Old 12-31-07, 09:22 AM   #1
Question Another EGR valve question
My 60 runs like crap with the EGR valve connected to the modulator and have been running it forever disconnected, would a bad EGR valve still connected to the intake decrease the engine performance? ( i.e. rough idle and power loss)? Someone mentioned to me that the valve can actualy leek allowing exhaust gases to enter the manifold at any given time. Can anyone please verify this?
'81 FJ60 landcruiser
'81 Toyota 4X, slow resurection in process
'90 Toyota camry ( her's )
'90 polaris 350 trailboss
'62 trail-er
RHON is offline   Reply With Quote
Old 12-31-07, 09:54 AM   #2
dmede808's Avatar
the EGR valve can become stuck open. pull it off and clean it out, spray a little carb cleaner or pb blaster on the valve itself and push it in and out with a screw driver. Don't spray anything into the vacuum connection on top of the EGR valve. This usually gets me going again for another year
1987 FJ60
dmede808 is offline   Reply With Quote
Old 12-31-07, 09:56 AM   #3
2mbb's Avatar
TLCA# 6404
The modulator applies vacuum to the egr valve to open it. There is a spring on the egr valve to close it when no vacuum is applied. However, depending upon the condition, the valve seal may be corroded and/or the valve may be stuck in a partially open position. You can take the valve off the engine and see if the valve stem moves freely or if the seat seems to be corroded.
mbb
1985 FJ-60
2mbb is online now   Reply With Quote
Old 01-03-08, 08:12 PM   #4
Thumbs up
Just pryed the computer away from my girlfreind- a little late here but thanks for the input- I'll yank off the valve this weekend and see what's going on inside.
'62 trail-er
Old 01-04-08, 06:25 AM   #5
hank14's Avatar
TLCA# 17839
What about the EGR modulator? Is there a way to objectively measure the air flow through it? I took mine apart and cleaned the filter in it and checked the air flow as per the FSM. It works, but took more pressure and had less air flow than I expected when I was blowing through the different ports.
I definitely don't want to replace that part just to see if it's working$$.
Scott
Granbury, TX
1987 Beige FJ60.
hank14 is offline   Reply With Quote
Old 01-16-08, 07:41 PM   #6
Butt Ugly Chuck's Avatar
TLCA# 18371
EGR Vacuum modulator test
Hank, This is EXACTLY where I'm at right now! Following the test procedure page 3-17 in the FSM: "Blow air into port Q. Check that the air passes through to the air filter side freely". I get air flow, but wouldn't necessarily characterize it as "freely". Freely is kind of a squishy word. Anyone know - should there be virtualy no resistance to air flow? Would some resistance give you EGR type symptoms (bucking/stumbling under throttle)?
Butt
7/85 FJ60 261k miles
91 Haro Extreme AL MTB - daily rider
16' Aire Jaguarundi
Butt Ugly Chuck is offline   Reply With Quote
Old 01-16-08, 08:54 PM   #7
hank14's Avatar
TLCA# 17839
Mine does not flow freely. It flows, but with sone resistance. The filter was clean, but I degreased it and blew it out anyways.
All I know is if I apply vaccuum to the EGR while idling, the engine nearly stalls, indicating the EGR is working properly. BUT- when the EGR is connected to the modulator, it bucks, surges, and generally runs like an old Craftsman riding mower.
When it is disconnected and capped off "egr bypass method", it runs like a new Craftsman riding mower.
Scott
Granbury, TX
1987 Beige FJ60.
Old 01-16-08, 08:58 PM   #8
TLCA# 18371
Thanks Hank! Since I'm in Cali and need to pass smog soon, I guess I'm looking to replace my modulator.
Later,
Butt
16' Aire Jaguarundi
Old 01-16-08, 09:03 PM   #9
hank14's Avatar
TLCA# 17839
You're welcome. I don't envy you on the smog test. I don't have to test in my county...yet, but I figure if I'm going to have all that crap under the hood, it might as well work. I'd rip it out, but as soon as I do, I'll decide to sell this fine piece of machinery or something.
I ticked me off when I saw an 83 FJ60 that I looked at 2 years ago for sale again and the seller was braggin about how easily his passed smog- and it's exempt everywhere in Texas this year! (24 years)
Scott
Granbury, TX
1987 Beige FJ60.
Old 01-24-08, 08:22 PM   #10
hank14's Avatar
TLCA# 17839
Here's a picture of how I replaced the EGR modulator filter- I used cotton makeup removal pads from my wife- just cut them to fit. After looking again at the modulator filter, the dense part of it was not letting much air through. I think this was "starving" the EGR valve or forcing more exhaust gas to recirculate instead of taking in fresh air.
After doing this and a few other things working through the emissions manual, she is running better than she ever has with all the smog equipment intact. Very minimal bucking and surging- and I'm not through the manual yet!
Scott
Granbury, TX
1987 Beige FJ60.
Old 06-16-08, 08:40 PM   #11
sk8salomon's Avatar
i'm in a similar situation but am trying to get the damn egr off. i can't for the life of me break loose the bottom j-pipe nut. i've tried to get a wrench on the top nut near the egr but it won't budge either. i've figured out it needs about a 27mm wrench so i thought about buying a box ended one and cutting a slot sort of like a brake line wrench. hopefully getting more torque on the nut to break it loose.
Running total of non-waving FJC drivers ......534
'85 FJ60 bone stock (the way i like it)
'87 Ford Ocnorb with lots of redneck stuff & custom dented body panels
sk8salomon is offline   Reply With Quote
Libro arquitectura | Cheap Magazine Subscriptions | Sudoku Software | Mobile Phones | MPAA
