10-23-07, 05:52 AM
#1 | | Addict
| Setting Ignition Timing with Vacuum Gauge...How? So How is this properly done? The same way one does it with a Timing Light? (removing the two hoses that go to the distributor)What's a good source of Vacuum in a 2F Motor?
Thanks in advance (no pun intended!  ) |
10-23-07, 07:16 AM
#2 | | Forum Regular
| a good source of vacuum is your intake manifold. brake booster is easy access. forget about that and use a timing light to set factory 7 btdc (the bb hole in flywheel) with vacuum PLUGGED to distributor. |
10-23-07, 10:27 AM
#3 | | 10k Club
| Quote:
Originally Posted by mmmahhmatt a good source of vacuum is your intake manifold. brake booster is easy access. forget about that and use a timing light to set factory 7 btdc (the bb hole in flywheel) with vacuum PLUGGED to distributor. | Why does the FSM say to warm up the engine and then disconnect the vacuum hoses from distributor, and plug both ends? Set the timing at 7 degrees at 950 RPM by adjusting the distibutor.
Reference is from Toyota 2F Engine Emmision Control FSM # RM36043 page 4-2
Grant backs it up here. http://forum.ih8mud.com/showthread.p...setting+timing
10-23-07, 06:21 PM
#4 | | Lifer
| I've never had any luck setting the timing with a vacuum gauge.......Timing with a vacuum gauge will normally result in timing that is more advanced than what specifications call for.... Resulting in pinging under load or hard start " kick back" when cranking under hot conditions..... I basically just use the light and most seem to preform best @ 10/12* bftdc....
__________________ |^^^^^^^^^^^^^^^\ ||__ |.......PBR BEER TRUCK.... ||""\_____\ |_____________________/||__/----| |(@)(@)"""""""""""|(@) (@)****|(@) The Beer Truck, that ran over Bunny..... (\__/) (='.'=)  (")_(") |
10-23-07, 08:48 PM
#5 | | Lifer
| Timing w/ a light is best, in that it gives you a reference of just HOW far retarded/advanced you go.
Timing w/ a vac gauge would mean simply advancing slowly unlill ya reach the highest # obtainable, then backing down just a hair, like a few degrees of distributor rotation only.
Ultimately, they both rely on the drivability test to really decide where is best, they just arrive at the final setting differently and use less trial-and-error than just turn a little, and drive, then turn a little more and drive, etc.
My spare $0.02
__________________ "The grass is always greener on the other side when you're not the one mowing it"
Toys:
'90 FJ 62 '03 Cannondale Speed 440 // '04 Yamaha Warrior 350 // '05 Suzuki z400 // '05 KTM Mini Adventure 50
2f engine manual and 84-90 Chassis and Body manual in pdf: http://hugh4prez.nate-online.com/Cru...416%20Manuals/ |
10-24-07, 07:40 PM
#6 | | Forum Regular
| How do ya know for sure how far advanced your are. I normally fun with the BB about halfway between the pointer and the bottom of the window. But how can I find out exactly what its at?
__________________ " I'm still pissed about the Lincoln Lamp ! "  1983 FJ60 Weber carb, Aussie locker, H55F, Homemade bumpers and rock rails, winch, headers, OME Dakar springs, Saginaw ps, smog pump AWOL, 33/12.5s, 4.56s, York OBA, Camo,
1993 FZJ80 "Backbone" (wifes) |
10-24-07, 07:50 PM
#7 | | Lifer
| You will need a light with advance increment control....
10-25-07, 11:43 AM
#8 | | Forum Regular
| Thanks, I'll look into getting one.
