05-17-07, 09:59 AM
| | 250+ Club
| Carb 'Secondary' : Failure Symptoms ? If the 'secondary' is not functioning, what would be the symptom ?
A few weeks ago, I senta post about seeming to have less 'power' when outside air is hot, but lots of get up & go when air is cold.
Seem to have fair 'green light' get up & go when hot outside, but real zoom-zoom ( well as best as a 60 could ever zoom) at o'dark thirty in the morn (or late at night)
Yesterday, 3.5 hour turnpike drive....every now & then, I'd find that I've slowed down (ever so subtley) to about 2500 rpm (64 mph) and gas pedel floored !
I could ease up on the pedel a bunch (maybe 1/2 inch tween pedel and 'stop' behind it and loose no speed at all....no matter what I did, couldn't get over 'about' 2500 rpm....
real pisser is an over pass,,,,looseing speed going up...with gas floored....
....of course got it back going down hill...only to have it dwindle on the long level straights....
down the road, approach a cloudy, rainey, cooler area,,,,,could....over the course of a few miles, get back to about 3000 rmp (71,72 mph).
and, as best as I could tell, no knockling or pinging under 'loosing speed, floored, ' etc conditions....
Engine 'unloaded' will rev well past 3000....just the under load performance sucks
Well, thanks for any suggestions...oh, this is a 442,xxx miles orig carb....
__________________ Nov 85 FJ60 94 FZJ80 |
05-17-07, 10:08 AM
| | Merchant of Death
| in 3rd gear doing about 40-45mph, floor it......you should feel the "HUGE"(LOL) surge of power when then secondary kicks in
__________________ Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace |
05-17-07, 05:23 PM
| | springfield user
| Quote:
Originally Posted by Landpimp in 3rd gear doing about 40-45mph, floor it......you should feel the "HUGE"(LOL) surge of power when then secondary kicks in | swing and amiss with mine, though i pretty much already figured i had no secondary.
__________________ it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler toyota material distribution center. your source for Factory Service Manuals. they're alot cheaper than you think. 1-800-622-2033 |
05-17-07, 05:26 PM
| | 250+ Club
| Mine used to lose power on long drives, too (same symptoms), but not since I cleaned the carbs, so you might be on to something. There are a couple of threads about it, but I'm not sure what you should search.
__________________ Accordionist of the Dirty Mugs http://www.myspace.com/thedirtymugs
85 FJ60- The Chooser- Rust free, 33's, a sleeping bag, a pillow, 2 Lo, and seperate front and rear sound sources. 215k. I'll trade it for a clean Yamaha Virago (500cc-750cc), VMAX, or Honda equivalent motorcycle. |
05-17-07, 08:59 PM
| | Forum Lifer
| With the engine off, put a paper clip on the secondary actuator rod so that it is touching the vacuum housing case. Take it for a spin and put your foot in it several times. Park it and check out the paper clip: If it has moved down the rod a half inch, the secondary is opening. |
05-18-07, 08:59 AM
| | Cruiser Curmudgeon
| Quote: |
| The secondary has been inop for the last 300K miles.
Really.
__________________ Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's  since 1988. |
05-18-07, 10:39 AM
| | 250+ Club
| brian > in 3rd gear doing about 40-45mph, floor it......
chit man, I'm lucky to get to 40-45 in 3rd !
I can easily get right on up to about 40-45, from there one it's a slow ride to 50,,,,,55,,,,,60,,,,if I'm lucky,,,,65,,,,,,if I'm real lucky 68,,,,,
Old ladys in old cars are honken & flippen me,,,,frikken loaded dump truck out accelerate me once 'we' hit 40 ish....
Pinhead> . . .paperclip
I'll try it
Soggy60 > this is a 442,xxx miles orig carb....
FJ40Jim >The secondary has been inop for the last 300K miles. Really.
The Great Guru Of Carb has spoken, and I'm a believer...
So, I beg of thee, what is the (hopefully) simple repair ?
( If I can grab a spare, one will come your way for your magic touch)
pete
05-18-07, 11:53 PM
| | elder statesman
| Quote:
Originally Posted by FJ40Jim The secondary has been inop for the last 300K miles.
Really. | Bwaaahaah! Perhaps a little generous in your estimate there?
Totally concur with Jim on that call.
You're in good hands.
Best
Mark A.
__________________ A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40, 69FJ40, 72VJ40, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA member, The White Trash Of The Elwood chapter
my website: http://www.marksoffroad.net IT'S FASTER if you CALL ME! |
05-19-07, 06:48 AM
| | Cruiser Curmudgeon
| Soggy, the fix (at minimum ) is a new diaphragm that is not cracked & rotten.
Cerainly w/ that mileage a whole carb rebuild & tweaking would also be justified.
Or maybe an entire engine rebuild.
and a tranny & t-case overhaul
And front axle rebuild
and new frammis modulator...
Where do you stop fixing on a vehicle w/ that kinda miles?
Jim C.
TLC Performance
05-19-07, 09:10 AM
#10 (permalink)
| | 250+ Club
| I R&Rd my diaphragm and WHOOHOO it really made a difference, although now I cant keep my foot out of it and my MPG is worse. |
05-19-07, 06:36 PM
#11 (permalink)
| | 250+ Club
I agree; it's my DD so I need to find a spare carb B4 I send ya mine
or switch to a Toyota desiel
got the parts for xfer overhaul; waiting for tranny to take a dump so I can 'justify' getting an H55
Been There, Done That; swapped diffs to 4.11s (w/ ARBs....both), too....
Before or after the muffler bearings ? ;-)
oh,, BTW, the 'ring' clamp ex pipe to bracket from tranny; bout every year, I have to 'reset' it, it walks off trany bracket( yes, I know about alignment of ring & lip on bracket...)
> Where do you stop fixing ....
Never....
Not all of the mile have been kind; banged trees, stuck in mud, bounced off logs, not yet been to GSMTR....
I'll get one of those diaphrams;
nudda question: The 'bolts' on carb; look like bowl drains (or access to jets)
OK to unsrew / drain bowl / blast (sorta blast) with carb cleaner / screw back on / be happy-don't worry ?
05-19-07, 09:10 PM
#12 (permalink)
| | Cruiser Curmudgeon
| Quote:
Originally Posted by soggy60 The 'bolts' on carb; look like bowl drains (or access to jets)
OK to unsrew / drain bowl / blast (sorta blast) with carb cleaner / screw back on / be happy-don't worry ? | Yes, the carb can be flushed out by removing the 14mm bowl plugs and then hosing Gumout(tm) in the vent tubes on top & in the drain holes. Not a bad PM idea.
Jim C.
TLC Performance
05-20-07, 03:32 PM
#13 (permalink)
| | 250+ Club
| Thanks Jim, I'll order one of the diaphragms for the carb and 'flush' the bowl...
Again,
Thanks to all !
