about limiting flex. It is my understanding that the sway bar will do so. Anybody knowns about this?
Jose Merced
TLCA #13009 and Yankee Toys
1972 FJ40
All your base are belong to us
masscrusher is offline   Reply With Quote
Old 08-29-04, 07:37 AM   #6 (permalink)
ojsdna744's Avatar
Talking
Yes...the swaybar will limit your flex a bit...but the solid on-road feel will be worth it. If you have a locker back there working for ya...the "flex" it loses for you won't be missed much.
"What is it that should have put him away? OJSDNA!"
88 FJ62 (new to me)
03 Durango (wifeys)
02 TJ (mine)
06 3500 Dodge Ram(pulls whatever I ask it to)
ojsdna744 is offline   Reply With Quote
Old 08-29-04, 09:01 AM   #7 (permalink)
Waggoner5's Avatar
HZJ60 Guy I wonder if you can do that with a spring over?
Yes you can , and should have one on a SOA. You will have to make longer links though. It makes a dramatic improvement.
Gary
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
Waggoner5 is offline   Reply With Quote
Old 08-29-04, 09:11 AM   #8 (permalink)
bad_religion_au's Avatar
as for losing flex, make swaybar disconnects, just a removable pin somewhere in your swaybar setup that you can pull when you lock in your hubs, presto, sway bar not limiting flex
What can you do when you wake up and realise you sacrificed everything you ever wanted in life for the sake of progress?
bad_religion_au is offline   Reply With Quote
Old 08-29-04, 09:16 AM   #9 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
FYI, only 84+ fj60's have the sway bar mounts on axle and holes in frame. If you have a lift get/or make longer sway bar links.
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 08-29-04, 09:57 AM   #10 (permalink)
swank60's Avatar
Does anyone know exactly when that started? My 60 is a Nov '83 (1984 year model) - as always, I'm right on the stupid line and isn't an easy call.
If I crawl up under the truck, what should I be looking for? Is there a good diagram or photos anywhere (like SOR)?
Originally Posted by OZCAL View Post
…I think we need Swank 60 on this case. He knows irony…
swank60 is offline   Reply With Quote
Old 08-29-04, 10:40 AM   #11 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
I did but I don't remember now.
but look for this
Old 09-03-04, 12:24 PM   #12 (permalink)
Veni, Vidi, Dormivi
sl33py's Avatar
TLCA# 13992
OK, another less than bright question (my specialty) -
can someone show me the swaybar all connected up on a 60? I have a 85 60 and would like to improve stability on the rear... any of them big damn pics?
thanks guys!
Rob
1984 FJ60 *still TBD* 33x9.5's, 3" BDS, H55f
Dual Batt's, LED's, SROR Bumper, Rear Sliding Windows, Audio Dampener, More to come!
1987 FJ60 "TeeK"
Bozone (n.): The substance surrounding stupid people that stops bright ideas from penetrating. The bozone layer, unfortunately, shows little sign of breaking down in the near future.
sl33py is offline   Reply With Quote
Old 09-03-04, 12:40 PM   #13 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
you know I ment to snap a pic the other day..........I will today.
thanks guys!
Old 09-03-04, 01:04 PM   #14 (permalink)
Veni, Vidi, Dormivi
sl33py's Avatar
TLCA# 13992
thanks pimp. So it looks relatively easy (?yes?), how much and where can you get em?
Rob
1987 FJ60 "TeeK"
Old 09-03-04, 01:20 PM   #15 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
WAY easy, like 5-10 mins. I got mine from our 88 fj62 that had been in a accident, seen them sell for $100 for all the bits needed. If lifted you will want to buy or make extend links(I bought mine from MAF for $40)
Old 09-03-04, 06:33 PM   #16 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
Old 09-07-04, 07:31 PM   #17 (permalink)
Veni, Vidi, Dormivi
sl33py's Avatar
TLCA# 13992
sweet pics, thanks Pimp! yeah that looks pretty easy. Just have to look and see if i have the mounts on my 7/85 60...hmm...another project with no time...lol. you da man.
