07-21-07, 10:06 PM
Kavik's SOA
Here goes...Still in progress!
1985 FJ60
2F partial de-smog, high flow cat, HEI, 300K miles
MAF add-a-leaf, F & R
4.88 precision gears
Aussie Locker rear, open front
Link to build pics
Before - 33x10.5x15 BFG mt's on 15x8 rockcrawlers 2" backspace
Front only - 37x12.5x15 MTR's on 15x8 rockcrawlers 2" backspace
After - 37x12.5x15 MTR's on 15x8 rockcrawlers 2" backspace
85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs ***FOR SALE***
95' FZJ80 - new to me, some mods, details to come...
Copper State Cruisers #71
KavikOffRoad.com
60 Series porn
07-21-07, 10:10 PM
Nice!!! That looks great! Those tires look BIG
02/83 FJ60
07-21-07, 10:10 PM
Looks good, btw how much lift did you gain with the add a leaf?
79 fj40- 2F-TBI , 4:88 R/P, ARB Front/Aussie rear, SOA, 38 TSLs, Full Cage, Bobby Longed SS, Saginaw Hi-Steer, SM465/3speed tcase, 4WDB, 97 wheelbase, fj55 springs, and some spares, it's MUSTARD YELLOW
07-21-07, 10:14 PM
Official welcome to the club!
Looks great, what is the measurement from the ground to center of headlight?
Dylan
'85 FJ60 | SOA | ARB | M8274-50 | Sliders | Aussie'd | H55F | 4.7 Toybox | 4.88s | Custom Crap
07-21-07, 10:19 PM
I'm close to wrapping up the major stuff, but there's still a few things to do. I'll try recap in chronological order. I have a bunch of pictures, so I'll post a few to show what's going on...
List of parts I used:
Marlin high steer kit
Custom length tie rod (44") and drag link (36 1/2")
Marlin steering stabilizer
DIY backing plate eliminator
Custom brake line (axle to caliper)
Marlin brake line F & R (frame to axle)
Ruffstuff FJ60 spring hangers
Ruffstuff U-Bolts 5/8" dia (front)
4+ U-bolt plates (modified from 4+ flit kit)
4+ perches
Spectrac U-Bolts 5/8" dia (rear)
Ford F-250 Shock towers
KavikOffRoad.com
60 Series porn
07-21-07, 10:23 PM
While spring under, the add-a-leaves lifted the truck at least 1 1/2 to 2". I used 2" shackles to level our the rear. My rear springs were pretty sacked.
Dylan
I'm going to take better pics and measurements tommorow, maybe even flex her out for shock measurements
KavikOffRoad.com
60 Series porn
07-21-07, 10:28 PM
Things left to do:
Shock mounts (more on this later)
Front drive shaft (possible temporary spacer)
Buy shocks (thinking Doetsh tech, any suggestions?)
Anti-wrap bar (Ruffstuff brackets in the garage - thinking JT Custom's design)
KavikOffRoad.com
60 Series porn
07-21-07, 10:29 PM
Just what you'd expect
HOW ARE THOSE 33's?!? N.F.W. Look like 37's or 42's.
07-21-07, 10:37 PM
I started on the front. Plan is to create a minimal lift shackle reversal.
It takes a while to cut off all the spring hangers and shock mounts. And, to clean off the axle of everything except steering stops. Basically, I used a 4 1/2" makita with a grinding wheel, cut off wheel, and a flapper wheel to finish. When cutting brackets off the frame, grind down the heads of the rivets, then 3/8" drill till it pops. A large hammer will do the rest.
I used only the main spring for mock up. I strapped it to a 2x4 so it would be as flat as possible. That way I knew where my shackles angles would be at full compression. I wanted to be as close to the frame as possible w/o touching.
The shackle tube was cut out of the stock shackle hanger...
I did not cut and turn (more on this later)
Low profile shackle reversal...
KavikOffRoad.com
60 Series porn
07-21-07, 10:38 PM
#10 (permalink)
The first picture is 33's
Now the bitch rides on 37 MTR's
edit - changed 1st post
KavikOffRoad.com
60 Series porn
07-21-07, 11:09 PM
#11 (permalink)
More mock up...
Low and flat, axle moved forward just a bit
Ruffstuff hangers are great. I needed to open up the spacing a bit, as they were tight on the bushings. I used a stock bushing bolt out of an old pair of shackles.
Had to clearance the perch for the diff housing
I pulled the fuel lines out of the way to get the shackle tubes in
KavikOffRoad.com
60 Series porn
07-21-07, 11:19 PM
#12 (permalink)
Mas...
Shackle tubes welded in...
Ruffstuff u-bolt were a bit long. I cut them down and ran a die down about 2"
Marlin hi-steer, no backing plates, braided lines (I have a banjo fitting on order to make room for the shock/mount)
KavikOffRoad.com
60 Series porn
07-21-07, 11:22 PM
#13 (permalink)
future lower shock mounts...
KavikOffRoad.com
60 Series porn
07-21-07, 11:29 PM
#14 (permalink)
Dylan
Thanks for the props, guys. I am stoked!
