impervious to subtlety
"Diesel" oil in a gas engine?
Title pretty much explains it. What is special about "diesel" oils and is there any reason not to run them in a gasser? Will the soot dispersants do anything counter-productive? Any advantages to a "diesel" oil? Any differences in TBN/acid buffering? Or is it all marketing to the main group consuming a given grade?
![]() Now that I have a dual filter set-up (http://forum.ih8mud.com/60-series-wa...good-idea.html) I want to put some good quality synthetic in there, and many of the good oils, gradewise, are "diesel" formulations. I am thinking of using AMSOIL with a bit of Redline mixed in (to be sure there is an ester component), and changing over half the capacity at 6 months/6-8,000 miles, varying the fresh component between 5W40 and 15W40 with the changing seasons. (If anyone is wondering "why not just change it all", poke around here: Synthetic Oil Life Study It appears that wear indicators rise most dramatically right after an oil change, and less rapidly after that. See the AMSOIL trends here: Amsoil Test Results and the Mobil1 trends here: Mobil 1 Test Results The iron and copper values tell the story.) Thanks for your opinions, ![]() Curtis. __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition Last edited by RockDoc; 01-28-08 at 06:18 AM. Reason: Add links |
Bonefide Cruiser addict
I have run mobil mx"diesel" oil in every engine I own for the last 3 years. that is my mini truck, my diesel Landcruiser, my V8 Landcruiser, my honda mower and weedeater. I also live in a hot part of the world, diesel formulations are generally a bit thicker so you wouldnt want to run them in a cold climate
Paul __________________ '97 HZJ80 - 4" lift, 33s, lockers, 12000 lb warn, ARB, barwork, intercooled turbo, soon to be A442 Auto '85 HJ60 - 4" lift, 36s, 8274 hi mount, EFI V8, T400, custom pickup chop, cage, lockers, Patrol front diff & coils, 80 series rear, rollbars, custom steering, custom tray - click here ROTW - here |
Most diesel oil is non detergent, and non energy conserving. Why would you go there?
__________________ world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored 03 Tacoma TRD SR5, Suzuki DR350 ANYBODY BUT OBAMA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
I have run Rotella 15w40 in everything i own for about 6 years now. no problems. 4 trucks (diesel and gas), 7 mowers, utility vehicle, etc.
it is easier to just buy one kind than to have a shelf of 5 different weights and brands that go in different things. __________________ _________________________________________________ 85 FJ60 236,xxx, Wilderness rack,33's, ARB front, XM, OME, Safari snorkel- - on the floor waiting it's turn.THE ENTIRE ENGINE!! and a Warn 9000, 07 FJ Cruiser - wife's ride 02 HD - Ultra Glide custom 97 HD - Heritage Springer |
TLCA# 16387
If the oil you're thinking of using is an "S" rated oil, ie: SE or SF or similar then it has been tested to meet the requirements of a gasser oil. The further down the alphabet the second letter is the more stringent requirements are met. Diesel oil is all "C" rated.
The "S" stands for spark ignition and the "C" for compression ignition. __________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
Thanks cruiser_guy, that'll help a bunch.
So something with the following ratings would be fine in a gasser? • API CJ-4, CI-4+, CH-4, CF • API SM, SL, SJ.. __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition |
TLCA# 16387
If it has both those ratings it is equally well suited in both gas and diesel engines. It's not uncommon for a higher quality oil to have both ratings. The Chevron Delo 400 which I use in my truck has both ratings as well.
I think a lot of it is marketing. According to Mobil 1, the current 5w-40 "Turbo Diesel Truck" formulation that is for sale is rebranded Mobil 1 Delvac, which is no longer marketed in the US apparently. They are now marketing Turbo Diesel Truck as premium grade 5w-40 that can be used in mixed (gas and diesel) fleets. Works great in my turbo Subaru and my FJ62.
API Ratings: API CI-4 PLUS/CI-4/CH-4/CG-4/CF-4/CF/SL/SJ Mobil 1 Turbo Diesel Truck 5W-40 Comparing Mobil 1 Turbo Diesel Truck 5W-40 to Mobil Delvac 1 5W-40 __________________ 1990 Land Cruiser 2004 WRX |
KI6MIE
S="spark" ignition rating. SM is the most current rating, I think the FJ60s only required SD or SE when new.
