02-28-08, 06:54 PM
#61 (permalink)
Ok, good to know. To do the job right my windshield may need to be removed, but now I know I don't need to take the fenders off first!
Thanks again for checking for me.
'87 FJ60 Freeborn Red with extras
02-28-08, 08:14 PM
#62 (permalink)
Originally Posted by landbruiser60
looking real nice!!! Did you paint those rims?
No, they came powdercoated from 4WPW, however, they match the frame and axles really well.
02-28-08, 08:15 PM
#63 (permalink)
Yeah, the only reason you'd have to take the fenders off is if you replaced the entire cowl, as it wraps down the outer firewall/upper forward door jamb.
03-01-08, 05:18 PM
#64 (permalink)
Pictures from last night/this morning. Drum brakes are rebuilt (shoes, drums, hardware), calipers rebuilt, trans, transfer, and OD resealed and cleaned/painted, clutch replaced, yada, yada, yada
Lets just get to the pics:
Werd.
03-01-08, 10:44 PM
#65 (permalink)
Skinner,
Thanks for showing all of us these phototos. Very extensive tear down and rebuild and repair job. Kind of reminds me of the extensive 9 month tear downs we did on our millitary aircraft. gives you a good peace of mind that nothing will happen to the body or frame for a very long time. Keep up the good work and dont spend to much time away from you wife of she may hate you.
03-02-08, 07:53 PM
#66 (permalink)
No pictures tonight, the weather was so nice today that I spent the majority of the day riding my motorcycle. But, this evening, I did get manage to get all of the fuel and brake lines installed on the frame and axles, and replace all of the flex hoses.
03-15-08, 02:45 PM
#67 (permalink)
03-15-08, 09:29 PM
#68 (permalink)
great work..............man i wish i had your shop.
03-16-08, 10:56 AM
#69 (permalink)
Thanks for the compliments!
Here are a couple of pics after glass beading the rear portion of the floor. Pretty quick process, this took less than 1 hour. The cream/tan color is the factory panel sealer.
I have found a slight bit of rust in both rear quarters, and a giant bondo hack job on the passenger rear fender lip...I'm going to try to uncover that this afternoon....
03-16-08, 12:12 PM
#70 (permalink)
I don't know how I missed this thread, but it is sweet! Did you try and spray anything on the inside of your frame for rust protection?
1990 FJ62 aka - HogMauler- (OME Med-SR-ARB Bull Bar-SROR Sliders) TLCA# 11319
1995 Saab 9k Aero (Custom intake and exhaust)
(((((_____ Denver Real Estate Blog_____)))))
03-16-08, 01:13 PM
#71 (permalink)
I'm planning on spraying it with ATF, used oil, or something similar after everything is done.
03-16-08, 06:05 PM
#72 (permalink)
very cool. what's the dimensions of your shop I am building one soon and yours seems pretty great
"shun the non believer!!"
'82 FJ60 Making Bumpers, Roof Rax and other stuff... all custom no store bought mods... just blood sweat and gears!
03-16-08, 07:52 PM
#73 (permalink)
Thanks, man! It is 30x36.
03-16-08, 07:56 PM
#74 (permalink)
There is a recipe in here for the stuff that the brits use for their landrovers. I'll see if i can find it.
03-18-08, 01:15 PM
#75 (permalink)
Very nice progress! Your build is looking better and better every time I check this thread. So you are going to put black shell on the entire body? I hope you are because I plan on trying it and I can't wait to see what yours looks like. that's a good idea on the used motor oil on the inside of the frame, I might do that as well. Keep up the good work!
03-18-08, 01:21 PM
#76 (permalink)
what size are the tires?
03-18-08, 01:24 PM
#77 (permalink)
BFG 33x10.50R15's
03-19-08, 05:48 AM
#78 (permalink)
Perhaps I missed it in the thread, but can you elaborate on your sandblasting equip?
Thanks,
Zack
03-19-08, 07:45 AM
#79 (permalink)
Thanks,
Zack
x2. Did you prep the bottom for blasting or did the glass beads remove the undercoating?
03-19-08, 10:32 AM
#80 (permalink)
I am using a 20 gallon pressure pot blaster from Eastwood, 3.5mm tip, and I think #8 Glass Beads.
I didn't do anything special to prep other than tape any holes that go through to the interior of the cab. I just blasted with the glass until the dirt, paint, and grease buildup was gone. I chose not to remove the factory sealer/undercoating, but the blaster will easily remove it with glass beads if you stay in the same place for more than 2-3 seconds. Of course, if you wanted to remove the factory sealer you could always swap to Garnet or a harder blasting media.
03-19-08, 05:18 PM
#81 (permalink)
03-19-08, 05:41 PM
#82 (permalink)
WOW!!! This thing is going to be sweet. Great work!
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers, Misc scratches, etc...Sold...What is next???
M101 Trailer - Sold & sadly missed...
03-19-08, 06:48 PM
#83 (permalink)
Is the body only supported on the lift by the quater panel? If so, is that safe?
Zack
03-19-08, 07:30 PM
#84 (permalink)
Yeah, it's the quarter panel at the rear, but it's on the pinch weld (Where the floor, side member, and outer skins come together). I've also got 2 screw jacks underneath it. Should be no problem.
03-20-08, 06:27 AM
#85 (permalink)
Looks lie those quarters a candidates to be bobed.
Really nice work overall, you are making this look easy.
Pacer
1972 r75/5
1974 r90/6
1989 fj62
2002 325xit
03-20-08, 07:05 AM
#86 (permalink)
You can find a rust free set of rear quarters. Some guys Weld them back in all the way from roof to floor.  I had the guy that did mine cut out the bad areas and weld in patches cut from 2 quarters I bought at a Junk Yard.
- 1983 FJ60 - 229K
2.5" Man-a-fre HD leaf springs, HFS shocks
4runner Calipers, 4.11 thirds 33x10.50MT's Wilderness Roof Rack - Roller Paint job
CORN TACO - DD - 2005 Tacoma Double cab with Ethanol full flex converter
ARB Front bumper w. warn winch and PIAA lights
3" Toy Tec Lift Rock-tec rear bumper
03-20-08, 07:46 AM
#87 (permalink)
Sorry to see the quarter panels...
I have not ordered from them, but I did find quarter panel patches from these guys: Toyota Land Cruiser Rust Repair Panels
03-20-08, 09:27 AM
#88 (permalink)
LOL, don't think I haven't thought about it....but unless I bobbed it to the rear door, I'd still have the rust issues to deal with.
03-20-08, 09:41 AM
#89 (permalink)
Yeah, that's my current plan.
I'm hoping to find a clean quarter and patch mine from the door opening back and the window down. I'll drill the spot welds out at the tail lamp/hatch area, pinch weld, and door opening, and make my cuts at the C/D pillars on either side of the rear window. This would minimize the length of my welds and should allow me to patch it with minimal distortion/body work. Ideally, I would like to do this on both sides.
So, if anyone knows of a person parting out a semi-clean FJ60 body, PLEASE let me know!
03-20-08, 09:49 AM
#90 (permalink)
Nice garage! Nice Rig, its gonna look awesome when you get it all sewn up. Nice work!
1988 FJ62, 225k, 3rd row seats, 3" lift, 33" BFG's