Rob
1987 FJ60 "TeeK"
Old 09-08-04, 11:25 AM   #18 (permalink)
Razor's Avatar
As I went around a corner last night, all the BBQ stuf dumped over on the dog..........................ARF........
This Sway system will help ??
I like the idea of a quick disconnect.
The only one I have found is new set up w/extensions...for $200..is that the going rate ??
TLCA#12161 Since 2001
Buncha 'OL Toyota Cars & Trucks
"Some very fast, some very slow"
Razor is offline   Reply With Quote
Old 09-08-04, 01:19 PM   #19 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
yep it handles better on the road for sure.
Old 09-08-04, 05:20 PM   #20 (permalink)
Mike S's Avatar
I bought mine on the For Sale section of this BB, paid $35 plus shipping, but had to buy the axle housing side brackets and bushings. Maybe $150 for the whole deal. Used MAF connector links to accomodate the 2-1/2" lift.
Mike S
www.AutoHomeUS.com
TLCA Member #14874
Old 03-21-06, 07:28 PM   #21 (permalink)
No way Eh !!!
MANUCHAO's Avatar
Hey all. I just found this thread and did not/was not able see the picture that was posted. Any chance of reposting or e-mailing me the actual pic?
Thanks !!!
MaNu !!!
'85--FJ60-L59
E-mail: viviendo.de.mar.a.cordillera@gmail.com
Alaska bound * June 2009 !!!!
MANUCHAO is offline   Reply With Quote
Old 03-21-06, 11:24 PM   #22 (permalink)
Damn! I was set to do this for my '83, too. Guess it was better to find out now. Is the retrofit a pain?
Carpe Discus is offline   Reply With Quote
Old 03-21-06, 11:44 PM   #23 (permalink)
Toadhopper's Avatar
Cruiserparts.net has the swaybars for about $100.00.
Ask for one thats not too rusted! I went to change the bushings and everything was frozen solid.
Toad
Toadhopper is offline   Reply With Quote
Old 03-22-06, 09:58 AM   #24 (permalink)
Or just go and buy everything new from Toyota for around $200. Just use the 89 FJ62 as the guide vehicle. That's what I did, and I'm glad I checked, rather than cleaning up rusted used parts.
landcruiserdude is offline   Reply With Quote
Old 11-23-06, 06:20 PM   #25 (permalink)
Rookie
the pics are missing now... if possible, can someone out there repost them or send them to me via email?
thanks
john
dogbonedoctors@aol.com
dogbone is offline   Reply With Quote
Old 11-25-06, 04:52 AM   #26 (permalink)
Rookie
thanks
john
Ditto, here too if some one could help out.
ToyDownUnder is offline   Reply With Quote
Old 11-25-06, 04:48 PM   #27 (permalink)
2mbb's Avatar
TLCA# 6404
Garage
There are some pic's in this thread...(use the search function)
http://forum.ih8mud.com/60-series-wagons/100440-rear-sway-bar-82-fj60.html
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 04-20-07, 11:45 PM   #28 (permalink)
Rookie
I did an soa on my Fj 62 and the damn mechanic threw them away. Aint that a bitch
Oscar V is offline   Reply With Quote
Old 04-21-07, 01:25 PM   #29 (permalink)
Tinker's Avatar
LCDude - you get 'em from your local stealer or CruiserDan?
"His mudder was a mudder".
Tinker is offline   Reply With Quote
Old 04-21-07, 02:02 PM   #30 (permalink)
mtb_rider's Avatar
Holy back from the dead!
"Where is it we're going again? And why are we in this handbasket?"
'88 FJ62. Little over 100k. 2nd owner. No rust. K&N, custom dual battery system, Optima Blue Tops, 3" Lift. 33x12.5 Firestone Destination MT's on Centerline two piece alloys. Pro Comp 9000's.
My myspace.
mtb_rider is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/21314-improved-handling-fj60.html
Posted By For Type Date
FJ60 and FJ62 FAQ ********* start here and come back often ********* - IH8MUD Forums This thread Refback 03-05-09 03:39 PM
