Old 01-07-08, 04:48 PM   #1
curdog14's Avatar
WTF and why is it leaking?
Ok boys, hope I'm not playing dumb on this one. After our first big cold spell in Sunny-Gunny (-25 F) Louie (88 FJ62) started to leak tranny fluid. I didn't think much of it as I thought that the tranny oil pan gasket cracked. Well, that is not the case. After crawling underneath in the blowing snow I noticed fluid pumping out of a hole in the front of the tranny. I had never noticed this hole before. It resides in what I assume is some sort of access plate to the flywheel. I have honestly never noticed it before. Over the years I've spent plenty of time on my back down there as have the rest of you. There was no gasket on the back of the plate so again I'm assuming that there should be no fluid in this area. Tranny was rebuilt in '04 (before I'd heard of Rodney) and other than high load temps, have had no issues turning the big tires. Here is the best pic I could get and I took some video that shows it pumping out. I'm looking for any reason to install a H55 but I need this rig reliable as it has inherited the title of daily driver. I can deal with the quirks that seem to follow this rig, but need the power-train to perform.
88 FJ62 the original "Louie", +-210K miles 3" SOR Heavy lift, 33X12.5 Cooper's on black American Racing wheels, Wilderness rack, XM SkyFi, primer, algae, and rust... send the lawyers, guns, and money... quick!
curdog14 is offline   Reply With Quote
Old 01-07-08, 05:08 PM   #2
curdog14's Avatar
maybe the pic will work this time.
Old 01-07-08, 06:02 PM   #3
torque convertor seal? or front seal on trans input?
remove the 2 bolts and see if you can diagnos better
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 01-07-08, 06:10 PM   #4
Skybill's Avatar
Location: Vancouver (USA, Not Canada) WA (State, Not D.C.)
TLCA# 15387
Yeah, could be the seal on the pump.
When mine went TU the fluid came out in a 1/2" stream!
You probably won't be able to see it thru access plate as it is where the bell housing and tranny meet and behind the torque converter.
Cheap part from Toyota >$15, but you have to pull the tranny out to replace it!
Mine had 287,000+ miles on it so I rebuilt the transmission and transfer case while it was out.
Good luck!
'89 FJ62 - SOA - 35" Toyo MT's - Rancho 9000X's - 287,000 miles 8 MPG!
'04 Tundra Double Cab - 2.5" lift 33" TXR's
'87 Tercel Wagon
'91 Celica GT
Skybill is offline   Reply With Quote
Old 01-07-08, 06:25 PM   #5
curdog14's Avatar
I pulled the plate while cold so obviously not dumping fluid. I'm no fool, but whats the banana scale for this gasket replacement? My garage is tiny and it gets damn cold here. It seems straight forward, pull bolts, jack stand tranny, replace gasket, rinse, repeat. Sound about right?
Old 06-13-08, 06:54 PM   #6
Randy88FJ62's Avatar
I have the same leak on my 288,000 mile 1988 FJ62... It looks like a lot of work. I'm hoping it's just the oil pan gasket.
Randy88FJ62 is offline   Reply With Quote
Old 06-16-08, 03:38 PM   #7
TLCA# 18761
Looks familiar - I will be watching this one closely... Sorry I can't offer anything in the way of help.
Joshua993 is offline   Reply With Quote
Compare | Credit Cards | Mortgages | Cheap Loan | MPAA
