Old 06-04-07, 10:49 AM   #1 (permalink)
earl's Avatar
H55 sticky 5th gear after extended highway driving
Hi,
I took my fam for a little trip in the Land Cruiser on Saturday. My wife actually went from not liking the cruiser to liking it after the trip. Anyway, after about an hour of driving at about 110 kph we stopped. Once we continued on I noticed shifting into 5th gear was really sticky/firm feeling. No grinding. It did this most, but not all of the rest of the trip. Going to work today, 5th gear felt normal.
Anyone have any ideas?
earl is offline   Reply With Quote
Old 06-04-07, 11:58 AM   #2 (permalink)
Almost done with V8!!!!!
djawahir's Avatar
Check fluid level in tranny?
How many miles on the H55F?
I have the uncanny ability to make things harder than they really are.
V8 swap progress: Oil cooler mounts being fabbed and installed!
djawahir is offline   Reply With Quote
Old 06-04-07, 02:08 PM   #3 (permalink)
earl's Avatar
I didn't check the fluid level on the trip, although I wish I would've so it would save me from driving a long ways again. There's 320,000 km (or 198,838 miles) on the tranny. I changed the oil in the tranny a few months ago and checked the t-case. No leaks. But I do wonder about the possibility of that problem where oil leaks between the t-case and tranny.
Old 06-04-07, 04:46 PM   #4 (permalink)
Stand and deliver
roscoFJ73's Avatar
Maybe the nylon bush at the bottom of the gearstick needs replacing or your shift forks are showing some wear.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 06-04-07, 05:51 PM   #5 (permalink)
FJ60Cam's Avatar
My H55 has been in the truck a little over a year, and has always been a little sticky getting into 5th. It doesn't grind or make noise, it just takes more effort. It doesn't seem to matter how long I've been driving it.
I just assumed this was normal due to the extra linkage for the 5th gear.
Cameron Mosley
'85 FJ60 - Daily Driver
FJ60Cam is online now   Reply With Quote
Old 06-04-07, 08:05 PM   #6 (permalink)
earl's Avatar
Guess there's only so much I can do really. I'll start with the little things, and then just assume it's normal. It was my first long trip with it, so maybe it is normal.
Old 06-04-07, 09:36 PM   #7 (permalink)
Cruiserdrew's Avatar
It isn't right. I've had mine for over two years and it doesn't do anything like this. I would start with a gear oil change, and see what happens, and see how much metal is on the drain plugs. If it's older, it would be worth replacing the plastic collar in the shifter tower.
Andrew
1976 FJ40 almost gone
1984 FJ-60 H41, Toybox, 4.56/ARBs, SOA, twin sticks and more
Old 06-04-07, 11:03 PM   #8 (permalink)
Supporting Vendor
cruiser_guy's Avatar
Mine has over 500,000km's and it doesn't give me any hassles. I didn't think that the H55 had the plastic ring but if it does that is certainly the FIRST thing to do!!
www.wirrell.com
Old 06-05-07, 05:00 PM   #9 (permalink)
earl's Avatar
Thanks. I'll order up one of those and see what happens.