Most diesel oils are "mixed fleet" oils, suitable for gas and diesel engines. They are excellent oils in your Land Cruiser. I like the Chevron Delo 15w-40 myself most of the year, and run the Shell Rotella Syn 5w-40 in the winter. As to them being non-detergent oils---well, that's just incorrect information. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#10 |
New think that I learn about oils .. S and C
I ran 20W-50 in all my cruisers .. 2 are turbo diesel and 1 it's a gasser .. coz in " diesel " oils the jump from 15W-40 to 25W-60 it's huge and the last one it's pretty thick. |
#11 |
Delo 15-40 here, in my 3 gassers, 97 4Runner, 92 Toyota PU 4x4.
87 Landcruiser and my two MBZ 240D's. Works great in all. __________________ White 1987 FJ60. www.marlincrawler.com Member: TCLA #18387, Central Valley Crawlers |
#12 |
TLCA# 16387
25W-60?!?!?! I've NEVER heard of engine oil that thick. That's just a little thinner than gear oil at 75W-90!
#13 | |
Castrol México - Castrol Ultramax Viscus |
#14 |
I recently purchased to Pure Power reusable, cleanable full flow oil filter (Pure Power Oil Filters High Performance Motor Oil). I was going to go Amsoil dual remote as well but just don't have the space. The head guy at Pure Power, a chemist, had nothing but bad things to say about synthetics and any weight under 10. Mostly he felt that the additive packages sucked. I've always used synthetics with excellent results so switching back to dino juice is hard. However I likely will switch this weekend (next oil change) to Shell Rotella (non syn) which he highly recommended. I'll probably keep my Audi's on Mobile 1 however.
__________________ Joel '89 FJ-62 |
#15 |
Thanks for all the replies guys.
![]() I think I am a bit more edumacated now. __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition |
#16 |
Shell Rotella 15/40 and a Wix filter. I swear by this combo and have run it in everything from a 1-6L Turbo Miata to my current 4.0L Turbo Cruiser. Rotella Rocks!
#17 | |
I'm always a little wary when a "chemist" makes negative remarks about another product.
There is substantial evidence that quality synthetics provide better lubrication of moving parts in almost all circumstances. Think about it, when car manufacturers do not want you to use synthetics until your engine is properly broken in, that says something. Other manufacturers require synthetics be used since the highly variable dino-oil is not of sufficient consistency or quality to provide proper lubrication in the given application (eg Volkswagen). In my past experience, most re-useable oil filters are not all that great. It's kind of like using a K&N style air filter on your off-road truck - which is akin to placing an oiled fly screen in front of your air intake. On the linked site, there's all kinds of brag about billet this, and stainless steel that, but nothing of filtering capacity, mesh size etc. in the text. Makes me kind of wonder. And back to the original thread: diesel engine oils are usually higher in detergents and higher in total TBN. Generally speaking, you are getting a better quality oil when you use a diesel formulated oil. They are suitable for use in all engines, as long as the viscosity is correct for the conditions. And, regarding the comment about any oil under 10W being suspect: that is just plain nonsense. Several manufacturers (eg Honda) now require light oils since they are machined to such fine tolerances that heavier oils will not properly lubricate the parts (and void their warranty). ~John Who uses spin-on filters and synthetic oil in his diesel Quote:
__________________ 1978 FJ40 - parts vehicle - PM me 1987 HJ61 VX 5spd - loaded - daily driver 1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa |
#18 |
Just try and git it.
When I had my engine (2F) rebuilt, the machinist said the new oils, synthetics included were mandated to remove Zinc to meet EPA guidelines. Zinc is an 'extreme pressure' additive and is critical for flat-tappet break-in. LINK
He gave me an addative, made by GM, that he said adds the zinc and manganese back. He also said to use Shell Rotella because all Diesel oils still have the Zinc and Manganese in them for extreme pressure applications. Newer cars without push rods or solid lifters don't need the pressure additives. Cars/Trucks with solid lifters do. Rotella or equivalent is the way to go. |
#19 | |
*Edit* As of 2003/2004 (the analysis link in the first post) AMSOIL's 5W30 had shitbags of Zinc and Magnesium (as opposed to Manganese, I suspect Magnesium is the addative). Know when the EPA rules came in? __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition Last edited by RockDoc; 01-29-08 at 12:59 AM. |
#20 | |
#21 |
For a bit more change (and some realestate) you can get >98% efficiency at 2 micron.
http://forum.ih8mud.com/60-series-wa...good-idea.html __________________ [ ][ ]=TOYOTA=[ ][ ] 4 eyes > 2 eyes ![]() Member of the Peace Canyon Toyota Swamp Donkeys Creep Coalition |
