05-28-07, 02:39 PM
| | Forum Regular
| engine keeps cutting out my rig is desmogged finally, and as of this past week, when she's running, the engine just sputters and dies. there seems to be no rhyme or reason. the engine will cut out at varying rpm's. i'm on my way to grabbing a vac gauge. until i post readings, does anyone know what this sounds like? thx!
__________________ '83 fj60 landcruiser "crusher" (blue), desmogged & rebuilt engine, 212k, 2" lift, 31" x 10.5 BFGs... wanna do a whole lot more |
05-28-07, 07:40 PM
| | Forum Lifer
| Do you still have your idle cut solenoid in place, wired as it should be?
__________________ Doug G
Seattle, WA
TLCA#12671
1987 fj60, 310,00 miles, 3" lift, 33X10.50's BFG MT, dual battery, rear drawers, CB, tuffy, , lockright, 4.10's and H41 soon |
05-28-07, 08:41 PM
| | Forum Lifer
| cut and ground the white w/black stripe wire on the idle solenoid....
__________________ |^^^^^^^^^^^^^^^\ ||__ |.......PBR BEER TRUCK.... ||""\_____\ |_____________________/||__|___| |(@)(@)"""""""""""|(@)(@)*****|(@) The Beer Truck, that ran over Bunny..... (\__/) (='.'=)  (")_(") |
05-29-07, 07:22 AM
| | Forum Regular
| Quote:
Originally Posted by lovetoski Do you still have your idle cut solenoid in place, wired as it should be? | yes. Quote:
Originally Posted by grant5127 cut and ground the white w/black stripe wire on the idle solenoid.... | even if the idle cut solenoid is in place & wired as it should be?
05-29-07, 08:10 AM
| | springfield user
| yes. the computer is confused and is closing the solinoid.
if you ground it, that keeps it open.
__________________ it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler toyota material distribution center. your source for Factory Service Manuals. they're alot cheaper than you think. 1-800-622-2033 |
05-29-07, 12:30 PM
| | Site Addict
| Part of your "desmog" likely disabled the vacuum switch. The emissions computer thinks you are decelerating and is shuting off the fuel cut solenoid. Grounding it to keep it on should fix the stalling issue but may also lead to dieseling on shutdown and backfiring when decelerating.
__________________ '96 FZJ80
Member Rising Sun Chapter TLCA
KC0ZAC |
05-29-07, 10:04 PM
| | Forum Regular
| Quote:
Originally Posted by brian yes. the computer is confused and is closing the solinoid.
if you ground it, that keeps it open. | i grounded the black & white wire. now my rig won't start at all.
HEEEEELLLPPPPP!!!!
i dunno where to begin now!
05-29-07, 10:46 PM
| | Forum Lifer
| Quote:
Originally Posted by iglou i grounded the black & white wire. now my rig won't start at all.
HEEEEELLLPPPPP!!!!
i dunno where to begin now! | Un-do what you did.
Seattle, WA
TLCA#12671
05-30-07, 09:13 PM
| | Forum Regular
| i'll undo tomorrow. then what?