I do have this measurement...
Front fender - stock spring pack w/ add-a-leaf and 2 shortest leaves pulled
Rear fender - stock spring pack w/ add-a-leaf and 3 shortest leaves pulled
KavikOffRoad.com
60 Series porn
07-22-07, 04:11 AM
#15 (permalink)
looks awsome. I have an OME 2.5" and was thinking of doing a SOA. Are you thinking of or have aready lenthend you drive shafts? if so how long are they.
07-22-07, 06:14 AM
#16 (permalink)
looking good
07-22-07, 06:34 AM
#17 (permalink)
Nice work and thoughtful use of what some folks refer to as scrap!
john
07-22-07, 07:04 AM
#18 (permalink)
Rear shaft works fine as is. But the front is way too short. It will need to be lengthened about 2-3" and a long spline kit added. The trans crossmember will also need to be notched.
I'm still trying to figure out what to do about the front d-shaft. I have all the parts to do a 350tbi/700r4/203 doubler/splitcase set up. So, both driveshafts will change. I don't really want to build the front one twice. A cool dude in our local club offered to turn up a spacer, I may try this as a temporary fix.
KavikOffRoad.com
60 Series porn
07-22-07, 11:01 AM
#19 (permalink)
Looks great Kavik!
07-22-07, 11:41 AM
#20 (permalink)
Nice clean work Kavik! My hats off to you for doing it this heat.
Some questions
Estimated cost of SOA?
Pinion angle set up - DC shafts?
How far did you push the front axle forward?
Did you push the rear axle back?
Do you plan to run sway bars?
"Knowledge without experience is just information"--Mark Twain
Copper State Cruisers #003
07-22-07, 12:09 PM
#21 (permalink)
Awesome work, will be reworking my front end to drop it down in this matter. It wont be a DD any more so I might get a little crazy with it...
Again great work!
07-22-07, 12:40 PM
#22 (permalink)
Some questions
Thanks...
Truck gets about 3 good hours of shade in the afternoon
Hi-steer(full kit), perches, hangers, u-bolts, brakelines - about $600+ (still need shocks and driveshaft mods $$$$$)
No cut & turn - stock pinion angle
Moved the axle forward about 1" at full compression(room for 37's), sweeps forward at droop.
Rear axle stock hangers/location
I forgot to weld the sway bar mounts back on the front axle. I want to make one of those locking hub sway bars anyways (Aisin hub, mini IFS torsion bar, etc)
I wanted soooooo badly to take her to the Sonic meet on Friday, but her tags are bad and she rides like a drunkard with no shocks
KavikOffRoad.com
60 Series porn
07-22-07, 12:54 PM
#23 (permalink)
Originally Posted by brokenparts
Looks great Kavik!
Again great work!
...watched your builds very closely...
Thanks!
KavikOffRoad.com
60 Series porn
07-22-07, 01:26 PM
#24 (permalink)
that rocks kavic. fine looking build and rig you have there. i am really liking the fact that the body is stright and not hacked on to make room for the lift and tires.
clint
07-22-07, 05:21 PM
#25 (permalink)
KavikOffRoad.com
60 Series porn
07-22-07, 05:40 PM
#26 (permalink)
Dylan
Drivers side 42"
Passenger side 43"
Average 42 1/2"
KavikOffRoad.com
60 Series porn
07-22-07, 06:20 PM
#27 (permalink)
A full 2" lower than mine.
Nice work, hopefully the spring packs hold up well.
07-22-07, 06:40 PM
#28 (permalink)
Cali - you running 35's or 37's?
KavikOffRoad.com
60 Series porn
07-23-07, 09:31 AM
#29 (permalink)
Kavik,
Looks awesome!
too bad shes rubbin like a crack whore!
Beautiful job on the SR...I would have been FREAKIN cutting the frame!
Did you get Longs, or run the stock axels?
Chicago
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Sold to a good home. Goodbye old friend!)
76 FJ40 (Blotch rig part deux)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS!
07-23-07, 09:56 AM
#30 (permalink)
Originally Posted by chicago
Kavik,
Looks awesome!
Chicago
Right on, thanks man.
No longs for now. I'll probably run stock till she breaks.
How do you like your D-tech shocks? Did you get them online? I'm trying to figure out what to use...
As far as cutting the frame, not as spooky as it seems. Having the right parts to play with(ruffstuff & 4+  ) and mocking up over and over builds confidence.
I kinda pussed out on the rear, and I may end up doing some surgery on the rear hangers as well. I'm having to run the rear springs very flat to get the truck level.
I'm going to bag the add-a-leaf in the rear and reinstall all of the stock(sagging) springs to bump up the load capacity. Right now it's very mushy back there.
KavikOffRoad.com
60 Series porn
LinkBack to this Thread: http://forum.ih8mud.com/60-series-wagons/167562-kaviks-soa.html
| Posted By |
For |
Type |
Date |
| kavik :: BoardReader |
This thread |
Refback |
01-16-08 06:54 PM |
