#61 |
Hudson's Dad
Those 37's are going to rub like a chubby girl's thighs.
__________________ If you’re not part of an organized volunteer group working on the trails, YOU are the problem. |
#62 |
As it sits, the rig will drop about 1 1/2"-2" more.
![]() We're happy with the ride height especially since it will come down a bit more. ![]() Axle got pushed forward an inch or 2. Still have 1" forward or back to play with on the spring pads.
__________________ My old 40, lowrider on leafs: http://board.marlincrawler.com/index.php?topic=19561.0 Building my 60: http://forum.ih8mud.com/60-series-wa...ilds-60-a.html www.4x4him.com Last edited by freds40; 03-10-08 at 10:55 AM. |
#63 |
Hudson's Dad
Looks like the cutter worked out.
I should have you come do my welding for me. __________________ If you’re not part of an organized volunteer group working on the trails, YOU are the problem. |
#64 |
I'm kind of leaning towards a 3" body lift. Should get us up away from the rubber.
__________________ My old 40, lowrider on leafs: http://board.marlincrawler.com/index.php?topic=19561.0 Building my 60: http://forum.ih8mud.com/60-series-wa...ilds-60-a.html www.4x4him.com |
#65 | |
#66 |
Hudson's Dad
You know where it'll be. You're going to have more post's in Jason's build thread than he is.
#67 |
He forgot his camera today so he used mine. So looks like I get to load the pics up.
#68 |
I've been waiting for you to get home and post up the awesomeness
#69 |
when all said and done I'll probably have 3"s off up travel. It's all about bumpstops. when it's compressing the tire will go back, dropping will go forward.
If it doe's rub a little, I don't really care. thanks for the use of the cutter it worked awesome, it took 5min a side to make the nice and clean cut. |
#70 |
Hudson's Dad
Are you going to build a twin stick. I think I found a bushing that will slip over the in/out shaft and capture a nut in the slot. You interested?
#71 |
#72 |
Did done figured that one out already
#73 |
Hudson's Dad
I believe it. If what Fred says is correct your 2" forward and I'm only an inch.
#74 |
these are the bump stops I'm probably gonna run on the front
![]() Double Convolution Springs - Timbren Aeon Hollow Rubber Springs I'm thinking the A530-65 will work for me Last edited by weak-link; 03-09-08 at 07:36 PM. |
#75 |
Got the toybox and t-case built and bolted to the trans. Forgot to bring my camera.
Now I'm just waiting for parts I'm hopping to have the soa done by the end of the week, then I'll start on the trans,TB,t-case install. I'm beat |
#76 |
Hudson's Dad
You are obviously better prepared than I am. I don't expect to be done for weeks. You need kids to slow you down a little.
#78 |
HAHAHAHAAA!!!!!
Those springs look a bit flat....you planning on hauling a ton of stuff? My SOA springs sagged after a month and they had looked like that in the beginning. You may want to add a leaf to stiffen them up. __________________ PORTLANDERS + NW CRUISERS:: $@#!! L A N D C R U I S E R S P E C I A L T I E S !!! H O R R I B L E W O R K , W O R S E A C C O U N T A B I L I T Y!!! ![]() L A N D C R U I S E R N O R T H W E S T R O C K S!!!! |
#79 |
kick ass build so far.
__________________ - Iam home now from the SUCK !!!!!!! VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!! - RUBITHON 2008 TESTED GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7.. |
#80 |
I gonna wait and see how it is first, with the bumstops I will set them up so there is just an inch of uptravel before they contact. those bumpstops are supost to be the poor man's air bumps.
#81 |
I'm sure they are, in your monster truck
whats your mesurment to the frame in that thing? 62"?
#82 | |
quit your whinning ![]() Did you get your toybox bolted together last night? |
#83 | |
x2
The build is looking good and having that nice kit sure does save some time. Don't give the pipe cutter back yet, you can shorten your rear driveshaft that way and you get a nice clean cut to keep things lined up.
__________________ 85 FJ60, testing, Cummins 4BTA, manual 4L80E, 203 to splitcase doubler, SOA, 38s, some other stuff. build-up: Family Haulin' FJ60 |
#84 | |
Hudson's Dad
No the new bearings should be in today. He stoped by on his way out of town and gave me the low down on assembly and recommended a few things. We got the input gear flush with the idler gear so that's a load off. I'll post pics of reassembly in my thread when I get to it. __________________ If you’re not part of an organized volunteer group working on the trails, YOU are the problem. |
#85 |
I don't think Tim will like me cutting the welds on a DC joint, but good idea.
#86 | |
#87 |
Hudson's Dad
About 18.5" from block to flange
__________________ If you’re not part of an organized volunteer group working on the |
