Old 06-22-07, 05:28 AM   #1 (permalink)
VTCruiser's Avatar
Garage
3,300 Miles in 6 Days (tech)
I will be doing a cross-country road trip in a about a week in an 1986 FJ60 with 258k miles ont it.
(incase you didin't see the post in chat... 3,300 Miles in 6 Days)
Since i have never owned a 2F i'd appreciate some advise on what spare parts to bring at what you would recommend looking at before the journey. I will dedicate one evening to some basic service when I get out there, a job that requires more than hand tools I can probably have a shop do before I get out there. Here's what I was thinking...
Pre-trip service:
- Oil change
- top off tranny, t-case and diff fluids
- inspect/replace brakes pads
- inspect/replace bulbs
- inspect/replace air filter
- Fan clutch?
- replace fuel filter (where is the fuel filter on these?)
- inspect smog equipment?? (how?)
- inspect u-joints
- check battery/power
Shop work:
- flush radiator
- upper and lower radiator hoses
- replace water pump?
Stuff to bring:
- Set of hand tools
- spare belts
- vacuum hose
- engine oil
- gear oil
- lots of water
- extra spark plugs
- oil drain pan
- brake fluid
- zip ties
- service manuals
- flash light
- tire gauge
- duct tape
- tire plug kit
- compressor
- gloves
- alternator
- funnel
anything else?
Hello. My name is VTCruiser and I am an addict.
Project Overland Build - Updated 12/28/09
ROTM - May 2009
UpstateCruisers.net
VTCruiser is offline   Reply With Quote
Old 06-22-07, 06:30 AM   #2 (permalink)
Zack1978's Avatar
Where are you going to do this work? Do you plan on taking it to a shop out there? How are you going to take tools on the plane?
Zack
Zack1978 is offline   Reply With Quote
Old 06-22-07, 07:09 AM   #3 (permalink)
euclid's Avatar
HELL Yeah. This is going to be good.
Top of the list of stuff to bring needs to be every service manual you can get your hands on:
FSM for sure then also Haynes & Chiltons
Read them all cover to cover a couple of times.
Get the Cruiser Assistance Club list from Woody before you leave.
I'd say do a good check over like you say, then get rolling. Fix what breaks as you go. Maybe add your hikeing shoes to the list, in case you end up hiking. Get a haircut in case you end up hithchikeing.
I wouldn't do the water pump unless the weep hole is leaking.
Greg Thompson
89 FJ62, Unstock.
euclid is offline   Reply With Quote
Old 06-22-07, 07:42 AM   #4 (permalink)
VTCruiser's Avatar
Garage
the work will likely be done in the parking lot of a parts store. I am a college student so I am wel versed in the art of shade tree mechanics...or shady mechanics under a tree? however that expression goes...
I plan to buy a tool set from walmart when i get there.....and maybe try and return it when I get back....
ROTM - May 2009
UpstateCruisers.net
Old 06-22-07, 07:48 AM   #5 (permalink)
Just what you'd expect
Tofudebeest's Avatar
Top and bottom radiator hoses. A radiator flush might be a good idea. Zip ties in various sizes, especially the big ones.
Are you towing anything?
Oh, don't forget to double check your spare tire. Maybe have a second spare tire on the roof or in the back.
Tofudebeest is offline   Reply With Quote
Old 06-22-07, 07:53 AM   #6 (permalink)
VTCruiser's Avatar
Garage
good stuff guys, thanks.
list updated...
ROTM - May 2009
UpstateCruisers.net
Old 06-22-07, 08:31 AM   #7 (permalink)
2mbb's Avatar
Garage
don't forget a roll of duct tape!
mbb
1985 FJ-60
2mbb is offline   Reply With Quote
Old 06-22-07, 08:42 AM   #8 (permalink)
Ming89FJ62's Avatar
Amen brother. Make sure that you can actually lower the spare. If the truck has been through any road salt the tire carrier may be inop. Life would totally suck if you needed the spare and couldn't get the damn thing to drop. Also make sure that you have the jack and the rod for lowering the spare.
78 FJ55 - "Arnold"
78 FJ55 - "Chester White"
89 FJ62 - "Ming"
07 UZJ100 - "Koto"
TLCA #13476
Ming89FJ62 is offline   Reply With Quote
Old 06-22-07, 09:17 AM   #9 (permalink)
euclid's Avatar
Good thinking on tires, add: tire plug kit and a cheapie Wall Mart compressor (return it too).
Greg Thompson
89 FJ62, Unstock.
Old 06-22-07, 09:37 AM   #10 (permalink)
hks3sgte's Avatar
A recent thread on this is Pathfinder's... Maybe it will be helpful to you VT...
1400 Mile Trip with New (used) 1984 Cruiser What should I take??
So that's the lucky 60 that's soon to be 1HZ powered?
hks3sgte is offline   Reply With Quote
Old 06-22-07, 09:56 AM   #11 (permalink)
euclid's Avatar
And cable lockers?
Greg Thompson
89 FJ62, Unstock.
Old 06-22-07, 12:52 PM   #12 (permalink)
Rookie
Ok, I joined this forum to find out info on cc trips. I've had my '85 FJ60 for 3 years, no problems, a few replaced parts, new tires, regular maint. and I'm planning on driving it from the Florida Keys to Michigan next month. I know nothing about fixing it. Should I be worried? I've read all of VT's checklists and I can have my mechanic follow it but what would any of you say the realistic chances of me breaking down are? Am I crazy to think I can make it 1,700 mi. without a problem? I can get duct tape.
'85Colleen is offline   Reply With Quote
Old 06-22-07, 01:03 PM   #13 (permalink)
You need to add some ass wipes to you kit. Also need them fancy plastic disposable gloves, tire pressure gauge. Ship misc. parts down there via DHL if you got them. You will be surprise how cheap it really is. flashight would be nice. The LED type will be even better. If you have an igniter handy bring it. I have an alternater I can drop ship you if you need one. Good luck.
Only put gas in well lit areas.
fjwagon is offline   Reply With Quote
Old 06-22-07, 01:11 PM   #14 (permalink)
VTCruiser's Avatar
Garage
list updated....
yeah I don't think it has a spare tire...so anyone in CA have spare tire they want to sell cheap? as long as it holds air...
yes this if the furture body for the 1hz, the newly aquired cable lockers and more....
ROTM - May 2009
UpstateCruisers.net
Old 06-22-07, 01:11 PM   #15 (permalink)
cabron's Avatar
definitely duct tape, funnel, road flares.
1974 Toyota FJ40 (sold Jan 27)
1985 Toyota FJ60 two-tone, Safari Rack, OME Heavy,33x9.5's, custom front/rear bumpers, fully sound deadened, Alpine H/U, Rainbow components, dual v12 amps, 12" Type_R, Mot's Lights.
cabron is offline   Reply With Quote
Old 06-22-07, 01:21 PM   #16 (permalink)
VTCruiser's Avatar
Garage
After three years you are probably pretty familiar with your cruiser by now so you don't need to worry as much about half the stuff on there.
i, on the other hand, have never even laid eyes on this thing....
ROTM - May 2009
UpstateCruisers.net
Old 06-22-07, 01:33 PM   #17 (permalink)
You can usually find a good used tire at those hole in the wall places that sell used tires.
Originally Posted by VTCruiser View Post
list updated....
Old 06-22-07, 01:33 PM   #18 (permalink)
NocalFJ60's Avatar
Did they tell you how bad the oil leak is? I am not far from highway 5 & 99 (about 30-45 mins) if you need a garage and tools after 4 hours of driving.
Sounds like a fun trip. The tires look bigger than 235's. That will help out on the highway. What size tires are they?
1982 FJ60 SUA OME w/AAL's, 34's, H55F, 4.7 toybox
Northern California
TLCA/PMC Member
"He who throws mud only loses ground."
NocalFJ60 is offline   Reply With Quote
Old 06-22-07, 02:03 PM   #19 (permalink)
hks3sgte's Avatar
http://www.africancruiser.com/
among many 60 series that have been driven long distances
Old 06-22-07, 02:28 PM   #20 (permalink)
warpdriv's Avatar
You might want to publish your route. That way we are aware of where you are if you have problems and can help. Isn't there a land cruiser travelers emergency contact list somewhere?
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
warpdriv is offline   Reply With Quote
